Question about GE Kitchen Ranges
A SERVICE REP FROM LANDER WYOMING CAME TO FIX MY STOVETOP IN APRIL, HE DISASSEMBLED THE WIRING AND LEFT IT EXPOSED, THEN DECIDED WE NEEDED A NEW BURNER INSERT AND KNOB, I CALLED TWO MONTHS LATER AND HE SAID HE HAD TO TAKE IT ALL APART I REMINDED HIM OF HIS DEDUCTION AND HE SAID "OH, I GOT MIXED UP, I'LL ORDER THE RIGHT PARTS AND CALL IN A WEEK OR TWO, NOW TWO MONTHS LATER NO CALL, I LOST HIS NUMBER HE WAS ASSIGNED BY GE, I STILL HAVE NO WORKING BURNER OR KNOB ON MY BRAND NEW COOKTOP AND EXPOSED WIRING
  • 6,487 Answers
This job needs to be handle by a professional tech for that unit so better call GE and ask for someone else that can come to your house and repaier this unit and also try to file a complaint about the previous tech/rep that handle this concern..
Good luck..........
Posted on Aug 04, 2008
  • GE Master
  • 19,396 Answers
Call GE at number at the end of user manual and complain ask to get a different engineer. You need to get the fix finished from them.
  • Ginko
    Ginko Aug 04, 2008
    GE number is 1-800-848-7620
    Monday - Friday: 7 a.m. - 10 p.m. ET
    Saturday - Sunday: 8 a.m. - 6 p.m.
    Guru:
  • 1,894 Answers
Its better to call GE and register a complaint telling that the service person has not responded back.
they will look back into history and send him again
SOURCE:
The remote cord is frayed the full length exposing wires within. It's the model designed for 350# capacity
wrong site fixya doesnt sell products need to direct your request to the proper company
Nov 05, 2017 | The Office Equipment & Supplies
I have an Audix D6 that was hastily disassembled, the wires on the microphone capsule were Ripped off How can I repair?
Not to be rude...send it back to Audix to fix or replace. They are somewhat of a liberal company, and usually fix things or replace for free. Just talk to a rep. Now, I am not saying lie to them about it being disassembled.
Jan 03, 2013 | Audio Players & Recorders
My casio exilim cant open the lens anymore.I think it was stuck up because of the sand.My cousin left it on the sand when were having our swimming last April 2010.And the big problem is that she left my...
Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
If these don't work, you'll need to contact the support section of the Casio website for their advice. Get an estimate for repairs....then decide if you want it fixed or replaced.
Apr 27, 2011 | Casio Exilim Zoom EX-Z250 Digital Camera
Front A/C blowing hot air.
Do you have thermostat in proper zone mode?
If still having trouble, try calling customer service/tech assistance number in manual for Monaco or Holiday Rambler. If you don't have number let me know, I'll do some digging & see if I still have it. Or, get back to me with thermostat model & rooftop AC models.
Jul 07, 2009 | Heating & Cooling
Stovetop lamp sockets very brittle and are disintegrating.
In effect (given the unit is wired correctly) without insulation on the socket, you have an exposed neutral wire in your oven -- this is certainly not as dangerous as an exposed hot wire, but does present risks. I recommend replacing the light sockets -- you'll sleep and cook a lot better.
Apr 23, 2009 | GE JVM1660 Microwave Oven
Disable coin vendor
It is easy to do... Just take the cover's off that will expose where the coin op wire is pluged into the copier. It is a 4 wire clip, I believe. Turn the copier Off and cut the wire on the coin op side and strip the wires. Of the wire's that are there you only need to have two of the wires jumed togather.to make the copier to work. I don't know how many wires are there they may have 2 or 6 or 10, it depends who made it. If you are lucky they may have left the jumper clip in the copier, just connect it again. If not jump two wires and turn copier ON and see it the display is un-locked. If not try another set. It is trial and error. You should be able to fix it. Good Luck
Jan 30, 2009 | Minolta EP4000/5000 CS/PRO Copier
LG Electric Range Oven Keeps Shutting Off
When you say "Just shut off" do you mean the circuit breakers would trip, or fuses would blow? If so, I would have an electrician check that the circuit is properly fused/breakered and wire sized for the amount of power required by the oven. If the installation directions say it needs a 50 amp service, it better be a 50 amp service.
If shutting off is just something within the oven, then get LG back out again, and let us know of what they say is wrong.
Jan 24, 2009 | LG 30 in Kitchen Series Dual Convection...
Bake element split and oven will not heat.
thats an eazy one by a new element from one off our links at fixya and install it with the power off and no theres no reason why this happened it just wore out God bless,tom
Jan 01, 2009 | GE Spectra JBP78 Electric Kitchen Range
Hotpoint RVM1425BA-003 Microwave Oven Stovetop Light Does Not Work
The problem is almost certainly on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 14, 2007 | Hotpoint RVM1425 Microwave Oven
Kitchen Ranges Logo
102 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Archie Ferrarini
Archie Ferrarini
Are you a Kitchen Range Expert? Answer questions, earn points and help others
