Question about Photography
Streaks I shot a roll of 200 the other day when it was slightly overcast and got yellow streaks going horizontally across the middle of my shots. This only happened on the last 6 or 8 pictures on the roll. Is this a film issue or did something happen to my camera?
  • 667 Answers
You may have a bad light seal on the film door. Try checking uscamera.com for replacements
Posted on Aug 08, 2008
Television is a Tosiba DLP 72HM195
your tv needs a y-load board its like a grafix card as computers have due to overheating the board components are affected this is a manufacturing fault it tends to happen with samsung aswell
Feb 22, 2012 | Toshiba 72HM195 72" HDTV
I have long yellow streaks on copies.
Hi, Sounds like the yellow PCU is faulty, pressuming the streaks are vertically down the page.
If they are horizontally across the page it is probably another issue.
Nov 02, 2010 | Ricoh Aficio SP C410DN Laser Printer
CRT TV with only a horizontal line through the center of screen.
Yeah. Unfortunately you are right. It is normally the ic that controlls power to the gun. And it is expensive.
Your only chance is to find another model of the same TV that some is ready to trash or throw away at low cost and that TV having some other defect. Advertise in the local newspaper or other channels. It is worth a shot.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 23, 2010 | Sanyo Televison & Video
35mm film developed with streaks
I take it the streak is a hot streak of light. If you're shooting negative, look at the negative and see if it's one long streak. If so the light leak could be anywhere between the film roll and the take up roll. I would open up the back, go into a closet and shine a bright light on the front of the camera and see if you can find the leak and tape it up. Otherwise, 35mm SLR's are very cheap these days. I'd recommend a Canon A-1 for your daughter, but you can't go wrong with any Canon or Nikon.
Sep 03, 2009 | Photography
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
May 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Colors are distorting e.g. Blue streak across top of viewing field
unfortunately not. the discoloration is caused by the light filter getting fried due to excessive dust and heat. and you cannot purchase the parts individually. you'll have to replace the entire optical engine.
Sep 03, 2008 | ASK Proxima C420 Multimedia Projector
Blue streaks across picture
Can you describe in a little more detail what the symptoms are? Are the streaks thin lines or are they large thick swashes of Blue? Is yur video still visible? Sounds like it may be the blue convergence amps or the resistor tied into the amps. is there anyway you can post a picture of your screen distortion?
Jan 26, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Horizontal streaks on pages
Streaks at 2.82 inch intervals: Horizontal marks at this interval are the result of a mark on the fusing roller of the printer. In some cases, these marks can be cleared up by running a cleaning page through the unit. Laser Printer Cleaning sheets can be purchased at your local printer/office supply store. If the marks persist, this can indicate a more serious problem with the fusing roller that would require service attention.
Streaks at 3.74 inch intervals: Horizontal marks at this interval are the result of a mark on the image drum of the printer. There is no way to repair a damaged photosensitive image drum, so in the case that it is scratched or otherwise damaged, the entire CRU (toner/drum cartridge) would require replacement to clear up these marks.
Dec 03, 2007 | GCC Technologies Elite 12/1200N Laser...
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Unable to focus camera.
The common cause of lines across the picture is a stuck shutter. This will cause over exposed pictures, out of focus, with lines across them. If the problem is infact a stuck shutter it will require full disassembly to fix, which will be somewhere between $100 and $200 to fix depending on where you send it. An image sensor failure, or focus motor failure can also cause simular problems - but they also cost simular amounts to fix. David Millier Advance Camera Repair
Mar 10, 2007 | Sony Cyber-Shot DSC-T1 Digital Camera
Photography Logo
89 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Tony
Are you a Photography Expert? Answer questions, earn points and help others
