Question about Standard Oregon Chainsaw Chain For Stihl Chainsaw 24" Bar Length 84 Drive Links 3/8 0.05 Gauge Chiesel Chain
Chainsaw will start but will not stay running.
    New Friend:
Do i need to add oil to the fuel, or should i get the fuel mix? for an 2.0 c eager beaver
Posted on Jun 25, 2013
  • 784 Answers
1. Check Idle settings.
2. Check Spark plug some plug is bad if engine heating!
3. Check all sealings, first check gaskets between cilinder and carburator, then crancase sealings.
Posted on Mar 28, 2011
Poulan chainsaw starts but won't stay running
Try choking it a little longer and it will warm up and should run
Jul 25, 2016 | Poulan Garden
Cant stay running
What to do if your chainsaw won't stay running?
arborist101.com/what-to-do-if-your-chainsaw-wont-stay-running/
Idle ports may be plugged or blocked - This is the small ports in the carburetor where the fuel passes through when in idle. ... Vent in the Fuel Cap is plugged - If the vents in the fuel caps are clogged the fuel becomes vacuum locked. ... Starting with the High Speed screw, turn it ...
Craftsman 16" Chainsaw Fix - Won't Run - Fixed! - YouTube
? 1:32
https://www.youtube.com/watch?v=aIUVQziXBPY
Jul 7, 2011 - Uploaded by BriggsRepair
Is this Craftsman 16" chainsaw broken? Hardly. Watch this carburetor fix and how it runs brand new!
Chainsaw won't stay running - DoItYourself.com Community Forums
www.doityourself.com/.../360759-chainsaw-wont-stay-running.html
Sep 20, 2008 - Chainsaw won't stay running. Craftsman 16" chainsaw, fuel/oil ratio 40:1. Saw is 10 years old, used once or twice a season. Last used in spring ... chainsaw wont stay running
Aug 1, 2015
Craftsman chainsaw won't stay running
Oct 30, 2010
Chain saw won't stay running
Oct 2, 2006
Poulan Chainsaw - starts but won't run
Apr 28, 2006
More results from www.doityourself.com
Why won't my chainsaw stay running? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 31, 2016 | Garden
Chainsaw wont stay running
if it starts (maybe idles) but then dies when giving it gas it sure looks like its a carb problem , most likely dirt in the high speed jet , but could be a dirty fuel filter as well and that's inside the fuel tank
Apr 16, 2015 | Stihl Garden
Chainsaw poor running
remove the muffler and run it if it runs good open the muffler and clean the screen inside
Jul 11, 2012 | Garden
I have a 394 chainsaw wont stay running
The plastic sleeves are anti tamper devices, if you screw a small self taping screw into the centre of it, it will strike the screw under neath and drag the plastic sleeve out far enough to insert a 2mm screw driver through the hole in the centre and adjust the screw beneath.
Jun 06, 2012 | Husqvarna Garden
Poulan chain saw will not stay running after i start it. What are the carb settings ?
a good starting point is the low speed screw at 1 3/4 turns and the high side at 1 1/2 turns. Hope it helps
May 20, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
SAW WILL START BUT NOT STAY RUNNING THROUGH CUT
remove the carb. and clean. if it has set for a long time with fuel in it. the gas will clog up the small openings in the carb. use carb. cleaner. and inspect the carb. diapharm. may sure it isn't tore or has an extra hole in it.
Oct 22, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Won't stay running
HI. I THINK IF YOU PUT A KIT IN THE CARB I THINK THAT WILL FIX THE PROBLEM. JIMBO
Sep 15, 2009 | Garden
My Stihl chainsaw starts up but then it won't stay running. Changed spark plugs and tried new gas, but didn't fix the problem.
Jets in chainsaw may have build-up. A good build-up remover is called SeaFoam. Add this by direction to the gas. When using the SeaFoam you need to run full throttle with intermittently full choke until motor runs smooth with no choke.
Double check 2-cycle mixture. Too lean mixture in the chainsaw wont stay running.
Sep 05, 2009 | Garden
Standard Oregon Chainsaw Chain For Stihl Chainsaw 24" Bar Length 84 Drive Links 3/8  0.05 Gauge Chiesel Chain Logo
324 people viewed this question
Top Standard Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Standard Measuring Tool and Sensor Expert? Answer questions, earn points and help others
