Spin Cycle on Wash Machine does not work
Washes great though
Kenmore top load washer about 8 years old washer filled with water ok...agitated ok... but would not spin to drain the water...I just hand emptied the tub and now looking for a self fix, instead of Sears service $$$.
  • Anonymous Mar 13, 2014
    Washer won't spin, clicks when it tries, but fills/empties water OK. Broken coupler?
  • 5,911 Answers
The problem is your lid switch. This is a common problem with this model washer, and a very simple & inexpensive problem to fix. Click on the following link for advice on how to replace:
http://www.fixya.com/support/r385198-replacing_lid_switch
You can find a replacment switch at searspartsdirect.com. Just type in your model number and look under the "Cabinet Parts" heading on the next page. I believe thats the heading the part is listed under. Sears has excellent part locator drawings to assist you in identifying the part. Once you have the part number identified, you can do some comparative shopping at other online websites too. Use the part number that Sears provides, however. A new switch usually runs about $25 to $35. In addition, make sure you check the lid strike. This is a small plastic piece on the lid that is used to activate the lid switch through a small slot. If the lid strike is broken off, it will give the same symptoms of a defective lid switch. I hope this information helps you. Please post back if you have any questions.
Posted on Aug 04, 2008
  • Jeff Rockwell
    Jeff Rockwell Aug 04, 2008
    PS You do not have to drain the wash tub in order to complete this repair. Once the lid switch is repaired, the tub will drain. You can also by-pass the lid switch as a temporary "fix" until your part arrives. I would not recommend using the washer in this fashion, long term, because the tub will not stop spinning or agitating when the lid is opened. This is a safety feature of the washer. To bypass:
    1. First of all, UNPLUG the washer!
    2. Disconnect the lid switch connector as described in the link provided.
    3. Remove the lid switch assembly from under the washer casing as described in the link. There are two mounting screws along the lid opening and one ground wire holding it in place.
    4. With the lid switch assembly removed, cut the connector plug off leaving about 2 to 3 inches of wire.
    5. Cut the green (ground) wire off the connector (not needed) and splice the two black wires back together using wire lugs or a crimped splice.
    6. You have now created a jumper plug. Plug this jumper back into the lid switch connector on the timer, and your lid switch is now by-passed.
    Again, do not use the washer long term in this fashion, and do not run the washer with the exterior case removed.
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series fills with water but would not agitate or spin
You have a problem with the motor coupling. Top-load washers use what's called a direct-drive system, meaning it does not use a belt but what's called a "motor coupling". I probably replace 5 a week because these little guys break because of 2 reasons that i've found.
1) The break mechanism is too dry and causing the basket to stop at a holt, which puts a lot of strain on the coupler.
2) They break because of over-loading. I don't think you're over-loading though because it was find for 5 straight years.
Good luck to you. The repair is kind of hard to do on your own for the first time, so I would call an authorized technician. It will run you anywhere between $90 to $120 at most.
Best of luck!
Jul 14, 2009 | Kenmore 22422 Top Load Washer
We just purchased a top load Kenmore 800 washer machine. We have washed 2 loads of clothes and Now it has stopped filling up with water. It will not do it to wash or to rinse. We have gone thru the mannual...
The first thing seems to be the timer,or the water level switch. Try filling the washer with water by hand, if it starts to agitate after being filled its the timer, if not it is the water level switch, let me know if you need further assistance.
Mar 13, 2009 | Washing Machines
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore wash machine will not spin
Eight years is getting kind of old. When the clutch or transmission goes out, it costs more to replace the part than to buy a new washing machine. You'd better plan a shopping trip rather than spring for that $100.
Aug 02, 2008 | Kenmore 22422 Top Load Washer
Kenmore 80 series washer
Your transmission is not engaging thats why the speed changes your making will sometimes get it to work.Honestly any machine after the 10 year age mark is not worth the cost of replacing the transmission.
Apr 15, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
461 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
