Question about Philips VOIP8411B/37 IP Phone
"New request waiting"
I have this icon on my handset display- has anyone any idea how to remove same ?!
  • ynotbrianwar
    ynotbrianwar Aug 18, 2008
    Thanks very much....sorted !
  • Anonymous Aug 24, 2008
    I have the same concern. Can't figure out what the icon actually represents or how to get rid of it........Rick
Press: Menu
Press: History
Press: New Contact
Then accept or decline the requests.
Done!
Posted on Aug 17, 2008
I am trying to register my panasonic kx tga641es to the base. I have no instructions/user manual...can anyone help please???
I have similar model and setup should be the same..
1, Handset: press Menu
2, Handset: scroll using up/down arrow keys to "Initial setting" then press soft key Select
3, Handset: scroll to "Registration" press soft key Select
4, Handset: sroll to " HS Registration" press soft key Select
5, Base Unit: Press and hold (LOCATOR/INTERCOM/TRANSFER) for 3 seconds. The Charge indicator flashes. After the CHARGE indicator starts flashing, the rest of the procedure must be completed within 1 minute.
6, Handset: 1: press soft key OK
2: wait untill a long beep sounds and the display shows the new extention number
**Registration should be complete**
Aug 25, 2011 | Panasonic KX TGA641ES 1Line Cordless...
I have done a hard reseet on my acer f900 now it shows arabic language!! can u help me to change it into english
TAP start- settings- system- regional settings( icon is earth)- locate English(ur country) in the search box- tap ok.
Next, TAP MULTILINGUAL SUPPORT( located near the regional settings, before the battery icon. Still the icon is earth but it has a somewhat ring figure)- locate your country. Then go to CONTROL tab located below<3rd tab>, unmark the first box then just below it, choose English with Arabic Enabled- tap ok.
Make sure to restart your handset. Long press the power button until it displays an icon that means do not turn off handset by removing the battery then if it's already off. wait for a couple of seconds, like 10seconds maybe then turn it on again.
Jul 08, 2011 | Acer F900 Quadband 3G HSDPA GPS Unlocked...
How do I deregister my handsets on my VTech 2656
To be able to register your replacement handset, you must de-register all the handsets from the VT2656 base unit.
Follow the steps below to de-register your handset(s) from the VT2656 base:
1. Take out the handset that sits on the base.
2. Unplug power from the base.
3. Hold down PAGE while reconnecting power. When the In Use light blinks, release the PAGE key.
4. Hold down PAGE key for 5 seconds. When the In Use light begins to flash, release the PAGE key.
5. The handset charging light will blink 5 times. Within 5 seconds from when it stops blinking, press PAGE once.
You must register the handset(s) by following the steps below:
1. After charging the handset, remove it from the cradle, the LCD display will read "SEARCHING FOR BASE".
2. Press "NEW" and then enter the 15-digit Base ID code, located on the underside of the VT2656 base unit.
3. Press "OK". The handset will display "PLEASE WAIT!!".
4. Wait approximately 15 seconds. The handset will display "FOUND BASE". If the handset displays "BASE BUSY TRY LATER", this indicates that the system is in use. Wait until the base unit is in the idle (on hook) mode and repeat steps 2-4.
Apr 30, 2010 | Vtech Digital Cordless Telephone VT-2568
CD445 voice message icon won't stop flashing
This feature is country dependent and may not
appear in some countries.
If you have subscribed to the voicemail service
from your local service provider, icon turns
on when you have a new message in your
mailbox. After you have accessed to all the new
messages, icon will turn off automatically. If
you find that the message waiting indication
cannot be turned off by the network, you can
still turn off the message waiting indication with
your phone by the following step :
In idle mode, if voice mail waiting icon is on,
long press the redial key to turn off the voice mail waiting
icon.
Once you choose to delete the message waiting
indication, all the other handsets registered to
the same base station will turn off the message
waiting indication accordingly.
Jun 01, 2009 | Philips CD4451B/37 Phone
Voice Message Icon always displaying
The voice mail symbol is sent to your handset by the network when you get a voicemail, they then send the handset another message to remove the icon once you have listened to the voicemail... Sometimes an error occurs and the phone doesnt receive the removal message...
Try getting a friend or using another phone send yourself a voicemail, then using your phone, check your voicemails, listen to the one you have and delete it... The icon should go... However if its a hardware fault with the handset display then this will not fix it...
May 07, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Can't register new handsets
If you have a multi-handset system, you already have more than one handset
registered to your base unit.
You can register additional handsets to have up to five handsets per base unit,
with each handset's number (1 to ) shown on its display. (Note: each handset
1. Press and hold <PAGE> on the base station for more than five seconds, to
put the base station into registration mode. It will stay in registration mode
To register a new handset to your base:
for about 1 minute, so the following handset sequence must be completed
with in this time.
2. Press <MENU> and <UP/DOWN> to select REGISTRATION.
3. Press <OK> and you are requested to enter the 4-digit system PIN.
4. Enter the 4-digit system PIN.
5. Press <OK> to confirm, and the display will show SEARCHING.
If the handset registration is successful, you will hear a confirmation tone and
the <antenna icon> will stop flashing.
The handset will automatically be allocated the next available handset number.
This handset number is shown in the handset display in standby mode. If the
handset registration is unsuccessful, the <antenna icon> will still flash.
I Used 0000 As the default pin when asked.
Hope this helps you
Apr 10, 2009 | Lands Phones
Searching is displayed on handset and Y icon is blinking, looks like a twig sign, have tried move closer to base station, base station is on reset unit restart handset reg, have tried all but gets to...
Turn base around and find the area which says pager/registration. Push this button after you set internally the handset registration.
Menu/H set settings/Reg. Handset
Dec 03, 2008 | Lands Phones
Philips dect 521/525 - 3 year old phone - No dialling tone on one handset
I had the same problem and my hubby managed to reset the phone by simply unplugging it from the electical network. Just wait for few minutes (the date goes back to 1 Jan 2005), then plug it again and try to dial a number. It should work.
Oct 05, 2008 | Philips DECT 2151 Cordless Phone
Unregistered, registering a new base, faillure....
IF YOUR HANDSET WAS WORKING AND THEN STOPPED WITH "UNREGISTERED":
If lowercase unregistered is in main display and a reg. appears under the left soft key:
Press the left soft key below REG. and then press and HOLD the button on the top of the base station until the two indicator lights on top of the base station turn off. Wait until handset signals with beeps and registered. You are done
THIS IS FOR FRESH OUT OF THE BOX REGISTRATION OF UNREGISTERED HANDSET
Press REG Register shall be highlighted.
Scroll to Register. Press Select.
Enter the system PIN (Default: 0000). Use
CLEAR to correct typing errors.
Press ENTER to confirm.
• Your handset starts searching for the base.
Press and HOLD the round button on top of the base unit until the two
indications turn off.
• If registration is successful, the signal icon
Jun 22, 2008 | Philips VOIP8411B/37 IP Phone
Unable to register, not asking for password
See below for complete instructions but think you have missed out part 2......
Reregister the handset or add additional handsets.
1. Remove all handsets form charging or Main base unit.
2. On on Main base unit, press and hold Page button for 10 seconds until beep. ( Not paging beep )
3. On 'unregistered' handset press and hold Redial & Calls buttons ( Top left and top right ) until 'bs-' appears.
4. Enter handset number ( eg: bs-1 ) then the pin number( could be 0000 but check your manual ).
Cheers
Monty
Feb 16, 2008 | British Telecom Freestyle 2200 Trio...
Philips VOIP8411B/37 IP Phone Logo
60 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
