Question about Xerox Phaser 8400 Laser Printer
What is error "Fault 37,016,43:30997
Any ideas on what this error refers to or how to fix it? Any help is much appreciated.
    Novelist:
  • Xerox Expert
  • 297 Answers
AC power supplied by power sources such as uninterruptible power supplies (UPS’s) or DC-to-AC inverter systems, may not supply enough current to properly power up the printer. In these cases, the printer may report printhead jet-stack or reservoir heater disconnect, drum heater, or preheater errors (37,002.47 thru 37,012.48). Verify the AC power source prior to troubleshooting a printer exhibiting any of these errors.
(Plug printer directly into a wall outlet)
If this doesn't solve the problem you will need the preheater replaced.
Posted on Jan 17, 2009
Hi, getting error fault on water system. Any ideas how to fix, manual says refer to service engineer???
NO as we do not know the make,model,year of what you have .could be fluid level , thermostat or the pump itself .
Jan 27, 2016 | Cars & Trucks
How do I fix error code P0744, )730,0736, 0602
0602 refers to the Engine Control Module ,either faulty , needs reprogramming,or wrong ECM which unless you've had it changed recently it will be one of the first two .The other codes all refer to the transmission and Powertrain Control Module , the only thing that can be done within a reasonable budget is to have the transmission fluid changed . The other causes are going to cost depending on what may be the fault if changing the fluid did'nt help, sorry not good news as there are no easy fix's to these type's of problems. Best advice get a diagnosis from a transmission specialist although as you've mentioned $1500 you probably have already.These OBD codes are only an indicator of which sensor/switch may be at fault so upto you if you try the fluid change as could only be around $100-$150 at most,otherwise may be better to change car in good luck
May 21, 2014 | 2005 Chevrolet Equinox LT
Fisher and Paykel Aquasmart
250. (11111010) SmartPump Loss Of Sync
This fault is normally as a result of the pump not starting. This fault is usually caused by an
object that has gotten into the pump, and is either under or on top of the impeller, which is
causing the motor to stall when it is trying to start.
Primary Source: Pump Stator Windings Open Circuit.
Action: Measure the resistances of the pump stator. For more information
refer to the AquaSmart service manual.
Secondary Source: Pump System.
Action: Follow procedures as for Fault Code 249.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Apr 27, 2013 | Fisher and Paykel WA37T26G Top Load Washer
How to fix error code 19 on honda civic dx 1993 5 speed
Error code 19 on a Honda civic refers to AT lock up system malfunction causes ---Lock up control system. Have the code item repaired first and the second fault may be fixed also.
Apr 20, 2013 | Honda Cars & Trucks
Fault code 1600
code 1600 refers to throttle position (TP) sensor-communication error. Cause wiring---poor connection---TP sensor---ESP control module---ECM
code 1000 refers to barometric pressure (BARO) sensor --signal high. Cause---wiring short to positive---BARO sensor.
Apr 08, 2013 | 2008 Volvo S40 2.4
Egr fault code p0401
Hi there:
In fixing this code, it is quite common for people to just replace the EGR valve only to have the OBD code return. The EGR valve is not always the culprit.
  • Use a vacuum pump and pull the EGR valve open while monitoring engine RPM's & DPFE voltage. There should be a noticable difference in RPM's with the EGR open
  • Clean out the EGR valve and/or tubing to remove deposits
  • Check the voltage at the DPFE, compare to specified values (refer to a repair manual for your specific model)
  • Replace the DPFE sensor (with a good quality / OEM one)
  • Replace the EGR valve
Hope this helps.
Dec 06, 2012 | Cars & Trucks
E000001-0001 fault codemany ideas?? thanks
E00004-0001 is fixing unit error. Need model# for more specific repair. More than likely needs fixing unit to be replaced.
Jul 09, 2010 | Canon Office Equipment & Supplies
Xerox Phaser 8400 Laser Printer Logo
251 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
