Question about Konica Minolta magicolor 2400 Laser Printer
Laser printer i have a 2400w printer and it smears a line across the whole page what is wrong with this do i need a new drum
  • 4 Answers
I developed a color print that has all 4 principal pure toner colors in vertical and horizontal bars that are at least 2" wide.  If perhaps you are having a toner problem only one of the colors will be affected.  If all colors are affected there are two possible issues.  The drum, which I think is actually a belt, and the other the fuser assembly.
The fuser is a heater and pressure roller system that presses and melts toner onto a page.   The drum is an imaging device that picks up toner where images should be and transfers toner onto a piece of paper.  Any toner not transfered from the drum / belt is destined for a waste toner hopper.  If the belt is not being cleaned properly or has an image or flaw artifact that cannot be cleaned / erased you always get that printed on a page.
Posted on Aug 09, 2008
Konica minolta 2400w....lines verticle in all prints...what do i have to replace or clean to fix this problem
check its cartridge if lines are on the drum then replace the drum unit, if drum is clean then replace only the toner.
Apr 16, 2010 | Minolta magicolor 2400W Laser Printer
Konica Minolta 2300W ink smears
check the transfer belt..there is a reason why some used printers are sold on ebay!
be prepared for sticker shot.
Apr 08, 2009 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta Magicolor 2400W drum cartrige-how to replace?
Did you buy a whole new drum unit, or just change the cartridge? If so, the fuse may still be blown. Also, you may need to empty the spent toner out of the old cartridge.
Oct 07, 2008 | Konica Minolta magicolor 2400 Laser...
Konica minolta magicolor 2400w printing proplem
pleas check transfer belt, and drum unit, probably these lines are caused by drum unit and you have to change it. also you can clean laser glass, what is under the drum unit. if both look fine you can also look at the fusing rollers.
May 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Magicolor 2400w Bad print quality and white lines
The solution for the white line problem in the 2400W is to clean the laser lens.
Take out the drum and wipe the laser lens with a soft clean cloth.
Replace drum and carry on.
I had to do it twice before I removed the speck of dirt that was causing this.
Wendy
Feb 21, 2008 | Minolta 2430DL Color Laser Printer
White band on photo glossy output
Open printer, remove drum, clean laser lens with soft dry cloth, reinstall drum.
Manufacturer's Instructions
website: printer.konicaminolta.com
white vertical line (s) / how to clean the laser lens
Cleaning the printer. (5 pages)
Worked for me
Watemusic
Nov 13, 2007 | Minolta magicolor 2400W Laser Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Three broken horizontal lines across all printed pages
sounds like a bad (defective) toner cartridge. You can also try cleaning the corona wire again.
Jun 21, 2007 | HP LaserJet III Printer
Konica Minolta magicolor 2400 Laser Printer Logo
129 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
