My Hp PAvilion DV9000 LAptops screen keeps going blank. If I hook it up to and external monitor then it works.
Here is the warning I get
Log Name: System
Source: Display
Date: 8/4/2008 4:32:54 PM
Event ID: 4101
Task Category: None
Level: Warning
Keywords: Classic
User: N/A
Computer: George-PC
Description:
Display driver nvlddmkm stopped responding and has successfully recovered.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Display" />
<EventID Qualifiers="0">4101</EventID>
<Level>3</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2008-08-04T20:32:54.000Z" />
<EventRecordID>9205</EventRecordID>
<Channel>System</Channel>
<Computer>George-PC</Computer>
<Security />
</System>
<EventData>
<Data>nvlddmkm</Data>
</EventData>
</Event>
Posted on Aug 05, 2008
    Champion:
  • 232 Answers
YOUR INTERAL DISPLAY ADAPTOR MAY BE GOING BAD, HAVE U TRIED REINSTALLING THE DRIVER , IF SO ITS UR ADAPTOR OR THE SCREEN ITSELF WHICH IS NOT A BIG PROBLEM REPLACING. THE EASIEST THING TO DO IS ASSUME ITS THE MONITOR. DOES IT DO THIS IMMEDIATELY OR DOES IT TAKE A WHILE. WHEN U HOOK UP THE OTHER MONITOR DO BOTH SCREENS WORK.
Posted on Aug 04, 2008
HP Pavillion 500series to Panasonic TV with DMI port, hooked the HDMI cable from it to the tv, blank screen, made sure the tv was on HDMI, blank screen, unhooked the monitor, blank screen, hooked the...
Most laptops have a "toggle":
* output video only to internal LCD screen,
* output video only to external HDMI port,
* output video to both internal & external.
Set the "toggle" to the best value.
Jun 15, 2011 | HP Pavilion dv9000z Notebook
I have an HP Pavillion dv9000. I RARELY use it, but my screen is blank. The power and lcd lights come on, but the screen is blank. I've taken the battery out, connected the power cord and turned the...
This might be a sign of a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Test with an external monitor attached to the laptop. If you get display on the external monitor, then this confirms the case.
Aug 21, 2010 | HP Pavilion dv9000z Notebook
The computer will start up but the screen will be blank
Try plugging in a regular computer monitor, if that works then you will need to open it up and check the screen's connection. if you get now lights from the regular monitor then you will need to check you ram/memory to see if it is connected properly.
Feb 27, 2010 | HP Pavilion dv9000z Notebook
Blue lights come on but screen will not come on or
see care fully at ur screen with in some external light
u see somthing check ur laptop to an external monitor
if working?now ur lcd problem
Jan 27, 2010 | HP Pavilion dv9000z Notebook
HP Pavilion dv9000 Entertainment PC shows a black screen and nothing else when it is turned on...warranty expired in March 09. HP said not under warranty anymore and to take it to get serviced.
Try and hook it up to an external monitor by using a vga cable. If there is a problem with the main display, the laptop will drive an external automatically. I have to tell you though that these laptops are notorious for burning out the video processors in them. If that happens to be the case, you will need a new motherboard. The one good thing about that is that there are instances where the motherboard from a dv6000 and the dv9000 can be interchangeble depending on the model. If you do get a picture on the external display then you may have just lost the screen and they can be changed out by just taking the bezel off the screen and disconnecting screws and cables. Let us know
Sep 14, 2009 | Computers & Internet
Laptop screen blank at start up
If it still doesn't work when you hook it up to an external monitor, assuming you did that properly, then it is your motherboard/video card.
If you have a seperate video card, I would replace that first. If you don't have a seperate video card, then you need a new motherboard.
FIRST - I would try hooking it back up to an external monitor, and making sure you switch it over to use the external as the default. otherwise you wont get picture.
Sorry... good luck.
Sep 10, 2009 | HP Pavilion dv2120us Notebook
Screen problem HP DV9000
Please perform system restore on your pc. Restore to factory default and remember to backup your documents.
rate this
Jun 04, 2009 | HP Pavilion dv9000z Notebook
HP dv9000
 Hello jarkk, I believe your problem is with your backlight inverter. the hard drive should be installed for this process of checking it on an external monitor. with the hard drive removed it will not boot to the operating system. with the drive in, use the external monitor. if the monitor works when plugged into the external monitor plug, this will eliminate a bad video card. if the screen is still black on the laptop screen, replace your backlight inverter. the last case cenario is to make sure your backlights are not burnt out.
Sep 11, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
114 people viewed this question
David Payne
David Payne
