Question about Kenmore Dryers
Kenmore Electric HE3 dryer not drying
Problem occurred last night. All controls look to be working properly and dryer was tumbling but not heating to dry the clothes. They were cool to the touch and the air coming from the outside vent was cool as well.
  • 5,911 Answers
Please click on the following link for advice on a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Please read through the link thoroughly. Check the power source at the outlet, first, to ensure you have the proper voltage prior to disassembling the dryer. It should read 220-240 VAC across the two hot leads (this would be the RED and BLACK terminals at the terminal block in the back of the dryer if you choose to check there). Then, inspect your ducting to make sure its not clogged or kinked anywhere. If you have questions, please post back and let me know. I hope this helps you.
Posted on Aug 04, 2008
Kenmore elite model 11070092990 dryer tumbling but not heating unplugged and started again-still not drying
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 13, 2011 | Kenmore Dryers
He3 8519320a dryer dosnot heat up
heatman101';
Jun 13, 2011 | Kenmore Elite HE3 Steam 8674 Dryer
My kenmore is 21 years old it is still tumbling but has lost its heat to dry
heatman101';
May 24, 2011 | Kenmore Dryers
My dryer will not heat at all to dry my clothes
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 02, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Dryer won't heat
heatman101
Jun 28, 2010 | Kenmore 62602 Electric Dryer
My kenmore elite he3 dryer has quit heating could it be the heating element and if so where can i find it on the dryer? The model # is 110.82822103 and the serial# is MR1751757
heatman101
Jun 05, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
He3 gas dryer quit heating
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
rtgh
Aug 25, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
Dryer working but no heat
The manual says that two circuit breakers used,and that the dryer
can spin but no heat if one of them tripped, check your panel and see
if any breakers are tripped. If this was the problem,have an electrician
check the circuit.
Apr 09, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Keeps on cutting out on Hot drying cycle
this will be a problem with your thermostats 1 of them will have a thermal cut-out switch built onto it this thermostat needs replacing it is faulty
Dec 07, 2006 | Zanussi TC7114W Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
