Question about Sharp Microwave Ovens
Sharp r957, turntable has stopped - Sharp Microwave Ovens
  • Sharp Master
  • 9,098 Answers
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
Info on ordering Sharp UK parts / spares is here.
Posted on Aug 08, 2008
No turntable for sharp R-1870
The turntable motor will need to be replaced, a common issue with most brands.
Apr 21, 2012 | Sharp R-1870 Convection/Microwave Oven
My Sharp Microwave R-1460A make load noises when turntable is on. Noises stop when turntable is turned off.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 11, 2011 | Sharp R-1460 Microwave Oven
Sharp R957(W)M jet convection oven and grill. Trips the elcetric when I open the door? Any ideas please?
Check the door interlock switches and contamination around the lower switch.
Jan 23, 2011 | Microwave Ovens
My Sharp R957 turntable seems to be sticking. I've cleaned under the turntable and the support but it doesn't seem better. If I give it a push it works for a bit then slows down again.
Replacement of the turntable motor should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The motor assembly is fixed to the base of the oven usually with two screws and access is obtained usually by removing the inspection plate directly beneath the motor. It is usually a plug in synchronous motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate, sometimes it must be cut out with sharp cutters, and disconnect the motor. Remove the motor and go and get a new one. Fit the new motor and fit the inspection cover back on the base by turning it to fit and using an extra screw fix it then put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Jan 16, 2011 | Sharp Microwave Ovens
Turntable stop working along with microwave and convection oven
would be a door micro-swtch sharp part # Sharp Part Number: QSW-MA085WRE0
Jan 07, 2009 | Sharp R-1405 / R-140 Microwave Oven
Faulty microwave function on the SHARP R-957 model (900watt)
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 10, 2008 | Sharp R-930AK Convection/Microwave Oven
Trying to find a synchronous motor for model r957. because my motor as gone pleased if you could help thanks nad
Sounds like the turntable motor or perhaps the damper motor?
Aug 10, 2008 | Sharp Microwave Ovens
R957 cooks for 59 seconds then stops ,resumes for 59 seconds if cook /start pressed all cooking modes affected kitchen timer works ok
You can probably find exploded views and order parts by entering your model number here at the Sears parts site. The best place to order Sharp parts is Tritronics.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 31, 2008 | Microwave Ovens
Sharp Covection Oven/Microwave stops after 1min on any setting
This 59-second stop failure is due to a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller thinks that the door is not in the right position, it will shut down the cook cycle.
See the attached sample photo.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We even have a video on our site that shows you how to safely & easily remove the control panel assembly to send it for service.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 08, 2008 | Sharp R-963 Convection/Microwave Oven
Microwave Ovens Logo
189 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
