Question about Vacuums
Keurig model B40 How do I empty the resevoir , I can empty the cold watet tank. We are moving so need to completely empty all water.
  • 710 Answers
The water reservoir lifts out. There are two tabs on the side which lock it in place. You may have to pres on them to remove it. If you are wanting to completely empty the entire machine, I have found an instruction manual and have instructions for purging: Fill reservoir with clean water and replace on machine with lid on it. Raise and lower handle without K cup inserted. Wait for the red light next to "heating goes off.
The blue lights on the control center will begin flashing. Put a cup on the drip tray and press "Brew"
When finished, repeat brew procedure 2 or 3 times and inner tank should be empty.
Hope this helps, if it does, please place a vote for me.
Good luck with your move,
Handie Andie
Posted on Mar 28, 2011
I need a downloadable manuel for a Keurig single cup coffee maker Model B40
just go to keurig.com - they have manuals you can download there
the "b40" is the "elite/b40"
morelater
the show doctor
Aug 16, 2011 | Vacuums
We have a Keurig Elite model# B40 that we've had for a little over one year. Because we do not drink coffee, the machine is only used when we have company. Now, when we turn on the power, nothing happens...
My suggestion is to purchase a different unit. It sounds like the circuit board in this one is problematic and it will cost you more to repair that than purchase a new coffee maker.
Feb 20, 2011 | Vacuums
My Hoover Steamvac Widepath will NOT pickup the water after dispensing. I checked the hose inside the cleaner, there was a cut in the hose so I put electrical tape and completely sealed the cut. Still...
Hi, empty the recovery tank of the Hoover SteamVac if the cleaner fails to pick up dirt. Once the tank is full, many Hoover models have an automatic shutoff that stops the cleaner. If the does not resolve the pickup issue, check the hose of the machine and remove any blockage.
Examine the water tank if water does not dispense from the SteamVac. It could be empty and need of a refill, or you may not have locked the dispenser firmly in place. The detergent tank should also be looked at and filled if empty.
Take care
Apr 12, 2010 | Hoover F6213-900 SteamVac Agility...
Wont spray the cleaner n water out
check the dial setting. - presoak, off, cleaner, rinse
is cleaner bottle correctly inserted?
is clean water resevoir empty?
is dirty water resevoir full?
these items will prohibit the water/cleaner from coming out.
Mar 28, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Detergent bottle keeps falling off, wont stay put and clean water isn't emptying at all
The tank assembly needs to be replaced. Keep your tank handle. The other problem is your water not dispensing. There are electric solenoids and a pump that control dispensing soap and water. Take it to a repair shop for complete diagnosis before you replace the tank. The new tank is better, both soap and water tanks are in one assembly
Oct 04, 2009 | Hoover Vacuums
I have a Hoover Steamvac model #f5888-900. Recently, after finishing use, it leaks a lot of water from the bottom of the unit onto the recently cleaned carpets. Do you know what would cause this spewing...
Either the rod in the handle is holding and not releasing the resevoir asm, this where the tank sits on, is bad. So water is not being shut off completely when off.
Apr 14, 2008 | Vacuums
Hoover steam-vac model #F7458-900 "All-Terrain"
Check the valves at the bottom of the tank(43513026)also check for cracks in the tank(42272104). Another thing to check is the handle asm. is a rod that pushs on the resevoir asm(tanks sits on) to make sure that it is stuck in the on position. Depressing the trigger and watching, you should be able to see if it is moving up and down ok.
Feb 14, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Vacuums Logo
269 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
