Question about Samsung Prostar DCS Phone
Pro Star DCS 24 B
Unit has jumped one day ahead even though the day date and time are correct. Is there a way to shut off the night mode ?
  • rod5 Aug 05, 2008
    Thank for getting back...actually the problem is with the Samsung Star Mail system...On Saturday the system thought it was Sunday so the phones did not ring, only the flashing green light on the phone panel lit up...before this started we had several power outages on the same day...the phone is correct and works fine during the week, only the last 2 Saturdays is when we have had the problem. We unpluged the Star Mail box to allow customers to leave messages and the green light to flash...
  • 3 Answers
SYSTEM ADMINISTRATOR
PROGRAMMING
SET DATE AND TIME DISPLAY Should it become necessary to correct the date and time displayed on all of the keysets, due of time change (twice a year), you must first access the customer programs.
To access customer programs, open system programming using the passcode you have been assigned. (Default passcode is 1234). You must use a (display phone) LCD 12B or LCD 24B keyset. ENABLE CUSTOMER PROGRAMMING Pro Star DCS 24 B - topbul1a.gif While on-hook, press TRSF and dial 200. he display shows. ENABLE CUS. PROG.
PASSCODE
: topbul1a.gif Dial the four digit passcode. The display shows: ENABLE CUS. PROG.
DISABLE
topbul1a.gif Dial 1 or press the ▲ on the Volume to enable. The display shows: ENABLE CUS. PROG.
ENABLE
Press TRSF. The keyset returns to its idle condition.
The display format is the following:
W (Day of the week): Enter 0 for Sunday and 6 for Saturday.
MM (Month): Enter 01 for January and 12 for December.
DD (Day of the month): Enter a number in the range of 01-31
YY (Year): Enter the last two digits of the year.
HH (Hours): Use the 24 hour clock and enter a number in the range of 00-24.
MM (Minutes): Enter a number in the range of 00-59.
SETTING THE DATE AND TIME 1. Press TRSF and then dial the 505. The display shows: OLD: 1102802:0852
NEW: WMMDDYY:HHMM
2. Enter the new time and date using the above format: OLD: 1102802:0852
NEW: 1102802:0752
3. Verify the time and date and reenter them if necessary OLD: 1102802:0752
NEW: WMMDDYY:HHMM
4. Press TRSF to store and exit programming.
If you have entered invalid data, you will receive an [INVALID ENTRY] message for three seconds. Reenter the correct date and time. If the information you entered is incorrect, repeat steps 1 through 4.
Posted on Sep 10, 2008
    Scholar:
  • 108 Answers
The Prostar can be programmed from any display phone, press #, display reads " PROGRAMMING ", dial 5 5, YY MM DD W HH MM is displayed, enter two digit YEAR, MONTH, DAY, DAY of WEEK ( 1 = MONDAY, 2 = TUESDAY ) HOUR and MINUTES MUST be in 24 hour clock ( 1:00 PM is 1300 ), enter # to exit. Since you did not specify which system you have, only the phone type, I have assumed and based my answer on a Prostar 816. If you have one of the newer systems please repost with ths type of phone system and I'll be able to help you with the night button as well.
Posted on Aug 05, 2008
The night time video doesnt work and the screen is black. It works fine during the day. Not sure what has happened to the night time mode. Even when plugged into the ac adapter the screen is still black...
It sounds like the Infrared LED are not on (there are 8 of them on the fornt of the unit), it should automatically turns on when it senses dark scene. You can find out at night using the digital camera pointing at the LEDs, you should see white glow on your digital camera.
The problem can be caused by the power supply that supplies the power the LED assemblies or the detector circuits that suppose to turn on the LED when the surrounding area is dark has failed.
Jun 24, 2011 | Summer Infant Additonal Camera for Video...
Change 12 to 24 hr & date
Hi bobwesley,
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Nov 17, 2010 | Timex 1440 Nylon watch
How do I switch from 24 hour time to 12 hour time?
Hi greg780,
Hope it helps.
Oct 12, 2009 | Timex 1440 Nylon watch
Timex 1440 time from 24 hour clock to 12 hour
Hi bowingman,
Hope it helps.
Oct 09, 2009 | Timex 1440 Nylon watch
How do I set the time and date for the fax on my Xerox Phaser 3200MFP
From xerox.com support for Phaser 3200
NOTE: If the printer has been powered OFF for a long period of time, the date and time may need to be reset when the printer is powered back ON.
  1. Press the [Menu] button on the Control Panel until 'Machine Setup' is displayed on the top line of the Display Screen.
  2. Press the [Left] or [Right] arrow button on the Control Panel until 'Date and Time' is displayed.
  3. Press the [Enter] button on the Control Panel.
  4. Refer to the table below to enter the current date and time using the numeric keypad.
    Unit
    Range
    Month
    01 - 12
    Day
    01 - 31
    Year
    four digits required
    Hour
    01 - 12 (12-hour mode)
    00-23 (24-hour mode)
    Minute
    00 - 59
    NOTE: By default, the clock mode is set to the 12-hour mode; however, the clock mode can be modified to the 24-hour mode. See the Related Items below for additional information.
    Press the [*] or [#] button on the numeric keypad to select 'AM' or 'PM' for the 12-hour mode.
    If a mistake is made, press the [Left] or [Right] arrow button to move the cursor under the digit to be modified, and then enter the correct digit using the numeric keypad.
  5. When the date and time are correct, press the [Enter] button.
  6. Press the [Stop / Clear] button on the Control Panel to return to the Standby mode.
Jul 29, 2009 | Xerox Phaser 3200MFPB Multifunction...
The date changes at 12 in the evening
The watch is set-up for a 24 hour cycle. It sounds like your watch is 12 hours late, so if you just advance the time 12 hours ahead, everything should be solved.
May 23, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
How to change the voice mail message on KP DCS - 24B LCD samsung
I have the manual for the DCS series and there is no help regarding this.
It does say how to turn from auto to manual and make sure that the time is correct.
1. If the manual NIGHT key is pressed BEFORE the system automatically enters night service then the automatic night service timer tables will be overriden until the system is manually restored to day mode.
2. If AFTER the system automatically enters the night service tables and will not be overriden.
Nov 17, 2008 | Samsung Prostar DCS-24B-LCD Corded Phone
Set time and date
hit the feature button (gray, looks like a globe on it) under the display, under the 3 gray buttons in a row.
then **8463
password is 23646
follow prompts :)
hit the hang up (phone with arrow underneath) when fone.
Jan 22, 2008 | Lands Phones
Samsung Prostar DCS Phone Logo
252 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
