Question about HP PSC 1610 All-In-One InkJet Printer
Copier problem my copier will work but will not copy,i have tried all settings but when the copy comes out,there are nothing but white and black lines
    Novelist:
    Scholar:
  • 111 Answers
HP.com has a few web pages that might help. One is a general troubleshooting page that you can review and the other specifically addresses the issue of "white lines" in a copy:
Troubleshooting Copying Issues
White Lines Through Copies
Read through both web pages and see if there's a suggestion that will help solve your problem. Good luck.
Posted on Oct 14, 2008
I experienced horizontal white lines copy on my fs1135 mfp could anyone had an idea? . pls. help me with this experts
This normally means you have issues with your laser or developer. I would try changing developer first.
Feb 03, 2015 | Kyocera Mita FS1135MFP Black Toner...
Black lines coming out on top of copies
3 things it could be. Easy 1st! run a copy using auto doc feeder and then run off the glass. If you only have a line after document feeer then it is somting on the small scan glass. If it is on both most likly you need a new drum. Or your fixing film in your fusing unit is bad. Pulling the drum unit is not to bad but a tech might be needed.
Jun 09, 2010 | Canon imageRUNNER 3230 Black and White...
The screen says the Paten glass needs to be cleaned. What is the paten glass? Also when copies are made a black line is showing up on the edge of the copy.
paten glass is the copy board glass.try cleaning both side,if still same.it can be off in additional funtion [copy board glass sign.turn it to off ]
Mar 17, 2010 | Canon imageRUNNER 1023iF Black and White...
Cannon Image Runner 1023iF will not send or re: a fax
First try to check your fax settings.Your 'line settings' has to be set to 'tone' and not "pulse".
Set your fax mode for "fax only"
And try again.
Jan 20, 2009 | Canon imageRUNNER 1023iF Black and White...
White line and very, very dirty copies
the nealy black copies sounds like the drum is going, try adjusting the exposure to light, if it comes out with the whole page the same way but just lighter than change drum. White line sounds like there is something on the coronas.
Jul 22, 2008 | Canon PC-940 Black and White Copier
Canon np7130 copier
Most likely when you make a copy you don't see the light scanning the paper, you can try this with the lid open to make sure. the Sacnning lamp is blown, need to replace
Jul 14, 2008 | Canon NP 7130 Black and White Copier
THE COPIES COME OUT ALL SMUDGED WITH INK WHAT'S WRONG.
Hello
in your printer fuser has went bad, just replace toner if its almost empy and fuser and that will take care of it.
Thankyou
May 15, 2008 | Toshiba 1370 Black and White Copier
Copying spreadsheets
If the lines look like little steps, maybe broken is segments off by about the thickness of a pencil line, try this. Most likely it's the scanner. You can try calabrating it by doing the following. press in order. Menu #1934. You will see a T pop up to the right side of "Ready to Copy". Then press machine status, then scroll until you find maintenance. May be under system settings. When you find maintenance, press enter, then scroll to Shading Adjustment. Or depending on software version, Adjust shading. Place 5 sheets of paper on the glass,, press enter, then when is says "Adjust Shading?" press enter again. Let it print out the sheet. Then try a copy. If that doesn't help, the scanner itself will probably need replacing.
The scanner is the issue. The segments of what is called the CCD are not working properly.
Once you adjust shading, if that doesn't work, the scanner will need to be replaced.
Feb 28, 2008 | Xerox CopyCentre C20 Black and White...
Cannot print in color on HP OfficeJet 9110 All-in-One
Nothing to do with the driver, I'd say the cartridges are your problem, skipping lines and missing colour are indications of needing new ink carts, are carts new HP ones?
Jan 19, 2008 | HP Officejet 9110 All-In-One InkJet...
HP PSC 1610 All-In-One InkJet Printer Logo
100 people viewed this question
Seeker5211
Seeker5211
