Question about Samsung HLN467W 46" Rear Projection HDTV
New Bulb Doesn't Light
I appreciate your help... I had the 'green lamp light blinking' - then recycled three times - then 'all three lights blinking'. I got a new style Philips bulb with adapter from DM - when I put it in it was different - 'only the green lamp light would blink continuously' - no recycle this time? But bulb did not fire up. I called DM - they recommended get a new ballast. I installed the new ballast today - with old or new bulb - it only has 'blinking green light' - no recycling - bulb does not fire up.  What is happening overall: I plug it in, turn it on - I hear a click - fans come on - green light blinks - seems like a very slight speaker 'sound' - with the back access panel removed there is a solid green light on (thru the top of the 'cheese grater' full of holes) - the color wheel is not turning - (all of this while checking with the cover safety switch closed with a rubber band). In order to get the fans to shut down I have to unplug the set - the power button only 'engages' when turning it on? I'm quite good at repairing most things but this is a real puzzle to me. If you have photos of some parts to check I can use a VOM - or any other diagnostic suggestions. How can I tell if it is the power board? Thanks! Bill Robison          oceansalive@mac.com
  • anthony777 Sep 03, 2008
    I have nearly the same problem. Green lamp light blinking and the set turns itself off after about 10 seconds. I have not replaced the bulb or ballast and cannot get a Samsung tech here (Yokosuka, Japan). The Samsung status light diagnostic chart does not include an entry for only the "Lamp" bulb flashing.
    Sergeant:
    Champion:
  • 375 Answers
Color wheel or light engine,call for service and save your money.
Posted on Aug 23, 2008
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
Hi, Our Sony Bravia TV model number KDF E50A11E is not working. There is a red blinking light flashes three times and then goes green and then red blinking again after about 3 seconds. Is this a bulb...
On that particular model I believe there is both a lamp indicator light and then the power indicator light. If it is lamp related the lamp indicator light (LED that looks like a sun in a cup...) would be on.
If the power indicator light is flashing red to green, that is a self diagnostic code, and you will have to contact an authorized Sony repair fascility for them to translate the problem. The error codes are not listed in the user manual, since most are not user serviceable.
Mar 01, 2011 | Sony (XL-2400) Projector Lamp for...
I have a Toshbia 52HM95. It was working fine and
it still could be the lamp, check for cloudiness at the base of the light, if not check to see if the lamp door sensor is making correct contact.if so it could possibly be a lamp ballast
Mar 18, 2010 | Toshiba 52HM95 52" HDTV Projection...
Panason PT-50LC13 TV won't come on, light blinks green then red
Ballast failure is more that likley the problem. Is the lamp light blinking,...once every 5 seconds? Discontinued part and can only be purchased used or rebuilt. Rebuilt units are available, check Ebay. Have a service type person confirm problem before throwing good money after bad!
Jan 03, 2010 | Panasonic PT-50LC13 50" Rear Projection...
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
LG 44SZ8D not turning on
The red light indicates the lamp is burned out. A new one is $100 to $200.
Depending on whether you use the old housing or want to order the lamp and housing together. There are lots of sources for this lamp online.
Once the lamp is replaced, it will be good as new and the lamp will last aprox. 8000 hours.
Apr 06, 2009 | LG DU-62SY20D 62" Rear Projection HDTV
Samsung HLM507W Blink Lights
beings the connectors were different on the new bulb the spark gap maybe different also if it is the lamp wont work in that unit
Apr 12, 2008 | Televison & Video
Samsung HLN467W 46" Rear Projection HDTV Logo
196 people viewed this question
Henry  Thomas
Henry Thomas
