Question about Hampton Bay 52 In.Carriage House II in Polished and Satin Brass Finish Fan
Hampton Bay Carriage House II Ceiling Fan Light Kit Wiring
I am trying to install the light kit that came with this fan and have an orange wire that is inside light kit that is not connected to anything. Does it stay this way or does it need to be connected to some of the other wires inside kit or should it be installed to a wire from the fan?
  • Allen Neal
    Allen Neal May 11, 2010
    what are all the colors in the light kit examlpe black white ect
  • 3 Answers
SOURCE: need wiring instructions
The wiring is pretty self explainitory with the wireless receiver. As for installing the receiver; get the wiring done and then zipstrip the receiver to the side of the motor mount bracket. Just make sure that you put it where it clears the canopy (motor cover).
Posted on May 24, 2009
SOURCE: Wiring light kit to ceiling fan
connect the white wires from light kit filter to the white wire labeled "for light" from fan. then connect black wire from light kit filter to blue wire from fan. use wire nuts to make the connections
Posted on Feb 09, 2010
  • 351 Answers
SOURCE: Trying to connect a ceiling fan light kit.
Those connections sound OK ,, now you have to go to the canopy and see if all the wires for the fan/light are connected to a house wire. If there are two switches , then the blue fan wire would connect to the red wire .. it may be capped off in the ceiling. If there is only one control switch , then the blue wire from the fan will connect to the same ceiling wire as the black fan wire does.
Please Vote !!
Posted on Jun 01, 2010
GeneratorDan
  • 44 Answers
SOURCE: I have a Hampton Bay
Go to home home depot or lowes . Thats were I go to match up fan parts for customers . Alot of those are universal . Hope this helps
Posted on Nov 06, 2010
  • 37 Answers
SOURCE: i bought a house with
If you have the fan working are sure there is not a light switch some where in th room that goes to the light side of the fan.and the chain for the light will have to be pulled to on also.is it a remote control fan that would have a remote that has been lost.some fans have a little black box in them that is a radio cntrl.you should be able to remove the fan with a few screws at the base next to the ceileing.be careful they can be heavy.
Posted on Apr 25, 2011
I bought a house with hampton bay fans and used a different lighting kit and hooked blue and black wires together and white to white wires and plugged connector back in and light kit will not light and...
Apr 03, 2011 | Hampton Bay 44 In. White Carousel II with...
Trying to connect a ceiling fan light kit. I connected the blue wire from the fan kit to the black wire in the light kit and then connected the white wire from the fan kit to the white wire in the light...
Please Vote !!
May 30, 2010 | Hampton Bay 24002 Ceiling Fan
Can you replace light kit on Hampton Bay ceiling fan, Model-Cessna
Yes..
There are a bout three screws that hold the light part to the fan.
Make note of the wiring before you disconnect it also.
Remove the screws and the wiring will be exposed as the light part drops down...
Check the diameter of the light parts and find a new light kit that will fit it...
The Hampton Bay fans are exclusive to Home Depot, so most any of their light kits will fit, but any kit the right diameter will work..
Heatman101
Mar 05, 2010 | Hampton Bay Cessna 04313 Ceiling Fan
Jan 17, 2010 | Hampton Bay 24002 Ceiling Fan
I installed a ceiling fan with light, fan works but notthe light.
Are you sure you got the wiring correct?
Ceiling fans usually have 4 wires....a black a white a blue and a green
the black & blue wire from the fan need to be connected to the black wire the white to the white and the green to the ground
Sep 18, 2009 | Hampton Bay 52 In.Carriage House II in...
Need wiring instructions
Mar 24, 2009 | Hampton Bay 52 In.Carriage House II in...
Crusier Ceiling Fan Not enough light
You can use another light kit, but it wouldn't be recommended. The wiring inside your fan is designed for that specific wiring kit, another kit and there could be major problems with the wiring. Better to just replace the fan or use a couple of lamps.
Sep 20, 2008 | Hampton Bay 04345 Cruiser Ceiling Fan
Wiring problems
The only thing which goes to the house's white wire is the fan's white wire.
Both the black and blue wires from the fan (black for fan motor, blue for light kit) go to the black house wire.
Anything else could result in a fire, a melting of internal parts, or a massive electrical explosion arc. The owner's manual is very clear about how the fan is supposed to be wired, and you voided the warranty by going against it.
You may have blown a fuse or a circuit breaker, or you may have blown something within the fan, or your house may be wired in series (very unlikely) in which case you need a new separate wire run for the light kit.
I hope this helps! If you have any other questions, feel free to ask!
Apr 17, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton Bay 52 In.Carriage House II in Polished and Satin Brass Finish Fan Logo
762 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
