Question about Senco Air Tools & Compressors
Why won't the driver retract on my pneumatic stapler
  • Brian Manuel Mar 28, 2011
    Have you taken the head out to see if you have a jam in there ,that is usually the case.
    President:
  • Senco Master
  • 1,388 Answers
Can't be more specific without model number.
Driver not returning to top of cylinder is caused by several issues. Bent driver, piston oring, and check valve. Remove head and pull out driver. The blade should be straight with no missing pieces. Driver piston should fit snugly into cylinder and not drop down cylinder under its own weight. If driver / piston look ok, pull out cylinder and look for check seal in place. It looks like rubber band or one or more orings and fit in groove/s with row of holes (make sure holes are clean). Other problems related to driver not returning is/are lower bumper is missing pieces or cracked and or air exhaust port is restricted, low air pressure. Parts are available at www.toolpartsdirect.com
Posted on Mar 29, 2011
2 Suggested Answers
lester482529
  • 226 Answers
SOURCE: broken piston
go to the harbor freight web site and put your model # in then click parts.hope this helps
Posted on Jul 29, 2009
.CENTRAL PNEUMATIC staples go right through insulation paper how to adjust
quite likely still too much pressure .personally I prefer a slam hammer stapler for that task .
Nov 19, 2017 | Staples Tools & Hardware - Others
What is wrong with my Senco pneumatic upholstery stapler?
only a guess but is the anvil sticking out the bottom where the staples come out . if so push it up a little with a flat blade screw driver .
Feb 23, 2015 | Senco Tools & Hardware - Others
What should I do if my brand new Fasco pneumatic upholstery stapler is leaking air through the tail end...not the hose, but the two holes in the handle? Any suggestions?
Hi Anonymus,
What's happened if the driver blade has stopped in mid stroke, the air will escape. Quickest was 'round this is to take the airline off the tool, then find some scrap wood, place the tool on it as though you're firing it, and in THIS ORDER... pull the trigger and re-connect the airline at the same time. This usually sorts this out. Regardless of the tool make and model this will happen to most users sometime....
Leigh Co Limited
May 25, 2014 | Fasco Tools & Hardware - Others
Stapler trigger stuck
Check for a trigger lock/bar that slides up or down to unlock trigger. If no lock, take a small flathead screw driver and jiggle it in the back of the trigger.
Aug 17, 2013 | Surebonder Pneumatic Stapler
Adjust depth on pneumatic stapler
I have noticed that many nailers do not have a way to adjust the depth. Usually there is a thumb screw under the trigger or on the side of the safety foot. If no visual way to adjust, you must get creative. The bumper stops the driver at the bottom of the cylinder. Adding layer of rubber (inner tube or similar) under the bumper will cause the driver extend less and shaving the bumper will cause it to drive deeper. Another method if to add material to tip of safety to space gun away from work (less deep, using various thickness of spacers like used on flooring nailers) or grind the tip of the driver (cant reverse but if driver is too long grind away) . Buy a spare driver and make adjustment to tip for when you need different setting. Good luck
Aug 28, 2012 | Surebonder Stapler. Pneumatic 1/4 in....
FR350 nailer ram does not fully retract. Lubed ram and it worked most of the time for the next clip of nails. Now it is back where it started, retracting about two thirds of the way, not enough to get...
Did you rebuild the tool? If not remove all the nails and unplug air, BUMP nose on piece of wood and does driver fall down? If so the pistion o ring needs to be replaced. Also if this is not the case look for a jammed nail in the magazine/nose area. Next check for a bent driver blade. All the above could cause your problem
Jun 06, 2011 | Porter Cable 60074 Overhaul Kit For FR350...
I have a ns100a porter cable narrow crown stapler. The driver will not retract, so it will not shoot staples. what can be the problem and how can I fix it? Thanks Pam
Usually when the driver is slightly bent, it will not retract. Easy to check. Remove the head and pull out the cylinder and driver together. Adjust the driver or replace as needed.
Jun 04, 2011 | Porter Cable Cable 18 Ga 1" Narrow Crown...
Broken pistoncentral pneumatic Item No.40116 Air Nailer /Stapler broken @flat driver with round O ring aluminum part
Jul 14, 2009 | Air Tools & Compressors
Sfn1
go to this site it will give you a break down of this tool . http://www.senco.com/con_rem/prod_finder.aspx
May 29, 2009 | Senco SNS41 16Ga Stapler 1" 2"
Air Tools & Compressors Logo
1,505 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
