Question about Whirlpool Dryers
My compact dryer, Model LEW0050PQ 2 will not power up when the On/Off button is depressed nor does the red power on light come on or the aural beep sound indicating that the unit is ready to engage the Start button. I've covered the obvious, plug and circuit breaker, and have 240 at the plug. It appears to be a faulty On/Off switch. Do you agree? How hard is it to gain access and replace the switch? Thanks, Truman Berry tberry2@alltel.net
After removing the dryer from on top of the washer, I found it was easy to expose the back of the control panel containing the Power On/Off switch. A quick check of the switch's continuity confirmed the bad switch. However, after reinstalling the switch connectors and plugging the dryer back in, the switch started working. It appears the problem is intermitant.
While the internals of the dryer were exposed, I also checked the door switch (which was good) and sprayed electrical contact cleaner on all of the switches and vacuumed out the dust and reassembled the dryer (which is now working) and ordered a new Power On/Off switch so I will have it when the switch mis-behaves the next time.
The most difficult part was removing the dryer from on top of the washer where both units are built in to a wall of cabinets.
Truman Berry
Posted on Aug 05, 2008
Tip
How to fix your PS3 when it's frozen at startup
1.The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
2.Put your PS3 in Standby Mode.
For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back in.
3.Time to enter Safe Mode.Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
4.Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
5.Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
6.Select option number 3, (Restore File System). Then select yes to perform step.
7.You will then see this screen. "The hard disk's file system is corrupt and will be restored."
8.First press the PS button to turn the controller back on. Then press the x button and it will restore, it will then restart and your problem is fixed!
on Apr 02, 2010 | Video Game Consoles & Games
My controls locked button light is on, pressing cycle button for 3 seconds does not turn it off. any other suggestions? thanks
Unplug the unit from the wall for 2 min's then plug back in and depress the lock button and hold until the beep or light shuts off. Sometimes it will take more than just 3 sec's and sometimes as long a 20 sec's,
Apr 02, 2011 | Kenmore 87562 Dryer
Re: LEW0050PQ The dryer does not power up. Is it a switch problem?
How new is the dryer? Is the door latching? Check the main electrical breaker for the dryer.
Feb 12, 2011 | Whirlpool LEW0050P Electric Dryer
Greeting From Alaska. I have a dryer Model # LEW0050PQ S/N# CAR4502402 that will not heat. The first indication that there was a problem was that the dryer would not shut off when you open the door. It...
either your element is bad,also you could have the neutral wire on the element burned off which will leave you with 240volts across element,you do need the neutral to make elements heat also ckk for 120/240 volts at dryer
Jul 13, 2009 | Whirlpool LEW0050P Electric Dryer
When I push start it beeps 3 times. Lights on the right work, lights on the far left don't light up.
Alright, pretty unconventional, but simple and Genius on my part!!! Not sure if we're talking about the same models, but I was cruising this site with the same problem.... K, so it's making three beeps right? Check inside the DRYER (maybe same issue w/ washer, I dunno), but there's a button on the top-inside.... DEPRESS THAT BUTTON, and while holding it down, START THE DRYER (HOLD TO START), if it starts working, this tip is for you!
1) on the opposite side, where the door depresses that same button on the dryer door... you ready for this... see step two ;)
2) SUPER GLUE A PENNY IN THAT INDENTATION PART, your problem is there's not enough connection, and the door is no longer holding that same button down...
3) TA DAH!! Since a repair guy could've charged ya like 50+ bucks, I'll take... emmm.. 25$, email me at Kumatrev@yahoo.com on where to send the check, or just shoot me an email to say thanks ;)
May 29, 2009 | Kenmore Elite HE4 Electric Dryer
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
May 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
Dryers Logo
602 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
