Question about Samsung HLR5688W 56" Rear Projection HDTV
SAMSUNG DLP SCREEN
SCREEN WENT 1/2 BLACK WHEN TURNED ON..IS THIS A LIGHT ENGINE ISSUE? HOW LONG TO FIX?
  • caddy_1 Dec 18, 2008
    I HAVE THE SAME PROBLEM HALF PICTURE HALF BLACK BUT ONLY AFTER RUNNING FOR ABOUT 2 HRS
    I think my hlr5688w only has one bulb, maybe dmd board?
    Problem Solver:
  • 11 Answers
Sounds like one of the Bulbs has burnt out. This is a very easy problem to fix. You just have to remove the back panel of the TV and replace the bulb on the side that has gone black.
The bulbs can be purchased directly from the dealer. (And are rather pricey)
BEFORE purchasing the bulb...I would first make sure that the current bulb has not become loose. Try reseeding the bulb and see if it will function correctly.
Posted on Aug 04, 2008
I was playing Fallout 3 and after a while, my screen turned a bit darker, not really dark but as if there is a light shadow on it and after a few seconds it turned black. I tried to press twice on the...
try shining a torch/flash light on the screen
If, when the flashlight is on the monitor, the problem is fixed then you have aback light issue.
You will have to contact your manufacture or shop you bought it from
Mar 04, 2011 | ViewSonic VX1940w LCD Monitor
Our Hitachi Plasma TV suddenly went black and the indicator light started to flash green. We turned it off at the wall and back on. The screen flashed green, went black again and the indicator light...
If you want it fixed, you'll have to take it to a real tech. If you read this garbage you'll probably end up spending more that the tv is worthed in the long run to fix it.
Nov 02, 2010 | Televison & Video
My ps3 turned off in the middle of a game and now it wont turn on?
there are also 2 SOLUTION
OPTION 1
You can contact Sony for a repair/replace.
Wait time: 4 - 6 weeks
Price:
in warranty $0
Out of warranty $150/$200
OPTION 2
You can repair the error by your self with the help of lightsfix repair guide.
Price: $37
You can find a great PS3 lightsfix guide Right here
That's everything you need to get this problem
like :
Inside this digital all-in-one set you will learn: check.jpg How to permanently fix the Blinking Yellow Light of Death (YLOD) check.jpg How to permanently fix the Solid/flashing Red Light check.jpg How to permanently fix the Flashing Green Light issue check.jpg How to permanently fix the 3 beeps issue check.jpg How to permanently fix the Red Screen check.jpg How to permanently fix the Black Screen of Death check.jpg How to permanently fix a Freezing Screen (during game-play or during the menu)
check.jpg How to permanently fix the HDMI issue on your PS3 check.jpg How to permanently fix the DNS error issue on your PS3 check.jpg How to permanently fix the No Power issue on your PS3 check.jpg How to permanently fix the Audio problem on your PS3 check.jpg How to permanently fix your PS3 Controllers
and good luck
Oct 18, 2010 | Sony Playstation 3 (PS3) Console
Black screen
how many times does the red light flash?
Techman
May 16, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Dimension e310- Black screen when powering on, 1 & 2 lights blink
Generally, the 1 and 2 Diagnostic LEDs indicate a failure of a PCI expansion card.
http://support.dell.com/support/edocs/systems/dim3100/en/sm/adtshoot.htm#wp1130520
So remove any expansion cards, see if anything changes. If it does, one of the PCI cards is suspect.
If the system has an expansion video card in the PCI-E slot, and removing the PCI cards had no effect, remove the PCI-E video card and connect to the intergrated video port (You may have to remove a black cover from the port) and see if you get video. If you do, then the Expansion video card has failed.
Nov 21, 2009 | Dell Computers & Internet
My Gateway t1625 laptop turned on the other day then the screen went completely black. I turned it off and took out the battery for a while and it went all the way to the sign in page before it turned...
Could be many different things
1. loose ram chip
2. failing video card
3. video driver error
4. failing screen
You can send it to the following company for diagnosis and repair. Fill out the form and be sure to include an email address
http://taeckertindustries.com/prod04.htm
Nov 16, 2009 | Gateway T-1625 Notebook
I have a 56" DLP Samsung (HLR5668W) Right side goes solid black
The color wheels will never fix an issue like that. The only things that will cause that issue is a bad DMD board which is part of the light engine or the digital board which is not. Freak Squad need to replace the digital board.
Sep 10, 2009 | Samsung HL-R5668W 56" HDTV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Touch screen's going black.
Your back light for your ds and sp may have went out, unfortunately it is impossible to fix a lcd screen with the black light going out other than buying a new screen and installing it. Sorry.
Aug 22, 2007 | Nintendo DS Lite Console
TV went to black screen
I had the same issue. The screen would shrink and then expand over and over. After thrity minutes it would correct itself.
After a few months of doing this it just broke - no sound and no videe but the power light was still on.
I searched these forums but did not find clear instructions or kits on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.
To help others I documented the fix and created a repair kit and step by step quide on how to fix the problem. You can find it here. http://www.magnavoxhelp.com
Aug 02, 2006 | Philips 9P6040C 60" Rear Projection...
Samsung HLR5688W 56" Rear Projection HDTV Logo
295 people viewed this question
Henry  Thomas
Henry Thomas
