Question about Stanton STR8-100 Turntable
High level buzzing
My Station str8-100 started emitting a high level buzz to point that its clipping. Did my tone arm go? What is this?
  • orb1tal Feb 13, 2009
    I have the same problem. Sounds like its clipping and seems to happen only with loud pieces of vinyl. certainly as if the gain is too high. I have tried changing the rca's, and the stylis. This had made no difference. I cant imagine what's inside the tone arm that could cause this?
  • Anonymous May 10, 2009
    There is no ground canle on these decks
  • 515 Answers
Only the following 3 things could cause this:
1) Tonearm
2) RCA Cables / RCA connectors
3) Cartridge/Styli
Make sure your ground cable is also connected.
- Davis
DJ Pro Audio
www.DJPROLAB.com
www.DJPROAUDIO.com
Posted on Aug 08, 2008
Yamaha YSP 800 Digital Sound Projector constantly emits a low buzzing noise (even on mute). My only remedy to drown out this interference is by ramping up the volume, which sometimes actually fixes the...
Do you have any other nearby devices that emit radio frequencies like a wireless router or a cell phone? I have had issues with buzzing on some of my speakers when my cellphone was nearby.
Oct 15, 2013 | Audio Players & Recorders
Realistic pro-62 scanner emits high frequency buzzing noise after half hour or so of being switched on?
There is a problem with something breaking down in power supply side. It could be a filter capacitor or a semiconductor.
Apr 18, 2013 | Radio Communications
I have a Boston Acoustics VR-500 Subwoofer with a problem. As soon as anything is plugged into the line level RCA jacks, the subwoofer produces a loud buzz/hum. I have tried connecting it to the subwoofer...
I'm thinking you have an open shield ground on the RCA input side. Connecting speaker inputs possibly restores the ground. Try connecting the high level inputs then disconnect the remote end of the cables (floating the grounds).
Then get out an ohmmeter and find that open circuitor or bad solder joint between RCA ground and real ground in the speaker's amplifier. Or.... if speaker ground kills the hum and you want to use RCA Line Level input to the sub, just connect one minus speaker output on your source amp to one minus on the sub's amp.
Mar 01, 2011 | Audio Players & Recorders
I have had a rather disoncerting lw level buzzing
I had the same after about 15 months. It seems to happen when charging the iPOD. I took it back to John Lewis, it was returned to B&W and came back repaired 8 working days later. I was very pleased with the service. As an added bonus B&W restarted the 2 yr guarantee.
Jul 27, 2010 | B&W Bowers and Wilkins Zeppelin iPod Music...
ION iTTUSB turntable has buzzing sound when I record
It sounds like you have a bad ground on the tone arm. It's probably time to replace the tone arm wiring, or the external connecting cables.
Nov 28, 2009 | ION Audio iTTUSB Turntable
Subwoofer Emits a Buzzing Tone
The 2200 uF capacitor in the power supply has gone bad and the humming is a 60 Hz from the rectification of AC to 18 vDC.  Either get a new power supply or take apart the power supply and replace the bad cap.
Mar 16, 2009 | Altec Lansing AVS 500 Computer Speakers
Buzzing tone. Can barely hear caller's voice because of the buzz
Two things to look at:
First, check the base station isn't too close to some interfering item of electronic equipment - try moving it to see if the problem diminishes.
Second, unplug the cordless phone and put a traditional corded phone in instead (if you don't have one lying around, it would be a wise investment to get one, otherwise you'll be without a phone service if your power goes out). If the buzz is still there, the problem lies with your line rather than with the phone (and that's the TelCo's problem, not yours).
A.
Nov 28, 2008 | Uniden Cordless Phone
Audio fuzzy or cuts out
Could have a loose connection in the audio section or a problem with the output IC . Also does this happen on the RF input and your A/V inputs or just one of these. If its the A/V inputs only your having this problem check your cables .
Nov 26, 2007 | RCA HD61LPW165 61" Projection HDTV
Stanton STR8-100 Turntable Logo
195 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
