Question about Sharp Office Equipment & Supplies
SHARP 1631 CODE L3
CODE L3
  • 138 Answers
The error is for the scanner mirror home position sensor. When the scanner mirror comes back to home (start) position if the photocell sensor doesn't see it due to be dirty or faulty the L3 error will be displayed.
Hope that helps you.
Posted on Aug 06, 2008
I HAVE A SHARP AL 1631, IT SHOW ME A 4 CODE, HOW CAN I TO SOLVE THIS
their is no A4 code,if you mean H4 try to reset it by simulation 14
Dec 26, 2010 | Sharp AL 1631 Copier
Tip
All sharp 1631 and 1642 models have scan unit problem.
When scan unit doesn`t move you have (L1-from left to right)and (L3-from right to left)code or blank copy (white).first must check scan uniy lock under the scan unit-then service 2 plates that scan moves on it.
on Jun 01, 2010 | Sharp AL 1631 Copier
Sharp al 1631 need drum roller reset code
enter code 42 start 1 start.
(press C auto C auto 42 copy1 copy)
Apr 28, 2010 | Sharp AL 1631 Copier
H 4 code flashing
The H4 code indicates the fuser may have blown the thermistor. It also could be a false error code. Try this series to clear the error and if it returns, then you'll know for sure the fuser is the culprit. To reset press the following buttons:
  1. Press this sequence: CLR-Exposure-CLR-Exposure
  2. The display will go blank
  3. enter "14", press "PRNT"
  4. Press "CLR" several times to exit.
Give that a try and good luck.
Feb 18, 2010 | Sharp AL 1631 Copier
Sharp al 1631 error code l-1
The problem it in exposere lamp section.The forward scan is not compelet.Cause is the mirror motor control board or mechanical parts.
Oct 03, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 is flashing 1 L. What does that
Hi:
This might refer to your scanner assy being locked. The scanner assy is the unit under the glass that scans your document prior to copying it. Look inside the cavity where you pick up your completed copies. Look at the upper left corner and see if there is a knob there. If there is, make sure it is in the completely unlocked position.
Andrew
Aug 09, 2009 | Sharp AL 1631 Copier
Sharp AL-1631 copy problem
it doesnt sound like to much is rong with the scanner they all judder at start up. if there was a scan drive issue you would get a L3 error code. does the m/c continually tick over? if so then you may just be out of toner as the m/c will be trying to reach its toner levels and that can take some time.
Dec 03, 2008 | Sharp AL 1631 Copier
H3 ERROR CODE SHARP AL 1631
H3:
00:TEMPERATURE OF FUSER UNIT HIGH,THERMISTOR CONTROL BOARD FAILING
Did you replace the thermistor? check the thermofuse also for continuity
Oct 20, 2008 | Sharp AL 1631 Copier
AL 1631
The clarification request should solve the problem
Jun 10, 2008 | Sharp AL 1631 Copier
What happend with a error L3
An L3 means the lamp and mirror carriage is not comming back to the home position. Back to the left. It isn't being sensed in the home position sensor.
Are the cables on the pullies?
Have you taken the glass out and cleaned it? You can put one of the screws into the wrong place and that will hit the carriage, blocking the return.
Jan 08, 2008 | Sharp AL 1631 Copier
291 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
