Question about GPS
Lowrance LMS 335 C
Will not boot up was the question. Where is the reset switch how much does the upgrade software cost and what will it do?
  • 13,433 Answers
Our unit will not power up
Hi urcvrdha,
You have an elaborate unit! I like these. Your problem sounds more electrical than software related. Try taking all power off the unit for about 30 minutes, then powering up again. Of course, check your fuses. If you get the unit back up to the main menu, and things are not working properly, go to the various "reset" options in your manual for that mode of operation.
If it does not succeed in getting power, I recommend contacting your local Marine/Lorrance dealer for service.
If you don't have your manual handy, download one here:
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LMS-337CDF_0156-071_121704.pdf
I hope this adds a little information to your problem search. Thanks.
Regards, Bill
Sep 16, 2010 | Lowrance LMS-332C GPS Receiver
LMS 332c Power cycles on own
i've repaird this by installing a secondary powerswitch and disconnecting the power switch on the keypad. It's an involved repair but it can be done.
Jul 13, 2009 | Lowrance LMS-332C GPS Receiver
Hi,when i switch on my lms-332c the map does not come up on the screen.If I remove and replace the map card it works perfectly. Can I fix this? regards nigel
I am guessing that the card you are using is a NAVIONICS chart? There have been some Lowrance units that were made around the same time that have had problems recognizing a Navionics chart right from power up.
Make sure the LMS-332 has the latest firmware version which can be downloaded from http://www.lowrance.com/en/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-332C/Downloads/LMS-332C-Software-Update/
If the update doesn't help, this is going to be a compatibility problem with the LMS-332 and that particular card. You will need to replace the card or upgrade to a newer unit...but probably can just get used to removing and replacing the card when you turn the unit on.
Jul 08, 2009 | Lowrance LMS 332c Mapping Sonar/GPS...
Lowrance 330c screen says '' boot failed''
Try a hard reset:
1. Turn the LMS-330 off
2. Press and hold the ZIN, ZOUT, and PWR buttons
3. Release the three buttons once you see the "warning, do not rely..." message appear
If you get that far, the problem is solved. If you get boot failed again, try installing the latest update which can be downloaded from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
If you still get boot failed, you will need to get the LMS-330 repaired/replaced. You can contact Lowrance support at 800-324-1356 or email them by going to http://www.lowrance.com/en/Support/Product-Support/Contact/
Mar 22, 2009 | Lowrance LMS-330C GPS Receiver
My Lowrance LMS-337c df keeps going crazy.
Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}This could be caused by glitch in the operating systemsoftware or by low voltage due to a short in the unit or somewhere in the boatswiring. To troubleshoot the problem Iwould recommend the following steps.
  1. Try a soft reset
  2. If the problem resurfaces, try a hard reset
  3. Update the the operating system software
Soft Reset (Does not delete GPSData)
1. Turn unit OFF 2. Press and holdthe PAGES key
3. Press and hold the PWR key
4. Release both buttons when the USA map
Appears
Hard Reset (Deletes stored GPS Data
such as Waypoints and trails)
1. Back up any waypoints, routes,and trails that you want to save on a blank MMC card
2. Turn unit OFF
3. Press and hold the ZIN&ZOUTKeys at
the same time
4. Pressand hold the PWR key
5. Release both buttons when the USAmap
appears
To update the operating system software, check out this link:
Lowrance337c df update
If you don't have a card reader I can program an update card for you.
Dec 15, 2008 | Lowrance LMS-337CDF GPS Receiver
Cannot access main menu or pages screen
I think I can help with your issue. I have an LMS 334c and have had a few issues in the past. Called the factory (this answer is not listed any where in your manual) and they instructed me to "Soft Re Boot" my unit and it would put everything back to factory settings. Try this anytime it does not respond for whatever reason.
Turn the unit off.
At the same time press the Pages and Power button. Hold both down until you see the square box come up in the screen. You should have your factory settings again. May need to try a few times.
Lowrance said it works just like a computer, ever now and then it just tries to disect to much information at one time and hangs up.
Good luck. James Cantwell
Nov 03, 2008 | Lowrance LMS-330C GPS Receiver
I need CD, or DVD to learn how to use my Lowrance it is modle LMA-332C & LMS-337C DF.
Here you can buy the DVD for $13:
Bennett Training DVD For Lowrance LMS-332C
Here is the user manual:
LMS-332C and LMS-337C DF Owners Manual
Do not forget to rate the solution appropriately.
Many thanks.
Aug 31, 2008 | Office Equipment & Supplies
GPS Logo
979 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
