Question about JVC TH-M505 System
Humming When I hook up the red,white wires to the back of the jvc vcr in. There is a hum when I plug into the source when I unplug and touch the end of the wires It hums
Maybe one of the audio leads does not have a complete earth shield and until the second lead is connected, the lack of a suitable earth shield produces the 50Hz 'hum'.
If you should connect either of the two the centre conductors to your body, YOU will introduce a similar hum due to your body acting as an 'earth' to that signal carrier.
These are frequently common effects and it may be a good idea to turn the volume level down on the amplifier or even turn it and the VCR OFF whilst you make or break these connections.
Good Luck!
Posted on Aug 05, 2008
How do I hook-up a dvd/vcr.
Hello dgrant13,
All you need to do is use a composite cable, or known as RCA cable (the red, white, and yellow cable). Both ends of the cable should have red, white and yellow. You just need to find the red, white, and yellow on the back of the dvd/vcr where it says audio/video out (AV out). Then match the colors and plug one end to the back of the dvd/vcr and the other then (matching the colors) to the Proscan tv where it says audio/video in (AV in). Good luck.
Joe
Aug 28, 2011 | Proscan 32LA30Q Television
CONNECTING DVD/VCR TO CABLE BOX & TV ETC
moz-screenshot.jpgHI-
Check this site for Info's how to connect your device, click HERE
keep me posted for inquiries, thanks!
Jun 30, 2008 | Philips Magnavox DVD/VCR Dual Player
My Epiphone Dot just started humming really loudly when I plug it in - it stops humming when I touch the input jack. I assume it's a grounding issue on the input jack, but how do I get at...
Make you a hook out of a coat hanger. Get inside and hook the wiring to the jack, take the nut off the jack and pull it up through the F hole. You can plug in to it a patch cord so you can pull it back through once fixed. Check out Guitarelectronics.com for a wiring diagram.
Jul 03, 2011 | Epiphone Elitist Country Deluxe Hollow...
Can't hook vcr to tv
on the back of your VCR there will be a yellow colored port - most likely labeled "OUT" as well as possibly a white/red pair of ports.
The yellow is for a VIDEO hookup, the white and red are for AUDIO hookups.
These ports use what is called an RCA type connection.
Radio Shack, or just about any department store should be able to sell you an inexpensive set of RCA cables.
now on the back of the TV (possibly on the side) you will also have the yellow, white and red ports.
Hook one end of the RCA cable to the colored ports on the VCR, the other end of the cable to the colored ports on the TV.
last thing - the TV most likely has multiple inputs. there is probably a input button on the TVs remote, you need to press that button to cycle through the inputs until you get to the one the VCR is hooked up to.
its easiest to put a tape in the VCR and press play - when you get to the right input, you will see your tape...
good luck
Apr 05, 2010 | Dynex DX-L32-10A 32" LCD HDTV
My akai receiver to my vcr
hi my name is mark, if you have cables. first unplug the power cords to the vcr and the receiver. on the back of the vcr there will an input and an output audio and video connectors. if your vcr does not have them you will need a new vcr that does. if you just want sound, find the Output connectors. there will two. they will be idenified as Audio OUT. plug one end of the red plug into the one labeled Audio R OUT, then the white in the one labeled Audio L OUT. if you are connecting the video up connect the yellow plug to the connector labeled Video OUT. the other ends connect to the receiver, on the back of the reciever find connectors labeled vcr or dvd AUDIO IN. then connect the red plug to the connector labeled R IN and the white plug to the connector labeled L IN.if you are just hooking up sound you done. to hook up video find vcr dvd Video IN and connect the yellow plug to the Video IN. on reciever. if you want the reciever to switch the TV you also need to run a yellow video cable from Video Out from receiver to Video IN on back of TV. when finished plug in vcr and receiver. select dvd or vcr on receiver to listen ot vcr on the receiver i dont know what model you have or it features i hope this helps thanks for your question.
Mar 17, 2009 | Akai 42 in. LCD TV
Humming from speakers
I need to know how you have your TV hooked up through the cable for ex. hdmi or the green blue red white and yellow cables that plug into the back if its not doing it through the ps3 or anything else means its not the TV its either a faulty cable box or the wires are bad or hooked up wrong going to the tv.. i would first check make sure all the colors are in the right color slots if thats how you have it hooked up and if thats all right then just email me back through the fixya website i am on every hr id be happy to further help you, and if you can please give me a rating it would be greatly appreciated...
Thanks,
Steve
Dec 29, 2008 | Sony Televison & Video
Strong humming sound coming from the over head speakers
are you running a stand alone dvd player or is it built in?check all plugs for sources coming ineg.dvd,vcr,xbox etc,if one is not in all the way,this will cause a hum.
Oct 20, 2008 | Sony DAV-C770 System
Sub
Most amplified sub woofers need to be grounded to the output source.If you plug the sub woofer in to the receiver you would use a ground wire from the receiver to the sub woofer there should be a ground terminal on the sub woofer and receiver.
Feb 17, 2008 | JVC RX-778V
Rca vcr
there a a bunch of different ways. 1) if you don't have a cable box hooked up to this tv,plug the main cable wire into the vcr input then the vcr outout to the tv.2) if you do have a cable box, plug the main cable into the cable box input, then the output to the vcr input, then the vcr output to the tv. put both the tv & vcr on channel 3 for this connection. [ you must have the vcr on channel 3 to record from the cable box!] 3) if you have aux line/video or source inputs on the back of your tv,you can hook up rca cables [ red, white,& yellow ] from the rca outputs on the vcr to the tv inputs.
hope this helps
wg
Feb 04, 2008 | RCA VR637HF VHS VCR
Hooking up Xbox 360 to JVC TV 20 inch 1 year old tv from Luxembourg
change the plug on the back of your xbox 360 from hd to tv unless of course your tv is hd then change it to hd :]
Jan 27, 2008 | JVC TV-20241 20 in. TV/VCR Combo
JVC TH-M505 System Logo
82 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
