Question about RCA HD52W58 52" TV
RCA 1997 TV - sound not working
The variable output speakers are off, the remote will not let us turn them on so we can get sound. What is wrong?
  • 41 Answers
Check the speaker...for continuity...
Posted on Sep 03, 2008
SOURCE:
I just bought the sharp home theater system ht-sl70/ht-sl75 and I cannot get the volume to be controlled thru my remote. I have a 60 inch sharp aquos tv. It has no arc and when I use the rca connection it...
Hi
I just bought HTSL75 speakers. Its manual saying its volume is controlled by TV's remote control
But i am having Samsung UN46EH6000 LED. and Speakers is connected to LED via RCA and LED is giving fixed output, so all the time, speaker is working on full volume
Is there any workaround, so that i can control volume while using sharp HT-SL75 speakers with Samsung UN46EH6000 ?
Is there any volume control device to control the volume of the speakers in my case ?
Thanks for your help !!
May 09, 2012 | Sharp Audio Players & Recorders
I have an L37HDTV10A that i just replaced the main board...i get picture but no sound...everything looks connected inside...also, what remote do i need?...will a universal work?
Go into ur tv Menu goto OPTION go down to Output Select,press enter make sure selection on (Fixed).This fixed selection will pick for the tv out put to tv speaker.Tv should have sound now on it speakers.Try website like Remotes.com to buy the tv original remote work for the best used for to reajustment setting and setting on the tv Menu.
Jul 29, 2011 | Vizio L37 Television
I purchased wireless speakers and want to know how I hook them up so I can control the volume with the remote
Go to on screen audio setup, turn off the internal TV speakers to OFF, set the audio output to 'VARIABLE' (the audio line out signal at the TV RCA JACKS (RED & WHITE) will be controlled by the TV remote), connect a set of RCA cable from the TV AUDIO LINE OUT to the audio input of the wireless speaker transmittere box and set the volume on the wireless to about 1/2 way, you can change this later. Try it and see.
Dec 17, 2009 | Olevia 237T 37 in. LCD TV
Can i run rca plugs from the tv to my stereo to listen to the tv through the house speakers
Just use the AUDIO line out RCA JACKS, You can also set the audio output to be either variable (controlled by TV Volume control), or FIXED output thenthe volume will be controlled by your stereo remote control, you will probably want to turn off TV buitl-in speakers.
Nov 20, 2009 | Televison & Video
We have the stereo hooked up to the dynex 42'' tv, as we did our other tv, we can not mute the complete sound and also sometimes we cant turn the volume up and down whats going on?
Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
Nov 19, 2009 | Dynex DX-L42-10A 42 in. LCD TV
Use JBL Creature speakers (pc speakers) through tv
There may be a setting in the TV's menu to set fixed or variable output for the rca's. You want variable. Some have two sets of audio outputs for fixed and variable. Depends on the TV. Check those two things. If no help let me know what the TV is and we'll see what we can do.
Jan 25, 2009 | Onkyo TX-SR605 Receiver
Using 2 Pc speakers on my Tv
1)probable incompatibility issue--for comparison did you try a set of headphones? 2)The RCA audio outputs on the tv can go to an amplifier that has speakers attached,ie surround sound. 3)Caution==never try to alter vol level at spkr!
Oct 02, 2007 | Toshiba 27DF46 27" TV
Volume control doesn't work on the enternal speaker
On some sets that have audio output jacks, the level of the audio output on the RCA jacks is fixed, and it does not change with the TV's volume control. On some sets, such as Sony, you can choose fixed or variable output. I have also seen some sets that have both fixed and variable RCA jacks on the back. With variable audio out, the audio level at the audio output jacks follows the TV's volume control. If you go into the TV's menu and navigate to the audio page, look for fixed or variable output options. If you have the owner's manual, read the section on audio output. If variable output is not an option on your model, then the level is constant and the volume will have to be adjusted with the stereo's volume control.
Aug 25, 2007 | Toshiba 27DF46 27" TV
RCA Audio Out not working?
You don't say whether you're successfully getting sound out of your stereo or not. I'll assume for the moment you are. Still getting sound out the TV is perfectly normal - RCA plugs have no mechanism for automatically disconnecting the built in speakers (in this respect, they're different from a headphone socket). Solution should simply be to press the mute button on the TV remote - although this will silence the TV speakers, you wouldn't normally expect it to affect the RCA output (failing that, just turn the TV volume control right down). A.
Apr 21, 2007 | Akai LCT2701TD Television
Audio output jacks
If I remember this tv correctly, check under the audio setting in the menu, most tv's including this on have variable output for the audio o/p. meaning the the o/p vol. is adjusted as the tv speaker vol. changes. some tv's will put out a fixed audio o/p to the rca jacks, but will only do this when the speakers are shut off in the menu (not muted, but off). I have run into this problem many times & have yet to find a better solution to getting a steady sound sound out of the o/p jacks.
Sep 03, 2006 | RCA F36689 36" TV
RCA HD52W58 52" TV Logo
51 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
