Maybe is you should provide the brand and model or you unspecified printer, could findyou the manual, if available.
You can llok for it too, search google with terma
manual, brand ans model
Hi there. . . okay . . . Follow this step 1.) Unplug your printer. 2.) Plug your printer again while holding the menu button 15 sec. 3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK 4.) then numbers appear looks like this ###:### ###:###. 5.) now push the MONO button until the purge:#### appears on the LCD 6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok 7.) - switch off the printer ,switch it on - ready to print - CHEERS! email me if I helped you. . [email protected]
good day! Unable to print 50 means'' the machine does not work due to paper jam or some sensor...mostly unable to print 50 is sensor problem. to clear the problem clean the sensor, and then the mechanical...t
my printer doesnt work, what do i need to do so that i can use my printer again,pls kindly give me the information, it always said that go to the maintenance and routine maintenance chapter. i have no any idea on that device, pls!!! thanks!!!
