Question about Video Game Consoles & Games
My wii is on. i am on the right channel, and the red, white, and yellow things are plugged into the right spots. i can hear the wii music, but the screen does not come up.
Try using your scart connection with the red, white and yellow leads.
Posted on Aug 04, 2008
I just bought a wii and I'm hooking it up to an older model tv. the inputs are on the front and there is only one audio input and one video input. I plug in the red cable in audio and I hear the music...
Hello
The yellow cable needs to go to video.The red and white are left and right speakers or stereo.Usually there is a yellow for video,the cable doesnt have to be yellow, another red or white will work.It just needs to be in the video jack or output.
You need one more cable for video.Also be sure your tv is set to the correct input for the wii to work.Possibly it may need to be on channel 3 or 4. Or if the tv is newer try component or any input available in the tvs setup menu.
Aug 23, 2011 | Nintendo Wii Console
On the sony bravia what ports and what channel of the TV should I plug the cable into for WII? I have tried pliging the wii in but don't know which ports are the right ones and what channel the TV should...
it all depends on model of sony bravia tv, the wii comes with a scart adapter that the white red and yellow phono plugs, plug into so justr use the scart socket , if you have no scart sockets plug the three leads into the composite plugs on the tv
Apr 08, 2011 | Televison & Video
My wii will not connect to my TV. I can hear the disc but I have no connection.
Check your A/V cables (red, white, yellow) on the back of the wii and the TV to ensure they are in the right color holes and firmly pressed into the wii. Then make sure your tv is on the right channel. If those all fail I would try another A/V cable.
Mar 08, 2011 | Nintendo Wii Console
I hooked the Wii up to a different tv than I had it on before. Now, it is in black and white and there is no sound. I am able to go into a game. What can be wrong?
I am guessing that you mistakenly plugged your Wii console cables into a component input section, rather than the normal AV or AV2 input. You can easily tell this by finding out which input station you have to select with your TV remote. If it is component 1 or 2 then your problem you plugged the cords into the wrong section. If you notice in the picture that the component are red, green, and blue, and the AV are red, white, and yellow. The Wii hook up cable is made for the Red, White, and Yellow. Just use a flash light and make sure you are plugging them into the right spot.bagdad319.jpg
Feb 01, 2011 | Nintendo Wii Console
I can't get video out to TV from Wii video input on receiver. Wii is connected to AV5. Video to TV is thru HDMI out on receiver to HDMI in on TV. I can port the audio but get no video
Hello there,
ok the setup you are using is a Receiver, TV, and Wii unit .
Step 1: plug one HDMI cable into the back of the Receiver unit on slot 2 name on it is called HDMI out jack
if looking at the back of the unit this slot is 2nd from the top left
Step 2: now plug the HDMI cable into the TV this is the cable you just plugged into the Receiver
TV done
Step 3: Wii Setup move the Yellow,White,Red cables over to the right if looking at the back of the unit 2 spots name for this group is called AV out Jacks .
Wii Done
now use the right input channel for this group and you should now See Wii playing .
Thank you and don't forget to Rate
Jan 26, 2011 | Yamaha RXV467 Receiver
I have an Envision AOC 32 tv monitor and want to hook my WII up to it, It has yellow white and red wires. The back of the monitor has HMDI, PC Cable, and coax connectors. It also has speaker out puts and...
Yellow Is VIDEO, Red & White is your AUDIO. (Stereo). They should go color to color on the TV's AV input. This is AV, and you use 3 wires to connect this way.
The Red, Green, & Blue, is called COMPONENT, & is ONLY VIDEO, the AUDIO, still must use Red & White. So to connect with Component you use 5 wires, altogether, 3 for Video, 2 for Audio.
Plug them in color to color & choose the right INPUT on the TV, and turn on your input device.
Feb 26, 2010 | Envision L32W761 32 in. LCD TV
Has sound but no picture .....help....tried another a/v cord and same problem....
DO YOU HAVE THE PLUG IN THE RIGHT SPOT. YELLOW TO YELLOW
WHITE TO WHITE
RED TO RED
Feb 23, 2010 | Nintendo Wii Console
Hi, I am having trouble connecting my Nintendo Wii to my Onkyo TX-SR507
Take the adapter cable from the Wii that plugs into the back of the Wii and converts the output(audio/video) into RCA style pin plugs, you will have: RED=right channel audio, plug it into any of the red audio INPUT on your Onkyo, then you will have WHITE=left channel audio, plug it into the other white INPUT jack next to the red plug on the Onkyo, then you will have YELLOW= video(picture) that will go directly to the yellow video INPUT on the back or side INPUTS of your TV.
Then when you want to play the Wii, set the input mode on the Onkyo to the inputs that you connected the red and white plugs into, then change the input on your TV to which ever the input is labeled on your TV in which you plugged the yellow plug into, you now will have sound comming from your Onkyo and the Wii up on the TV screen ready to play. Good luck!
Jan 27, 2010 | Onkyo Tx-sr507 A/V Receiver
I have no picture but hear the sound of the system on my tv
It could be 3 things:
Your tv connections are disconnected and need to be replaced. See if anything else works when plugged into these connections.
Your cable cord could have a disconnect internally and the cord needs replaced.
Your graphics card on you XBOX 360 is shot any you need to replace it.
Good luck and please rate my solution accordingly.
V/r,
Coldissickofman
Jan 23, 2010 | Microsoft Xbox 360 Console
When trying to play dvd player or the Wii, sound from another channel comes across very loud.
Make sure that that audio plugs (red and white) are on the same input as the video for that device (i.e. wii or dvd player) In other words the yellow red and white plugs must all be plugged in under the same input. Where it says "Input 1" or "Component 1" on the back of your TV, all three (red, yellow, and white) must be in the corresponding holes for that device.
Dec 14, 2009 | Samsung Televison & Video
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
