Question about Zanussi 24 in. ZSF6150 Free-standing Dishwasher
Zanussi jetstream dishwasher zfs 6161
When turning on the dishwasher every 2 minutes it appears to go on hold.
On the display I get the following message
i (flashing) 10
together with light over the cycle slected flashing.
Can you please help.
Thnaks
John
5 Suggested Answers
SOURCE:
  • 1142 Answers
SOURCE: Zanussi ZSF 6161 Dishwasher error codes
Did you try a hard reset
Posted on Jun 24, 2008
SOURCE: Zanussi ZSF 6161 Dishwasher with Error 30 Code
The light cover on the side is loose causing it to flood remove the side and tighten the light cover the tilt the dishwasher to get water out of the float tray. let the dishwasher dry out and you should be grand
Posted on Sep 06, 2009
Hi ya, Zanussi dishwasher zsf 6161 error i30. I tilted it back, mopped up. Used dishwasher cleaners, cleaned around door, filters but it happened again. Any ideas?
Posted on Aug 13, 2010
SOURCE: I have a Zanussi Electrolux Jetsystem Progress ZSF
I have a Zanussi Jetsystem Progress ZSF 6161 Dishwasher stops after a few seconds and flashes -30 Any ideas? thanks!
Posted on Jun 23, 2011
Spin only on Zanussi Jetstream 1400
no agitation check timer and control board. but more likely culprit is the water pressure switch. Which determines water level and when machine goes into agitation mode?
Sep 26, 2014 | Zanussi Washing Machines
Replace bulb zsf6161
see your instruction manual, and go to the section troubleshooting.
however is very simple, unplug the power and proceed taking the first wire and make note for color wiring, and replace.
If you do not i.manual download from www. retrevo.com
God bless you
Jun 18, 2012 | Zanussi Dishwashers
Warning C 08 how to reset?
Hold down on/off and prog 2 for 5 sec.
display ``fac``
Press prog 2 until display ``ron``
Press prog 3 until ``c8 / 1 or c8/3.``
Press prog 1 until ``c8/0``
Press prog 3 until ``ron ``
switch off -switch on and o.k.
General
C8 caused from glogged jets or rinse pump problem or bad luck.
If there is a problem at the dishwasher then c8 will appear again
Hope I helped you
kostas
Jan 26, 2011 | Zanussi 24 in. LS6E Free-standing...
I have a Zanussi Electrolux Jetsystem Progress ZSF 6161 Dishwasher which, no matter what programme I use, stops after 2 seconds and a -10 flashes.
Jul 28, 2009 | Zanussi Dishwashers
Mar 22, 2008 | Dishwashers
i have got an zanussi des 959 and showing falt code 5 could u help me out
Jan 19, 2008 | Dishwashers
Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
Dec 30, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi 24 in. ZSF6150 Free-standing Dishwasher Logo
206 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
