Question about Dell Inspiron 1000 Notebook
Abnormal shutdown, can't restart
I got an error screen that said an error had occurred and to shut down immediately. The only way I could see to shut down was with the power button. On restart attempts it goes to a screen that says unsuccessful startuup has occurred with choices for startup: safe mode, safe mode with networking, safe mode with command prompts. last known configuration, and start windows successfully. All choice go to a blue screen that says a problem detected, windows shutdown to protect damage, Check installation hardware and software (nothing new installed), disable BIOS memory options, use safe mode, F8 to select advanced startup options. I cannot get off this screen. Diagnostic information: Stop:0x000000ED
(0x8132A030, 0x0000006, 0x00000000, 0x00000000). The unit does get hot but I've noticed no increase in heat prior to the problem occurring. I'm working with limited funds, what do I do now, any suggestions?
    Genius:
  • 2,028 Answers
This is going to be one of two things. 1- An operating system error or hard drive failure resulting in operating system error. 2- A component failure or bad/loose connection that is shorting the system and causing the system to think there is an operating system error resulting in a blue screen. First, try to do a system repair with your recovery or operating system disc. If the repair doesn't take, then reformat the hard drive and install a new operating system. If you have any issues during or after the format and install, then the hard drive has failed and will need replaced. If the repair, fresh install, or new hard drive (if you get this far and opt to purchase one) are successful and you get a blue screen to the effect of "detected a problem and had to shutdown, check newly installed hardware" then most likely you have a loose connection inside the machine. You will need to take the machine apart and check all connections. If the connections are good, then you have a failed device somewhere in the machine, and will need to take it in for diagnostics. I know that the latter sounds difficult and rather scary, but I believe that you're going to find this to be a simple operating system glitch or failed hard drive. If you have any other questions feel free to ask, and let me know how the repair turns out.
Posted on Aug 05, 2008
SOURCE:
Tip
Start up error
Some users have gotten an error message similar to the following when attempting either to shutdown or restart Win XP:
STOP 0000009F, DRIVER_POWER_STATE_FAILURE
STOP 0x0000001E: KMODE_EXCEPTION_NOT_HANDLED
STOP 0x000000D1: DRIVER_IRQL_NOT_LESS_OR_EQUAL
TechNet and the Microsoft Knowledge Base have numerous articles discussing this type of error condition; for example, these. As a review of these articles will show, these are commonly device driver problems, but may also be caused by troublesome software (such as the notorious CrashGuard), or a problem in a system service. MSKB article Q262575 discusses a shutdown problem of this type, known to exist in Windows 2000 due to a resource (IRQ) conflict, if you have PACE Interlok anti-piracy software installed. This problem may occur in Windows XP as well.
Microsoft advises the following as one approach to these problems: Restart the computer. Press F8 during the restart and select “Last Known Good Configuration.” If you catch the problem when it first occurs (meaning you likely have installed only one or two drivers or new service), this will return you to a previous working condition. (Would System Restore accomplish the same thing? I don’t know, and don’t have a broken system to test it on.)
Microsoft reported similarly that these STOP code error message occur when Windows XP is trying to shut down devices. He says that he has seen this twice: once with Logitech Quickcam installed (with an unsupported driver), and once with a USB DSL modem that would hang if it wasn’t disconnected before shutdown.
on Jan 01, 2010 | Computers & Internet
How do I shut off my computer? L670 series
Normal shutdown: Click on Start button (lower left corner on most PC screens), and then select shutdown.
Abnormal shutdown: If computer is "frozen" and you can't click on Start button, press and hold the power on/off button until the computer shuts down.
Jan 24, 2011 | Toshiba Computers & Internet
Due to c00002la fatal system error problem I am unable to shut down.
Shut down your PC by pressing restart button then immediately shutdown button, Next time when you start your PC, press F8 during startup before the window logo comes up, and choose "last configuration that worked". If the last known good configuration does not work you may have to reinstall the operating system. Visit this link to resolve this error.
Thanks..!!
Nov 26, 2010 | Computers & Internet
Cannot read disk
"A disk read error occured press Ctrl+Alt+del to restart " FOLLOW THE BELOW INSTRUCTIONS TO RUN DELL DIAGNOSTIC ON INTERNAL HDD Open the Dell Diagnostics on either your hard drive (F12) or from the Resource (Drivers and Utilities) CD. Running from the hard drive is the preferred method of using the diagnostics. If problems occur when running from the hard drive or there is no Utility Partition, the diagnostics can be run from Resource (Drivers and Utility) CD. From your hard drive: Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. When the boot device list appears, highlight ?Boot to Utility Partition? on desktop systems or ?Diagnostics? on portable systems and press . Note: On portable systems, PSA will be executed first. When PSA completes, press any key to load the Dell Diagnostics.? Go to step 2. NOTE: If you receive a message stating that no Diagnostics utility partition has been found, follow the instructions on the screen to run the Dell Diagnostics from your Resource (Drivers and Utilities) CD. From the Drivers and Utilities CD ResourceCD: Insert the Drivers and Utilities CD into the CD drive. Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. NOTE: This feature changes the boot sequence for one time only. On the next start-up, the computer boots according to the devices specified in the system setup program. When the boot device list appears, highlight IDE CD-ROM and press . Select Boot from CD-ROM option from the CD boot menu. Select Run the 32 Bit Dell Diagnostics numbered list. If multiple versions are listed, select the version appropriate for your platform. Go to Step 2. After the Dell Diagnostics loads, the Main Menu appears. Click the button of the option you want. If a problem is encountered during a test, a message will display the error code and a description of the problem. Write down the error code and problem description and follow the instructions on the screen. If you can not resolve the error condition, contact Dell. If you run a test from the Custom Test or Symptom Tree option, click the tabs above the right window for more information: When the tests are completed, if you are running the Dell Diagnostics from the Drivers and Utilities CD, remove the Drivers and Utilities CD. Close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and restart the computer, close the Main Menu screen. Regards Sunil Dsouza
Dec 04, 2009 | Dell Dimension 2400 PC Desktop
Starts, runs a few seconds then shuts down. Will restart immediately, but then shuts down again. 32.5 KW, White diesel eng.
Check for a low lube oil sensor problem first. Could be low oil pressure or a failed sensor. The sensor is timed and if pressure doesn't come up, then unit is shutdown.
Check fuel filter and also air leaks in the fuel supply lines.
Check if the fuel shutoff solenoid is responsible for the shutdown. If it closes just before the engine quits, then it is being commanded to shutdown, probably as a safety interlock.
Oct 11, 2009 | Kohler Electrical Supplies
Computer will not re-boot
your hard drive has been corrupted due to improper shutdown
Oct 07, 2009 | Dell Dimension 3100 PC Desktop
Computer restarts on shutdown
If your computer constantly restarts while you are using it, or if you are trying to shut down the computer after it has stopped unexpectedly, click to clear the Automatically restart check box. If you clear this check box, you receive an error message when the computer stops responding. This error message may describe the cause of the problem. You can also review the system log in Event Viewer to view the critical stop error that occurs when the computer restarts.
  1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Startup and Recovery.
  2. Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
Thanks & Regards
Nandu :)
Mar 25, 2009 | MSI Computers & Internet
For solving blue screen error
HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
Description
Windows XP may not start and the following error message may appear on a blue screen:
This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
Solution
If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
use the link to know how to use recovery option with hp laptop
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&dlc=en&product=18703&docname=c00608578#
_____________________________________________________
Thanks and Regard
dilipbagdi
Technical Associate
May 18, 2008 | HP Pavilion dv9000z Notebook
Problem while pc shutdown and startup
unplug it from the wall for 10 sec. and then plug it back in and restart.
Mar 15, 2008 | Computers & Internet
Dell Inspiron 1000 Notebook Logo
190 people viewed this question
Ekse
Clive
Clive
