External hard disk and pcmcia cardbus
My external hard disk isnt being recognised by the 4 port pcmcia cardbus which i have. the usb port on my dell inspiron 5160 laptop doesnt work so the cardbus is an alternative. it supports a pendrive but not the external hard disk which incidentally does work on any other system. would appreciate a solution. thanks. merle I bought an "Extra Value 4-port Hi-speed USB2.0 Cardbus" which works fine with flash drives, but not with my Western Digital Passport External Hard Drive, which itself works fine, but very slowly, on the old USB1.1 ports on my laptop. When plugged in to the PCMCIA cardbus, the hard drive light comes on but it does not spin and it is not recognised by my computer. I have tried it with the extra power cord but with no difference. I.m not sure about the cardbus drivers, but I think they installed all right.
Any ideas?
  • 2,794 Answers
There may not be enough power from the cardbus to run it. That bus is very low current to power it up so you will need the power cord.
Try reinstalled the card drivers.
Posted on Aug 04, 2008
Does this devise pick up internet on laptop or desk top either one
Hi cfisherman8
This is a PCMCIA Wireless Adapter Card.
It slots into the large PCMCIA Port that almost all larger laptops and notebooks have.
This device can also work in a Desktop computer but requires a PCMCIA Cardbus Adapter to be installed in the Desktop Computer for it to slot into. There are different types of Desktop PCMCIA Cardbus Adapter. Some types internally connect a PCMCIA Wireless Adapter Cardbus to an empty Motherboard PCI Slot and others externally connect a PCMCIA Cardbus to the computer via its USB or Serial Ports. See here for examples:
http://www.amazon.com/StarTech-com-Port-CardBus-PCMCIA-Adapter/dp/B000BMMN7K/ref=sr_1_21?s=electronics&ie=UTF8&qid=1316320335&sr=1-21
http://www.amazon.com/Startech-Cardbus-Adapter-Transfer-115-2kbps/dp/B004WGR6YG/ref=sr_1_12?ie=UTF8&qid=1316320098&sr=8-12
http://www.amazon.com/Quatech-PCD-X-U142--CardBus-adapter/dp/B001BEF3YC/ref=sr_1_28?s=electronics&ie=UTF8&qid=1316321566&sr=1-28
Other alternative internal wireless networking devices for Desktop computers include a PCI Wireless Network Card. See example here:
http://www.amazon.com/Sabrent-Wireless-802-11n-Network-Adapter/dp/B002DYIZ2Q/ref=sr_1_14?s=electronics&ie=UTF8&qid=1316320278&sr=1-14
Once installed, it is able to send and receive data wirelessly between the computer and any Wireless Router/Modem to which the computer is configured to connect.
This device is most easily used with a Laptop. An easier solution for a Desktop PC would be a USB Wireless Adapter.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa
Sep 18, 2011 | D-Link Air DWL 650 802.11b Wireless...
I have a cardbus card 2.0 and it's recognizing my ipod but not my
You might check with your manufacture and make sure it's 2.0, I known some PC's to come with 1.02 REV2.
Also the best way to check a USB if its working check the following pins on the USB and grab a DMM and measure them.
- From PIN 1 to PIN 4 should measure 5.0V if it's working correctly.
http://en.wikipedia.org/wiki/File:USB.svg
Jul 29, 2009 | Dell 4-Port USB2.0 PCMCIA CardBus Card...
Nec USB 2.0 CardBus on HP Compaq nw9440 with Vista Ultimate
Hi I have a Compaq Presario 919EA with xp operating system and others have a nec pcmcia usb 4-port and when the insert locks the operating system
Feb 01, 2009 | NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC...
Voltage/polarity of power supply for NEC pcmcia 4 port USB2 card
If you KNOW it is 5 volts then you only need to make sure that the amp is higher and never lower. Higher amp only means it can work without getting too hot. But the VOLTS MUST BE precise. For polarity it is MOST common to have the center pin PLUS and outer NEG/GND. When I fix laptops and put the powercord wrong nothing happens. When I get it right then lights go on on PC.
Oct 31, 2017 | NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC...
External Toshiba 400GB HDD not recognized on my Dell CPx J650GT
New hard drives need to be formatted! So go into the control panel switch to classic view, ( if you are still using category view for the control panel ) open administrative tools, then open computer management. Next open disk management. In disk management your new drive will show as raw, you will be give the option of formatting the drive, select primary partition and format in NTFS.
This will then format the drive, when this has finished your new drive will appear in my computer.
Alan
Jan 18, 2009 | Dell Latitude CPX Notebook
Try reinstalling the drivers for the PCMCIA card and get drivers for the external hard drive..if that doesn't work then get this here. Don't buy dell they have bad quality products.
May 20, 2008 | Dell 4-Port USB2.0 PCMCIA CardBus Card...
Did i just get ripped off?
Did you install the latest drivers for this device? Download and install the latest dell drivers and firware for the cardbus controller. Make sure you are using dell drivers, not microsoft from windows update.
Nov 11, 2006 | SYBA 4 Port Combo CardBus/PCMCIA to USB...
Computers & Internet Logo
David Payne
David Payne
