Question about Goodman CLQ36AR49 Air Conditioner
Goodman h/p not cooling
Everything starts and runs condenser and attic blower. lines are not getting hot, and can't hear movement of the refrigerant in the lines like i usually have. the house lights are dimming acting like something is trying to start on it periodically. the digital tstat middle button is green, but now there's a yellow light next to it on the right. any clues.
sandtx2@verizon.net
  • Anonymous Aug 16, 2008
    condensing unit stops for 2 or 3 seconds then restarts
Whle your fans are running, chances are good your compressor isn't. One line (the smaller one) should get warm to hot and the larger line should feel cool or cold. If that's not the case there is a good chance the compressor isn't running. OR it's low on freon.
Posted on Aug 04, 2008
My air conditioner froze up. We turned it off over night and cleaned the evaporator and condenser now it doesn't cool at all.
is the outside unit running? may have got something wet have someone turn it to cool while your at outside unit see if it's starting up. one line should be warm the other cool.
Jun 18, 2014 | Goodman Heating & Cooling
Food has started to thaw. power and power light are on. Compresser is running and warm/hot. cool air is felt at the vents inside unit, but there is no airflow. Shouldn't there be a fan/blower blowing...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 05, 2011 | Refrigerators
The goodman air conditioning unit will randomly turn on and run for a few minites then turn off. The blower fan does not run just the unit in the attic. Any advice?
Hi, not enough detail not enough detail. I have no idea where you are located, but if it is a gas heater/ Ac then maybe the attic space is so hot that the over temperature sensor is turning the unit on in an attempt to cool the system down. If however it is a refrigerant AC unit, I would suggest that the control circuit is faulty, maybe a sticking contact somewhere. good hunting col
Feb 24, 2011 | Heating & Cooling
I have a kemore coldspot side by side maufacture date 04/07 that is not cooling properly. Freezer gets cold but won't freeze and fridge section gets cool. I have checked condenser fan runs and compressor...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Oct 24, 2010 | Kenmore 53642 / 53644 Side by Side...
UNIT RUNS BUT WANT COOL BELOW 50 DEGREES... COMPRESSOR IS RUNNING AND COLD LINE COLD ,HIGH PRESSURE LINE HOT BUT WILL NOT COOL BELOW 50 DEGREES.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 15, 2010 | Haier HSB03 Compact Refrigerator
A/c is blowing but it is not cool air will freon
Hi, so you have a central air split system, with the gas furnace in the attic and the condenser outdoors. Unless you had a service tech out and told you your system was shot, you more then likely just have a problem with the outdoor unit. Yes, it may be a freon problem and it needs a charge, or some minor problem in one of the electrical circuits not bringing on the compressor so there would be no cooling. $6,000 sounds about right for a complete system, but I don't believe at all that's what you need. If you are familar with electrical, or you are able to go to the outdoor unit to see if you can hear the compressor running, and the outdoor fan is on, this is the place to start. Look it over, turn the unit on and make sure the blower is coming on in the attic. If so, make sure the outdoor unit is up and running. You can take off a panel and hear the compressor to see if it is on. If so, its very possible it is just low on freon. You will have 2- copper lines coming out of this unit. Place your hand on the large line and see if it is nice and cold and even wet, condensation. The smaller line will be much warmer, even hot if its running ok. If you find that the compressor is on and the line is warm, sounds like it may just be a leak and you should call and get a tech out to check this for you. It may be many things, but check to make sure that what I have told you is ok, and keep me posted. Until we find out what is going on, don't let them tell you you need to install a complete system. I am sure you were just checking. Please give me the model and serial number, and name of the outdoor unit if you would be so kind. And the age and over all condition that you think it may be in, like the last time it was serviced. I will wait to hear back from you, so we can get this up and running.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Jul 28, 2010 | Whirlwind FH-778 Air Conditioner
I had my a/c charged today because it has not been cooling the house down. It took less than a pound, but it still blows worm air. Fan and compressor all running. I cleaned outside unit, filters, replaced...
It could be that it is not charged correctly. Check the insulated copper
line outside if it is sweating and the condensor is discharging hot air, then the ac is doing all that it can. Check the evaporator inside to see
if the drain has condensate coming out of it.
Getting the heat out of the attic is a good idea, but you must have enough make-up air in the attic for the fan. If you do not have enough
make up air, it will start to draw air from inside the house. One way to check this is if you have a gas water heater and or furnace. If you put
a flame by the exhaust pipe in the basement and it blows it out, then you now have a backdraft problem.
Run the AC withoutthe fan, my real guess is the unit is not properly
charged or you do not have a big enough AC unit.
Jul 17, 2010 | Goodman CKL36AR36 Air Conditioner
I have a GMPN080 horizontal gas furnace in attic of my home. What is the purpose/function of the drain trap assembly in furnace. Cooling coil is external to furnace?? Please advise, looks as if someone has...
The reason for the trap is to compensate for the negative pressure the drain line is under. Since the blower is pulling the air, if the trap wasn't there, then the drain wouldn't drain properly.
By having a trap, your blower is pulling air back through the trap while the condensate water is allowed to flow and drain.
With that being said, if you have water forming in your emergency pan, its an indication that the main drain line is clogged up. If you know where the drain line exits the home, take a small shop van and vacuum out the drain line. If its really backed up, it will sound like a golf ball through a garden hose.
If your trap has a clean-out installed, I would recommend pouring some hot water and bleach combination down the trap itself after you have cleared and flushed the drain. The bleach will assist in killing any mold/mildew that has accumulated in the drain.
Also, while your in your attic, ensure your emergency pan has a float switch and that its operating properly.
Jan 11, 2010 | Goodman Heating & Cooling
Goodman compressor cuts off when temp too high
I believe you have 1 of 2 problems going on here your system may be overcharged causing the compressor to cut out on a overload relay circuit internally, or it also could be tripping out a high pressure switch which could be from an overcharged system or a dirty condenser. I would have the tech come out on a 90 degree day and put the gauges on and check the pressures while it is operating under a full load.
Hope this helps you.
Please rate me
Jul 19, 2008 | Goodman CLQ36AR49 Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
80 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
