Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
Intellifax 4750e won't grab paper for outgoing faxes
Hi..I presume that perhaps the feed rollers are getting worn, but, would appreciated some feedback on a solution, recently we are having some frustration with the machine not grabbing the paper when we are attempting to feed documents for outgoing faxes.
Thanks, I'll look forward to your ideas.
Ani
Macro-Pro.
  • wjefferson Feb 11, 2009
    My Brother IntelliFax 4750e won't grab the paper in the paper tray anymore. The message reads "change drum soon". So I bought a new drum and that still doesn't help. Once the copy goes through, I can hear the machine trying to grab the paper, as it squeeks. Any ideas how to fix this? Or could it be the drum - as I bought a refurbished one. HELP!!
  • 215 Answers
Like the other solution says, try cleaning your feed roller, and last but not least, make sure the rear paper stopper in your paper cassette is not pressed up against paper tightly. best to leave about 1/8' gap.
hth,
razors
Posted on Feb 18, 2009
    Genius:
  • 2,120 Answers
Clean the rollers and rubber pad with alcohol.
Posted on Oct 26, 2008
We have a Brother intellifax 4750e. When we send a fax, there is a black streak down the right hand side of the paper. When we receive a fax, the streak is not there. The streak is about 1" wide. ...
Try cleaning the rollers with rubbing alcohol using a good quality paper towels, I find there is a buildup on the rollers causing streaking on the paper. If that fails the print head must be suspect.
Dec 30, 2010 | Brother Office Equipment & Supplies
Multiple pages
Actually, when you get more than one paper feeding in at a time, it is almost always the separation pad being worn down. Go here to buy a new sep. pad and tell them Ken from National Cartridge Co. sent you there!
http://www.precisionroller.com/paper-feed-components-for-brother-intellifax-5750e/details_9248.html
May 28, 2010 | Brother IntelliFAX 5750e Laser Fax
Fax feeder is pulling sheets through at the same time
Sounds like the separation pads in the paper tray are worn out. You can contact Brother and purchase the parts from them. It should be less than $10. as long as the paper is being pulled from the tray it sounds like the rollers are okay.
Oct 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Fax machine is not pulling paper for printing.
Atypically this indicates one of three problems.
  1. the nip rollers have become oily and traction for the paper to feed does not exist
  2. the nip rollers on the paper feed spindles are worn and are not grabbing the paper.
  3. the gear teeth in the sprocket of the feed spindle are damaged (broken)
In case one some manufactures provide utility kits with paper that has a rough surface to which you can condition the rollers (kinda like a sand paper)
In case two and three (above) these items will need to be replaced. This is not a job for a novice and given the return on investment ... you may be better off buying a new machine.
Oct 06, 2009 | Brother IntelliFax-2820 Laser Fax
Brother copier paper feed grabs 2-5 sheets at a
check the feeed rollers ateh seperation roller the one that seperates the pages is worn.. it has proberly worn the tread and if its sn=mooth or worn it wont stop multi feed
Jul 29, 2009 | Office Equipment & Supplies
Broken paper guide and difficult fax input.
Lets start with the paper feed problem. You need a new paper feed roller to pull the paper in when it should. You need a new seperation pad to prevent multiple pages from being fed at the same time. you will have to look at your machine to determine which parts are needed. here is a link to a company that I do business with. You can find the trays here also.
http://www.precisionroller.com/manufacturers/brother-intellifax-4750e.html
May 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
We have a Brother FAX-1840c. It will jam feeding paper into the scanner. I maintenance mode it returns an A1 error code. Feed rollers look serviceable and the pressure pad is clean. Stops half way thru...
Hi
There must be some torn paper or something stuck in the Paper feed. You will need to ope the upper face portion by pulling it, and then look for papers/ dirt / pins there, you can either clean it by blowing air or use a blower, or if you can see the particle. Try feeding the paper, it should be ok.
Jan 27, 2009 | Brother IntelliFAX 1840C Plain Paper...
Outgoing fax makes loud clicking noise
2 different problems here. 1st is with document feed and 2 is with paper feed.
1st prob seems to be with the paper feed roller not meshing at the gear. Probably a broken piece on the lower document tray assembly. No real fix for this unless you can strip it out and haywire it.
2nd prob is probably a poorly meshing drum unit. Examine the gear teeth on both the drum and the machine. As you have replaced the drum already (presumably with a brand new one) You might possibly find a missing or badly worn tooth on the messhing gear in the machine.
Oct 02, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
247 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
