Question about Dewalt 18v Battery Hammer Drill Dcd950 Dc925
Dc925 drill just stopped working no powe - Dewalt 18v Battery Hammer Drill Dcd950 Dc925
I would imagine its the trigger or battery conections on the drill. How much for it lol
Posted on Jul 08, 2011
I have a DeWalt DC925 type 1 hammer drill,took it apart to repair switch and clean. Four pin bearings fell out,I don't see them on a parts diagram,where do they go ?
You will find them in the transmission, remove the metal cover and they will be located just under it - sounds like it is either the gear posts or the clutch cams on the nose side of the transmission DeWALT DC925 Type 1 Hammer Drill Parts
Mar 23, 2015 | Dewalt DC925 Cordless Drill
It is very hard to turn the adjustable ring that switches from drill to hammer grill
Hi my 925 has had same problem right out the box it must be an allignment thing a find a tap with the old hammer sorts it out
Sep 15, 2012 | Dewalt DC925 Cordless Drill
Why does my screw gun work an then stop and work again ?
The trigger is probably going bad. A replacement trigger is around $30.00
Mar 31, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
Dewalt dc925 drill, the chuck jaws appear to be jammed tight shut and will not open. any ideas?
Hi, soak the chuck in crc overnight then put the drill in low speed and reverse. Hold the chuck by hand or with multi grips and pull the trigger. Hope this helps, regards Phil.
Jul 23, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
When drilling drill comes to a stop easily.i can actually hold the drill and keep it from turning
Assuming you batteries are good you probably have bad brushes. They are located behind the vents-one each side- at the back of the drill. New ones are about 10 bucks from dewalt.
Feb 19, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
DeWalt DC925 electronic brake repair?
first make sure brushes are not worn out and if not then replace the switch. the brake is contained in it to throw a short thru the motor when trigger released to stop drill. You can find a breakdown for this tool at Dewaltservicenet.com
Apr 04, 2010 | Dewalt 2 Dc925 18v ½ Hammer Drill /...
Hi, I have a dewalt dc925 drill. When running the
They all do that a bit. The sparks when starting up and stopping are normal. If it has been used alot brushes may be a good idea but before they need to be changed it will spark quite a bit.
It will not hurt to inspect the amount of brush material remaining.
Jan 04, 2010 | Dewalt DC925 Cordless Drill
We have several dc925 desalt drills at work and
You are set on LOCK? or are you set to let go at some lesser level? My DeWalt is much older than yours and in the same service with no problem.?
Oct 26, 2009 | Dewalt DC925 Cordless Drill
I want to switch the drill chuck.model dc 925.how to do it?
CONTACT YOUR NEAREST TOOLKING STORE THEY WILL ADVISE YOU
Aug 13, 2009 | Dewalt DC925 Cordless Drill
Dewalt 18v Battery Hammer Drill Dcd950 Dc925 Logo
81 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
