Question about Tappan Kitchen Ranges
I HAVE A GLASSS TOP RANGE THATIS NOT A UEAR OLD. i HAVE MARKS ON THE BURNER THAT WILL NOT COME OFF. i HAVE FOLLOWED THE INSTRUCTIONS A TO CLEANERS AND THA MARKS ON THE BURNER ARE A SOLID BLACK, LIKE THE LITTLE DOTS HAVE MERGED AND SOLIDIFIED. i AM SODISSAPOINTED. i HAD HOPED THAT THIS STOVE WOULD BE EASIER TO CLEAN. ANY SUGGESTIONS? NANCY REIF WTRCLR@CTCN.NET
  • wtrclr Aug 04, 2008
    Used the cleaner that cme packaaged with the stove.
    Genius:
  • 1,011 Answers
Dear Sir/madam,
Try baking soda as an abrasive with a damp sponge. Stuff is GREAT for removing stains
Or Else
Try the stain remover Barkeepers Friend. Make a paste from it with a little water and rub gently with a rag until the stain is gone. It is not supposed to scratch. Key- be gentle.
Thanks
Good luck
Posted on Aug 04, 2008
    Guru:
  • 1,894 Answers
What procedure did you follow to clean that?
can you describe the steps you have taken till now.
What is the most reliable pool cleaner for below ground ground pools?
I have tried <a href="http://www.gilbert-pool-service-repair.com">pool repair in Gilbert, AZ</a> and I remember they had some nice cleaners. You could try contacting them.
Sep 29, 2013 | Dolphin Advantage
I just bought a newer "Kenmore" Gas range. my probem is it is set up for natural gas and i use LP gas. Well it came with the LP gas conversion kit. I followed the directions carefully and the range-top...
Remember this: Crank down and flip. You must tighten down all the top and the oven valve orifices and open all the hutters and flip the nut on the regulator. crank down and flip.
Jan 14, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have a Kitchenaid electric range Architect Series II. Seems every time I use the large burner on the right side there is some sort of residue left that is very hard to get off. I have already made a...
What are you using to clean the stove? Only cleaners made for ceran type tops should be used according to directions. Do not use enamel coated pans or glass pans on your cooktop.If you have a boil over, turn off the burner and change to a different burner immediately. Clean up the spill completely before cooking on that burner again. Use a flat edge razor to clean tough residue. Your cooktop will look new for years to come, even with heavy use.
As far as the scratch, don't use abrasive cleaners on the top and only use pots and pans with flat bottoms. If you do use cast iron pans, never scoot them around on the top.
Nov 30, 2009 | KitchenAid KESC307 Electric Kitchen Range
My Whirlpool electric range made a loud electrical popping/cracking noise followed by smoke. Now the indicator light for the left front element is always on. Also when we try to turn on any burner the eft...
Sounds like you have a short in one of your burner switches that may have also taken out your main control. Does your oven work normally? Those error codes are related to 1] control board and 2] oven over temp, so the burner issue is unrelated except in that it may have surged the control.
you can view the switches by removing the rear panel(if this is a freestanding range) and from the description you will likely see the shorted component with some black marks around it. Please unplug the range first,as these wires are live even when all burners are off
Sep 02, 2009 | Kitchen Ranges
Infinite switch sparking!!!!
You have a short somewhere between the switch and the burner connector. Probably a wire's insulation has worn away or melted and is allowing the wire to contact the metal housing somewhere. You will see arc marks wherever the short is located. Look carefully where the wire passes through any holes or where sharp turns are encountered.
Aug 12, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Burners on top will not light with the pilot lights
To Clean:
IMPORTANT:
Before cleaning, make sure all controls are off and
the oven and cooktop are cool. Do not use oven cleaners, bleach
or rust removers.
1. Remove the burner cap from the burner base and clean
according to “General Cleaning” section.
2. Clean the gas tube opening with a damp cloth.
3. Clean clogged burner ports with a straight pin as shown. Do
not enlarge or distort the port. Do not use a wooden
toothpick. If the burner needs to be adjusted, contact a
trained repair specialist.
4. Replace the burner cap, making sure the alignment pins are
properly aligned with the burner cap.
5. Turn on the burner. If the burner does not light, check cap aligment.
May 27, 2009 | Roper FGP300 Gas Kitchen Range
Glass top stove
you can try a flat blade rasor blade, cerama brite smooth top cleaner and some elbow grease
Feb 08, 2008 | Frigidaire FEF366 Electric Kitchen Range
Schott Ceran cooktop on Maytag range
try clr from a local supermarket.it comes in a green plastic bottle.wipe the burner generously but not soaking wet with it and turn the burner on the lowest setting.then use a metal scouring pad and LIGHTLY scour the burner.
Aug 11, 2007 | Maytag MER5775Q Electric Kitchen Range
Kitchen Ranges Logo
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
