Question about Whirlpool Microwave Ovens
My whirlpool microwave is not spinning, nor is it heating the food.
  • Whirlpool Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount, a misaligned door, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Aug 08, 2008
My whirlpool Max microwave has stopped heating up the food. How can I fix it ?
Does the microwave turn on, the plate spins and it counts down time?
If so, and the only issue is that the microwave is not heating you are looking at a High Voltage transformer or a Magnetron. Either parts should only be installed by a service technician, and will cost you $100+ for the repair at most repair shops.
Apr 27, 2015 | Whirlpool Microwave Ovens
Whirlpool microwave have power, not heating up food or water
The problem is most likely the magnetron, or the inverter board, "7years old or less" and possibily the keypad control board.
May 02, 2012 | Whirlpool Microwave Ovens
Whirlpool microwave hood combination won't heat
There are three common issues, the magnetron "heats food" a cracked high voltage diode, a shorted high voltage capacitor.
Mar 10, 2012 | Whirlpool Microwave Ovens
Will not heat
If everything else is working fine, the magnetron is the likely problem, "heats food and is the heart of the microwave oven" if more than five years old cheaper to replace the whole item.
Mar 02, 2012 | Whirlpool Microwave Ovens
Microwave has power but wont heat food
Nothing to do with programing if it doesnt heat you have a bad magnaton or a bad capacator. I work on panasonic microwaves every day.
Sep 27, 2009 | Whirlpool MH7140XF Microwave Oven
Whirlpool MH1150XMB-0 runs but does not heat food
If the housing of the unit isn't too difficult to remove (normally 3-5 Phillips screws around the rear edge), with the unit unplugged of course, check for a user replaceable fuse inside. The magnetron is separately fused and fuses can fail due to metal fatigue. It will be high amperage; 10-20 amperes and many hardware stores will have them. BTW, there is no residual radiation from a magnetron that isn't operating.
Aug 18, 2009 | Whirlpool MH1150XM Convection/Microwave...
Whirlpool mircowave will not heat
HI, the high voltage capacitor is unstable and, it has damaged the Magnetron. you will need to replace the Magnetron. it will run you about $191.30. this will restore the heating action in your microwave unit.
May 27, 2009 | Whirlpool MH6130XEB/Q Microwave Oven
MICROWAVE NOT HEATING
I have the same problem. Everything seems to work except it doesn't heat up food.
I remember last time when it was working. I pressed the start botton before I closed the door. So it didn't start automatically, and I pushed start and it worked(it still heat up the food), but it doesn't work now. Help Please!!!
I have a Whirlpool Gold GH5184XPQ.
Thanks in advance
Aug 27, 2008 | Microwave Ovens
Microwave Ovens Logo
65 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
