Question about E-Mu 1820M Sound Card
E-MU 1820m J've got problem with E-MU Digital Audio System (E-MU 1820M, Seria NR: M1EM8840446001046M). There is I think a small problem, because one of the output ( MONITOR OUT 4 RIGHT ) have got too small signal in campare to the others . I'm electronic and I have tried repaired this E-mu system. I think I've found problem in to the main board, becouse SMD transistor Q35 is damaged. There is ( 6K ) symbol on this SMD transistor . I found three symbols 6K transistor in to the catalog code of transistors SMD : ( MMBF4932, MUN2133, MUN5133 ). Can somebody of service engineer tell me please, which of this transistors must be use to repaire this output ? Stanislaw Strzelecki Torun Poland [email protected]
  • Anonymous Nov 26, 2008
    I used to see in Thailand.
    Pinij
    I used to see 2N4932 and 2N4933 in Thailand, I'll check them again tomorrow.
Pinij
Posted on Nov 26, 2008
SOURCE:
Is my e-mu 1820 work with my accer cpu
Simple answer: Yes, provided that you have a free PCI slot in your Acer. The E-MU 1010 PCI controller board is the only controller that will work with an 1820. The PCIe version will not work an one or both may be damaged if you try.
Do not expect to get anything close to good latency from an old computer. If your Acer is a P4 or an equivalent AMD or newer you should be fine.
Jan 22, 2013 | E-Mu 1820M Sound Card
E-MU 1820m recording isue
restore your machine,and do installation of ur E MU soundcar.d again
Sep 13, 2012 | E-Mu 1820M Sound Card
Can the EMU 1212m work with the EMU 1820m Audiodock?
If I remember correctly you'll have to choose between the 1212-board and the 1820m-dock. The internal 1212-board is not needed if you have an 1820 and, as the line inputs/outputs on the 1212 appears as DockA/B and line 1 R/L on the 1820.
Dec 18, 2010 | E-Mu EDI Cable Sound Card
Crackling sound on boot up. goes away after a while
Crackling sounds are from poor connections. As the system warms up, the heat causes expansion and the crackling stops. You should remove and reseat the board in its slot, remove and reseat all connections between the board and the speakers, mics, etc. and restart. The sounds should have stopped - or been reduced considerably.
Please rate this reply - good luck!
Aug 09, 2010 | E-Mu 1820M Sound Card
No lights on dock, dock doesn't start
Replace the Mlan cable supplied with the EMU 1820M with a regular short length CAT 5 Network Cable - It is an unresolved power issue - this sorted my problem out.
Just remember to keep it away from sources of electrical interference.
Sep 16, 2009 | E-Mu 1820M Sound Card
Bought a new computer with PCIe slots without realizing they aren't compatible with PCI soundcards, so my E-mu 1820m sound card does not fit. Are there adapters that will solve my problem? If so, how much...
even if your motherboards does have PCI-e slots it will still have 3 standard pci slots. So have another look there will be a slot for your sound card as in my experience and knowledge i have nether seen a motherboard with out a pci slot.
Aug 19, 2009 | E-Mu 1820M (054651066717) Analog to...
Pops and clicks in recording audio mix
when mixing... using wave plugins?( Koolwater)
Mar 18, 2008 | E-Mu 1820M Sound Card
E-Mu 1820M Sound Card Logo
528 people viewed this question
Top E-Mu Computers & Internet Experts
Marvin
Marvin
Alun Cox
Ben Armstrong
Are you an E-Mu Computer and Internet Expert? Answer questions, earn points and help others
