Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Flap My floor/ tools knob won't turn. The knob controls wheather you are going to use tools to shampoo furniture of floors. The flap and knob will not trurn
    President:
  • 1,673 Answers
Most likely the diverter valve is broken part #2136988. You will have to remove the top to replace it.
Posted on Aug 10, 2008
Dirt devil turbo clean sd40060 Cyclonic vacuum. Was given it as a present. Floor tool won't spin. Checked everything! Belt, for hair through out. All ok. Why isn't it working?
You should find a large button or flap on the floor tool. This is usually spring loaded and needs to be OUT. This should then let air in to drive the turbine which drives the spinner.
Check out Vacuum Cleaners Upright Hand Stick Canister Vacuums Dirt Devil
Aug 08, 2015 | Dirt Devil Vacuums
Just got a bissell proheat clearview force cleaner, we press the trigger, no water sucking action or shampoo release going on .. what's wrong?
By the Floor Cleaning setting knob and Tools for PreHeat setting knob, there's a red x inside a clear circle cap. Is it spinning at all? If not...twist the cap off and remove the red x. Under the red x there is a tiny little filter. This might be plugged. Pull it out and clean it. Put back in (this is all really easy).
See if it works now.
Dec 24, 2009 | Bissell 1699 ProHeat Clear View Upright...
How do I hook up my Bissel Proheat to clean my sofa?
There is a little switch on the side of the machine base that reads "floor cleaning" and "toos or preheat". Switch that to the tools setting and a little flap under the "clearview" shield will lift. Just take the hose off of the little rack and attach one of the cleaning heads. Check that the flap isn't blocked by lint or something. If this doesn't work you may have some other problem.
Sep 16, 2009 | Bissell 1699 ProHeat Clear View Upright...
My dyson won`t stand up
http://www.youtube.com/watch?v=JX7axXoYfIc
The red foot release pin jumped track and is stuck in a square
Jan 10, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Vacuum won't go to upright position, and seems to **** through the floor portion and attachment at the same time
Hi.
If you look at the front left side of machine there is a removeable inspection port it will have 2 coloured buttons you press these in & pull it up to remove.
Now pull handle back as if vacuuming the floor.
Now where the inspection port was you will see that there is a square hole pull forward on the flap in front of square hole it pivots just behind the round rubber seal.
Slowly lift handle back up at the same time The part with the 2 long grooves in it must go under the flap as you lift handle.
Chris.
http://dysonmanuals.llc.nu/
Dec 29, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Replace the switch that controls hand tools to the upright unit
If that flap isn't moving when you turn the knob for floor or hose, then yes it is broken, part #2136988 is the diverter valve. You will have to remove the top cover, it mounts on the underside of it.
Jul 23, 2008 | Bissell 1699 ProHeat Clear View Upright...
Shampoo stairs
There is a portable shampooer/sprayer that attaches to the hose ( the long one that makes the kirby a canister vacuum). It should have come with your attachments. Looks a bit like a gun without the tank attached to the bottom...the tank screws on.
To use it you would put the fingerguard attachment on the front of the kirby where the powerhead would normally go and the hose with the portable shampooer where the bag would go.
The tank on the portable sprayer/shampooer has lines to indicate how much water and shampoo are needed.
Be sure to put the mesh nozzle (sort of a triangular shaped thing with a piece of mesh along the front that attaches to the front of the portable sprayer) on the front of the portable sprayer if you want to shampoo..otherwise it will just spray a mist. The triangular piece with the mesh screen is what produces suds.
Vacuum the furniture/stairs thoroughly before shampooing. Cover the stairs/furniture with a thick coat of suds. Once covered with suds, pop the suds into the fabric/carpet using your hands...working the bubbles into any heavily soiled areas with a soft brush. No need to vacuum after shampooing. There is only about 10 percent water to 90 percent air in the suds.
Then let it dry. 15 minutes to and hour depending on the amount of solution used. Hope this helps!!!
Feb 23, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Unable to Extract Water
1/ Is the diverta flap in the correct position.
2/ red lint filter in tank clean.
Sep 03, 2007 | Vacuums
Bissel Proheat 7901 Diverter Knob and Flap problem--Helpppp!
Manual here in case you missed the link; http://www.bissell.com/images/UserGuides/7920.pdf Waiting on your photo as discussed. :)
Mar 14, 2007 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
255 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
