Question about Black & Decker Classic Metal APP F63D Iron
Iron won't heat up.
My Black and Decker Classic Metal iron is about two and half years old. The cord has become badly twisted due to wear, so the connection isn't being made, and the iron won't heat up. Otherwise the iron is in fine shape, and since it was fairly expensive, I'd like to repair it. I think all it needs is a new cord. Is this a possibility, and will it be very expensive to replace?
Thanks!
SOURCE: Cleaning a self cleaning iron
My iron went into cleaning mode and I don't know how to stop it from doing this. I don't need to clean it now. How do I get it to stop?
Posted on May 24, 2007
SOURCE: iron D2000C type 1 black decker
the folowing reason for not working 1. the connection may be lose 2. the heating coil is gone 3. inside connection may be lose.
Posted on Sep 30, 2007
VOTIT
  • 2071 Answers
SOURCE: Black & Decker Iron - Steam Advantage - won't turn on
Just open your flat iron and locate the face plate contactor that has a soot burn causing the filament not to heat,use a sand paper to clean the contact from soot burnt,this the common problem of a flat iron...
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 10, 2008
futureloginn
  • 734 Answers
SOURCE: my iron needs a new cord
purchase it from==
http://www.powercord-manufacturers.com/
thank you for using FixYa
Posted on Nov 14, 2008
electrodynam
  • 35 Answers
SOURCE: the black and decker iron wont heat up
It probably has a high temp overload opened up inside or the thermostat control has gone bad.You can only tell for sure by taking the unit apart and testing the circuit for continuity.The steam feature on the iron is heated by the same element that heats the iron so it wont work.the element itself could also be bad,but I have never seen one go bad.You will have to check each component seperately to find the damaged part.or you can test the whole circuit at the plugs end,and use a jumper across each part until you have continuity through the unit.Make sure the thermostat is turned all the way up.the part that you are bypassing when you get continuity is the bad part.
You can buy a cheap continuity checker at any lowes,or even wallmart for that matter.
Posted on Mar 16, 2009
How do i prevent my black and decker classic iron from spitting out how water after I have used it for a while?
Cheaper irons may steam better using distilled water. Minerals in water can cause this due to build up inside.
Oct 01, 2014 | Applica Black And Decker Classic Iron With...
The electrical cord is very hot at the point where the cord enters the iron
mcdevito75 here, You may have a problem with the heating element in your iron, Check to see if you have a Warrantee if so, return the iron to Black & Decker. In the meantime look for an appliance repair shop in your area and have the iron checked out.
Aug 07, 2010 | Black & Decker Prestige Plus Premium X830...
How to replace the power cord on "The Classic"
If it looks like a allen and and you cant get it ... be aware allen comes in both metric and standard ... you may be looking at a Torx which is a different animal all together.
Take your Iron to the hardware store and match it up to the proper tool for best results.
Thanks for your interest in FixYa.com
May 31, 2010 | Black & Decker Classic Metal APP F63D Iron
Black & Decker Steam Xpress AS250 Iron with Auto Shut-off: my iron won't heat up. the green light comes on b...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
May 18, 2010 | Black & Decker Steam Xpress AS250 Iron...
Black rubber burned onto plate of iron
Here is a tip that will help you with that problem...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Apr 12, 2010 | Black & Decker ProFinish X750 Iron
Cord
If the iron is still in warranty send it back via the shop where you bought it, the inner wire is frayed and needs replacement, if you know an electrician its as simple as shortening the flex by a few inches and reattaching it again. the inner wires twist with time and become frayed or come loose from connection
Mar 24, 2010 | Black & Decker Steam Xpress AS250 Iron...
Brand new iron and it wont heat up over 140 deg F.
Contact B & D and they will probably replace it - they will need the receipt.
Mar 01, 2010 | Black & Decker Classic Metal APP F63D Iron
Same Issues with my Black/Decker 2030
change the thermal fuse inside iron that's why not getting hot. thermal fuse blown up due to overheat inside.
Aug 19, 2009 | Black & Decker D2030 Iron
I want to repair myself
There is a security screw in the back of the F63D classic iron. It must be removed to get the back plate off. I haven't found the right tool yet myself, though it was suggested it is a "security" Torx.
Aug 21, 2008 | Black & Decker Classic Metal APP F63D Iron
Black & Decker SteamXpress 620
Check the cord...
heatman101
Jun 11, 2008 | Black & Decker Steam Xpress AS250 Iron...
Black & Decker Classic Metal APP F63D Iron Logo
75 people viewed this question
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
