Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Ge profile specrtra gas stove JGBP85WEB5WW
Got zapped during an electrical storm. Power went out to the stove, from a 220 outlet stepped down with an adaptor to 110. I plugged it into a regular live outlet and it sparked / arced. I pulled the plug, it didn't blow the breaker. I dismanted the stove until I found the door locking mechanism fried. It appears a micro switch is vaporized on the mechanism. I don't know if replacing the part will fix the problem or only fix it until I plug it in again. Is there some typde of voltage regulator I should have checked before replacing the door lock? I tried plugging it in without the part, but loose wires sparked, I didn't tape them up, however the clock & ignitors work but the display reads door locked.
  • 3 more comments
  • pelicans Aug 04, 2008
    need an appliance expert. we have 100 amp service
    What parts?
    Can you be more specific? Where is the circuit board & what parts do we need? My husband is very handy but I don't want him electrocuted.
  • pelicans Aug 05, 2008
    It's a 220 VOLT plug stepped down to 110 VOLTS (not amps). The service is 100 AMPS
    Got zapped during an electrical storm.We have 100 amp service. Power went out to the stove, from a 220 volt outlet stepped down with an adaptor to 110 volt. I plugged it into a regular live outlet and it sparked / arced. I pulled the plug, it didn't blow the breaker. I dismantled the stove until I found the door locking mechanism was fried. It appears a micro switch is vaporized on the mechanism. I don't know if replacing the part will fix the problem or only fix it until I plug it in again. Is there some type of voltage regulator I should have checked before replacing the door lock? I tried plugging it in without the part, but loose wires sparked, I didn't tape them up, however the clock & ignitors work but the display reads door locked. I have had several suggestions but no one actually answers my qustion.
  • 770 Answers
What is your email I will send you the service Guide on your model It is too detailed to trace out here
Posted on Aug 05, 2008
  • 2,071 Answers
  • LORETO LACARON
    LORETO LACARON Aug 12, 2008
    did the solutions from all of us experts solved your problem if not then let us know the current updates so all the fixya experts can assist you further
    Genius:
  • 2,035 Answers
Please use this link to get the part for your burner:
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Good luck..
    Master:
    Sergeant:
  • 462 Answers
There is one way to try to solve but it will involve lot of patients and say workmanship... first thing u need to trace the wires inside and check for all electrical compartments see for burn outs like u said in the door mechanism and clear one by one... but for this again u need electrical knowledge to service.. not much can be explained thru here.. cos even a minute mistake will blow it again... so take ur time and do it... also u need to clean them for healthy operation too..
Thankyou
    Genius:
  • 1,226 Answers
Hello:
Thats dangerous! You fix it by yourself considering that you are expert enough to do so.
You should isolate each parts that is busted or burnout and then replace it one by one.
recommendation: leave it to the expert to check it personally for you. or call repairman in your location.
melnavz
Posted on Aug 04, 2008
  • Emelio Navaja
    Emelio Navaja Aug 07, 2008
    Since you plug it to wrong voltage outlet, Yo should see to it that some parts is ok, You check the voltage regulator. if you plug in and there still power means that fuse is ok. besure to check it carefully before you do some replacement in the sense that when other parts got errors the system will not function correctly.
    good luck!
    melnavz
  • 876 Answers
Sounds as though it was a bit jerry rigged when installed. You had a 220 amp plug with an adapter for 110, but you only have 100 amp service. You need an appliance repair person to even make the appliance safe to use again...
    Genius:
  • 1,269 Answers
If something sparked when you plugged it, there were electronic components that might have been fried. Go to nearest appliance repair center or electronic repair services and have them check the circuit board for possible part replacement.
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
You should be able to order these parts and replace them. it will be fix it....
thanks
good luck
    Master:
  • 555 Answers
How many amps on your circuit?
Where do i find the pilot light on my ge profile gas stove
Are you sure it has one? A lot of the newer model gas ranges are "pilotless ignition." I had one that did and it had to be plugged into an electrical outlet and the outlet for some reason quit working, so the igniter wouldn't work either...
Jun 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
GE Profile Gas cooktop stove- buzzer won't stop
Unfortunately you have to wait until it dries out. I have tried hairdryer before but most of the time I have had to leave it off overnight. FYI if you dont shut off at the circuit breaker and the sparking continues it will short out and definitely get worse
Feb 09, 2009 | GE 36 in. Profile JP968 Electric Cooktop
Electric range burners and oven element just stopped working. Burner indicator light came on and oven temp setting displays correctly. Clock went into set mode automatically, though. Burner came back on...
check the power behind the stove, the outlet for 220 volts, i just fix one with the same problem, it was getting 110 volts but not the 220 volts. so there was nothing wrong with the stove but with the power source.when the stove indicator lights work and the clock, it means that only 110 volts are coming to the stove.
Dec 10, 2008 | GE JBP24 QuickClean Electric Kitchen Range
The 220-110 volt saga
Not sure, maybe broiler and oven element on different circuits?
Aug 31, 2008 | GE Profile JTP56 Electric Double Oven
GE profile stove, Gas-electric
All oven elements are 115/130 VAC. Stoves use 220/240 so that you can use both the burners and Oven at the same time. Since the burners are Gas, then 220/240 VAC isn't needed.
(Note: 220 is simply dual 110 hot leads with a common ground)
Aug 31, 2008 | Tappan MEF500 Electric Kitchen Range
GE Profile Spectra JGBP85WEB5WW
im assuming you dont have to light the pilot.if thats the case and you replaced the ignitor assembly it could possibly be the ignition module/board.
Aug 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP85WEB5WW Range
It sounds as if you might have a problem with the gas valve for the oven. This is something that I would not reccomend that you try and fix yourself.
Aug 12, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
No power...
If the stove was on without the hood fan's being on, it could have put too much heat in the "innards" of the microwave. It may have opened the thermostat or thermal fuse located inside - either on the chassis of the microwave or or the magnetron. It will look something like the one in the attached photo. For helpful exploded view diagrams and to order any needed parts, you can visit the GE parts Web site or the Sears parts Web site at http://www.geappliances.com/shop/prts/ or http://www3.sears.com/ (the 3 is correct) In my profile, you can find a link to my site, where you can find critical safety & disassembly tips. Post back if you need more help.
Dec 23, 2006 | GE JVM1660 Microwave Oven
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
78 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
