Question about Frigidaire CWS3600AS Top Load Washer
Washing machine clogged with dirt
The water company installed a new water meter and dirt backed up all water lines to the house including washing machine, now the washing machine is clogged with dirt, a small amount of water will trickle out.
  • 5,911 Answers
You probably have sediment clogged in the inlet hoses and/or screens in the water inlet valve of the washer. First, turn off your water taps in the back of the washer. Disconnect the hoses one at a time and insert them in the wash tub. Turn the water taps back on to see if you are getting water through the lines. If not, you will need to remove the hoses and flush them out. If the hoses appear fine, inspect the sediment screens on your water inlet valve (this is where the hoses connect to). You can use cotton swabs to remove most sediment. If you cannot get the screens to clear and/or if sediment has gotten inside the water inlet valve, you will probably have to replace it. Try flushing the lines and cleaning the sediment screens, first, though. I hope this helps you.
Posted on Aug 04, 2008
There is a water leak in the water meter. Who is responsible for sorting this out?
up and including the meter , it is the responsibility of the utility company
after the meter it is your respobsibility
Sep 22, 2017 | Washing Machines
Can you tell me how much water a Lemair XQB22 uses per wash
Hi, depending on where you live (such as an apartment, house, or the kind of water company you have. The easiest thing to do, I would think, would be to make sure nothing in your house is using water. Check your water meter, run your washing machine, then go back out and see the difference on your meter. Depending on your washer, different "soil" levels will use more or less water. Hope this helped
May 04, 2011 | Washing Machines
Hi my washing machine samsung WA10U3 top load. After wash always filter check. Why?
because the function of filter is to block the small particles or dirty things including grease or oil etc., before disposing the water, and to avoid the clogging of floor drain and even sewage line. And after you used it you should check the filter if theres a some dirt, and grease or oil to clean up to avoid clogging and unclean water from your washing machine
Feb 06, 2011 | Samsung SW62ASP Top Load Washer
My washing machine is displaying the letters "nd",
ND is no drain error code for the FAV6800A and most Maytag machines.
Is there water in the Wash Basket. If not this could be a stuck Pressure Switch. If there is water in the Wash Basket then there could be a Drain Pump issue/Drain Line clog.
If you want to DIY I can help you.
Feb 05, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Water was turned off to house to fix a plumbing problem. now the washing machine will not work. the water will not pass through the hoses.
take your lines off and check your screens in the back of the water inlet valve,, then with the hoses off hold them in a bucket and turn them on, this will get rid of all the dirt and things in the lines,, the screens will be where your hoses hook up on the back of the unit
Jan 25, 2011 | GE WSXH208A Front Load Washer
Display says error
I have give the same solution in other post, here it is :
usually problem with semi auto washing machine is on the sensors , exactly in the water level sensor, please check the hose that connected to water level sensor, make sure no dirt blocking or clogging the hose. also you can clean the tube under the pulsator, usually there is many dirt blocking the hose line.
the problem is in the hose leading to the water level sensor, if there is no dirt and looks normal, water level sensor must be replaced
Jul 24, 2010 | LG WM2487H Front Load Washer
I have an old Kenmore washing machine. Model#
It's coming from something deteriorating in your water heater,there were some heaters out there that had a thermostat housing that was breaking down and doing what you describe.check with the company that made it,they may still be doing repairs on them for free.
Sep 21, 2009 | Washing Machines
Leaking under ground pipe what water company says..........cant find a leak . grounds not wet any where no water under the house .how can i find the leak with out a plumber? cant afford one....lol
this sounds like a joint is leaking just but not enough for the water to surface try digging the main line from the meter to the house be careful not to damage any lines under the ground and mind any gas and electric lines. once you find the water line out of the meter trace it to the house as soon as you start digging into mud your gitting close to the leak. once found remove dirt so that repairs can be made
Dec 12, 2008 | Plumbing
Whrilpool washing machine will not fill
May I first suggest that you turn both the hot and cold water off to your washer and check the screens installed in the back of the machine. A lot of times dirt and debris can clog the supply lines. After you check the supply lines, turn the water on with the hoses in a bucket. This will make sure that you are getting water to the machine. Replace the lines, and turn the supplies back on. If you are still not getting any water, you are looking at a bad water solenoid.
Jul 15, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Water leak
your drain pipe is clogged up, going to drain- Duh
Jan 13, 2008 | Aprilaire 550 Humidifier
Frigidaire CWS3600AS Top Load Washer Logo
308 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
