Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Hcn4226w samsung recently moved. Worked fine for a day or two. Now only get a red "oval" on the screen. Any suggestions? Thanks in advance!
  • Anonymous Aug 09, 2008
    IDENTICAL PROBLEM 3 ARCS OF COLOUR AT BASE OF SCREEN APPARENTLEY A GLOBE IN THESE BURST AND THE ACID FROM THE BOARD WEEPS ALL OVER THE BOARDS EATING AND CORODING ALL THE LITTLE BITS AND PIECES INSIDE
    NOT A HAPPY CAMPER THINK I'LL GIVE SAMSUNG A BY BALL IN FUTURE
    HEATHER NORTHERN IRELAND
    Novelist:
  • 132 Answers
The most common problem with all 3 tube rear projectors is a damaged convergence circuit. The Samsung TVs are easier to repair than many others and the numbers that break down is not excessive. For every Samsung with a convergence problem there are a large number that did not breakdown. The fault is caused by bumps or noise in the AC power, not the TV design. This usually produces colored outlines around heads, etc.
Check out the Convergence Gallery. If you see the colored outlines or color shading as in the Gallery, you have a convergence problem.
This requires the replacement of the defective IC or ICs and any damaged or smoked resistors. Usually there is little alignment required after the repair. If you play with all the adjustments before the fix, hours may be spent re-aligning.
Don't monkey with it.
This is a delicate and difficult repair. If not done by someone with some electronic repair experience, the TV will likely end up as junk or cost considerably more for a tech to fix the damage done.
If you live in Calgary, call me. If elsewhere, find a competent tech.
easyab
Posted on Sep 15, 2008
No color!
we had this exact same issue with our Samsung projection tv. We solved the problem (temporarily) by trading in the cable box for a new one. All colors worked for a while, now the red goes on and off at will... I think we may have had a problem with the cable box AND the tv. Maybe this will help?? Good luck!
Mar 11, 2009 | Samsung HCN4226W 42" Rear Projection...
Sound went out
Please help ! I moved my Samsung hcn4226w and reconnected. The picture is fine but, no sound now and cannot use all functions on the remote. Any suggestions would be great. Thanks.
Jun 29, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W Rear Projection TV
You can get the convergence board by clicking here.
The service manual you might buy it from the same place.
May 23, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W blue color outlines
Samsung parts for convergance problem
http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
This convergence board works with the following Samsung television models: HCM4215W, HCN529WX, HCN559WX/XAA, PCN5425R, HCN4226WX, HCN529WX/XA
Mar 10, 2008 | Samsung HCN4226W 42" Rear Projection...
I think I have a convergence problem but looking through solutions I have become confused Help?
to tell which board you have there should be writing on the corner of the board in white.
Jan 27, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W yello stain around the screen
Its a problem with the screen, Plasma depends upon a chemical and eletrical impluses to create a display... I think you might just want to change the screen.
Jan 10, 2008 | Samsung HCN4226W 42" Rear Projection...
Convergence issues?
most likely the convergence board.
Ordered complete convergence board, ask samsung for part number Convergence AMP PCB $108.44, from www.samsungparts.com
or could send it in to ptscorp.com for repair.
Dec 23, 2007 | Samsung HCN4226W 42" Rear Projection...
Red line fault
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Aug 07, 2007 | Samsung HCN4226W 42" Rear Projection...
Convergence problem?
That board, P/N Bp94-00155a should fix the problem and be fairly easy to replace. Make sure you unplug the TV before starting the repair though. Duh!
Mar 11, 2007 | Samsung HCN4226W 42" Rear Projection...
RED Ghost Image on Samsung 42" Rear projection HDTV (Model - HCN4226W)
I WOULD RATHER THINK IT IS ONE OF THE CINVERGENCE AMPLIFIER & DRIVER IC,S A REAR PROJECTION TV NORMALY HAS 2 OF THEM AND THEY ARE THE SAME AND NORMALLY THE NUMBER ON THE IC STARTS WITH "STR *****" SWAPING THE TWO AROUND WOULD PROVE THAT YOU GOT A PROBLEM ON ONE OF THEM,THEN JUST GET 2 NEW IC'C THE SYMPTOM THAT YOU ARE DESCRYBING IS MOST LIKELY THE IC'S HOPE THIS HELPS IGNATIUS ,SOUTH AFRICA TV REPAIR ENGINEER
Feb 20, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
Henry  Thomas
Henry Thomas
