I turned my xbox 360 on and and 1 red light started flashing and then a system error page came up
1 red light can mean a number of things, normally a scaler chip error
U GUYS R ****** U DONT NEED 2 PAY FOR BLOODY REPAIR FOR 1 RED LIGHT N E MORE THEY ANNOUNCED YESTERDAY THAT U DONT NEED 2 PAY MONEY 2 FIX 1 RED LIIGHT WITH E74 E71 ECT.
How to fix e74 ebox 360 elite
Normally this is E74 send it in!
1 red light is the lead up to the 3 red lights and you will probably see them soon!
Hope this helps!
1 light is E74
E74 scaler chip
1 red light is E74
Dose the screen some times turn into a pixled mess?
Red Ring of Death: Red Flashing XBOX 360 Lights Explained
Common Xbox 360 Red Ring Errors
The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error,
follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
one red light systems error
The screen either turns into a pixled mess or it has one red ring and then an error report flashes up i have no idea what is wrong and if it is serious or not.
got this too
1 red light bottom right corner
1 red light
1 red light is showing on the 4 line on the 360 and it goes system error but when i take it out it works fine
1 red lights
1 red lights
I WAS PLAY GTA 4 ON XBOX 360 AND IT FROZED I TURNED IT OFF I TURNED IT BACK ON AND IT WAS 1 FLASHING RED LIGHT.
3 lights sometimes 1 is flashing
1 red light :(
1 light for me too!
1 red light sometimes 2
3 red light started with 1 though, bottom right
1 light flashing
bottom right 1 red light
1 red lights for me!
1 light
turn on myu Xbox and i light red flashing and it sais E-74 i dont know what that means
E74
1 red for me
1 light
1 red light
on power up of xbox360 1red light flashing, followed by error message instructing user to contact support centre. tried cycling the power, removed and refitted hard drive with power off. fault remained.
i turned on my 360 and i waited because i thought the controler had to sync but the n the red light popped up in the 3rd section around the power button
1 red
1 light
1 light flashes
1 light
1 red
1 red light
1 red light flashing
1 red lights
1 red
1 red light
3 red sometimes 1 red light
1 red light
1 red light
1 red
1 red light
got this too!
1 light
1 light
yes I have one flashing light, and when I took out the hard drive still my console un-readable disc to all my games I got, But still when I put back on the hard drive there's an error code, and if the hard drive is taken out still can see the stard menu but still won't play any games or even my remote won't work,,it's scary because when I put inside a game there's a funny noise. so please help me out,,cause I just boughted last november2007
1 red light
1 red light
me too 1 red
1 bottom right red light
1 red light
fl;ashing lights error E74
1 red light
1 red
1 red light
i turned off my x box 360 and it instantly went to the system error page and had 1 flashing red light and no longer works.
1 red light for me too!
1 red light error
1 red light
1 red light
1 red light
me too
1 red light
1 red light
1 red
1 red
got this! Damn
1 red light as well
1 red light
1 red light
1 red light
1 red light
I have 1 red flashing light and system error e74 message
1 flashing red light and system error E 74 message
1 red light
1 red
1 red lights
1 red light
2 red lights for me!
there is a flashing red light blinking.
one red light when turned on!
1 red light
1 red light
got this too!
1 red light
1 red light
1 red light
1 red light
1 red light
1 red light
2 red lights
2 red lights
3 red lights
3 red lights
1 red light
freezing up on me
1 red light
1 red light
2 red lights flashing
1 red light on
1 red light
1 red light
2 red lights for me
1 red light
1 red light
1 red
2 red lights
2 red lights on
1 red light
1 light sometimes it comes up with 3!
1 red light
1 red light
On the bottom right corner is one flashing red light, what do I do?
1 red light flasihng on the power display!
1 red light error
1 red light
2 red lights
1 red light
2 red lights
3 red lights
2 red lights
2 red llights on mine!
1 red light
i got 1 red light and i did the towel trick and everything is red
2 red lights on
1 red
1 red light problem
1 red light
2 red lights on
1 light
1 red light
2 red lights sometimes 1
1 red light
the smae is happining with mine . but when i take the av cable out it stops so i bought a new one and still same problem
1 red light
My Son's 360 has the same problem. What can be done to fix the one red light problem?
Damn Microsoft not standing behind their product. One red flashing light (E 74) is not covered under the 3 year "RROD" warranty. Will cost you $99 for them to fix at least, if you are out of your 1 yr warranty that is.
1 red lights
2 red light on mine!
1 red light on mine!
1 red light on
2 red lights
3 red lights
1 red light and freezing
problem with 1 flashing ring of death
2 red lights
2 red lights on!
1 red light
1 red light
2 red lights
1 red light
red light
1 red light
2 red lights
1 red light on power button
1 red light
2 red lights
sitting horizontally its the bottom right
1 red light e 73
