Air Conditioner Model @AR-DL10
My remote will not come on. I have changed the batteries and it still will not come on. I cannot turn my AC off. Please call immediately.Thank you
  • FREDSAL Aug 05, 2008
    remote wont shut down unit
    SHUT DOWN UNIT @ FUSE BOX FOR 10-15 SECONDS-SAME PROBLEM
  • Anonymous Sep 07, 2008
    remot
Open the slide cover and pull the batteries out. Next press the ACL button on the remote and make sure the ABCD slide is on A
Posted on Jul 18, 2010
I have a model AR-DL10 remote. One of the batteries corroded , installed new ones and now the unit will not respond. What should I do?
Pull the new batteries and clean the terminals. If cleaning don't work the corrosion may have damaged the remote. Use a PC of sand paper, or scratch the surface that the batteries touch.
Aug 12, 2015 | Heating & Cooling
Digitech ar 1731 Air conditioner remote. I need code for Fujitsu AC Model AST12LSBCW please
Fujitsu Air Con codes for the Digitech AR1731 Universal Remote Control for Air Conditioners are:-
1152
0464
0127-0137
Dec 12, 2013 | Televison & Video
Where can I find a new remote AR-DL10
Hi gdpotter,
Here's the LINK for the original remote control.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jul 29, 2011 | Fujitsu 24C1 Air Conditioner
I am looking for a replacement remote for my air conditioner model Number AR-JW1 its a fujitsu
dear sir
please use blow link and further information about fujistu air conditioner in near of your area dealer for find out your aircon remote:
http://www.fujitsugeneral.com.au/find-dealer/dealer-search.php
thank you
hope answer the question
please vote!
Sep 30, 2010 | Fujitsu 24C1 Air Conditioner
After I changed the battery of the remote the AC will not respond. I have to turn on the AC manually. T
dear sir
please turn off the switch of air con and after two minut turn on, your main electric soures for reset the settings then it will show to you on it,s display Green light. it is sign of power supply after that you can use your remote control with your air con,
thank you
please vote!
Sep 25, 2010 | Fujitsu 24C1 Air Conditioner
Fujitsu remote control Model AR-DL10. I need to change the batteries. I can pull the slide down to expose the set/ swing/ energy save, but I think I have to pull it further down to get to the batteries. ...
How to get to the batteries in a AR-DL 10 Model Fujitsu Remote Control/ A/C
Pull it down to expose the controls inside.
To pull it down further to expose the batteries: PINCH BOTH SIDES OF THE slider at the top where it is knurled so it will bow out a little bit in the center AT the same time you may need to
slide an object under the slider to help it bow up a litter further.
WHILE DOING THIS: pull the slider further to expose the batteries. There are two plastic stops that the slider must clear to pull it down enough to get the new batteries placed. Before putting it back together: File down the two stops with a nail file so it is easier to do next time. - Who engineered this?
Sep 11, 2010 | Fujitsu (FPCRC04AR) Remote Control
Remote unit slides open but cant find battery cover-model AR-DL10
When sliding the bottom part of the remote down, you have to lift it slightly (I did this with a letter opener - very carefully) to pry the door up from two stops that normally prevent the dorr from sliding down too far. If you look carefully, you can see what I mean.
Feb 04, 2009 | Fujitsu 24C1 Air Conditioner
Wall Hung A/C unit remote control # AR-DL10 batteries died last. Replaced remote batteries with 4 new duracell batteries. Unit came back on but running to warm. I tried to figure out the programming of the...
I just got onto a technician who solved the problem for me. What he had me do was:-
  1. Pull dowwn the slider and use a pen to press the ACL button.
    That didn't fix it so...
  2. Take off the slider (the way you would to change the batteries). There is an ABCD slider switch and mine was set to "C". I moved it back to "A" and now it works! I am not sure how it got to "C" though ???
The other thing is I had been messing around with the "Manual/Auto" button under the grill on the wall unit. It was set so that the A/C was off. I'm not sure if that is significant.
Hope that helps.
Cheers,
Garry Rogers (ausgaz)
Dec 16, 2008 | Fujitsu 18C1 Air Conditioner
Heating & Cooling Logo
422 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
