Question about Electric Lawn Mower
I cut my chord electric lawn mower - Electric Lawn Mower
  • Brian Manuel Mar 28, 2011
    What do you need to know? you must replace it because in wet grass it could be dangerous,just go to the hardware store and bring cord with noting the length you need and replace the same way you took apart . Probably need some connectors and I suggest crimp style and make sure you use some sort of clamp to keep it from pulling out and also very important to have it have a ground prong on it.The hardware clerk will know what size wire and will even help you with your questions.
    President:
  • 670 Answers
If it is a clean cut, and not all mangled up. You can get a male or female replacement plug at any hardware store to replace the cut off end. Hope this helps you.
Posted on Mar 28, 2011
My john Deere 110- 42" cut lawn mower ran out of gas and won't crank back. Noticed the parking brake is engaged but will still roll. What is my problem?
Hi Shannon, It's either fuel OR electrical, First check electrics, If it cranks but not starting......
How to test a solenoid....
How to test lawn mower solenoid
How small engine governors work....
How Small Engine Governors Work any governor setup
How to test lawn mower electrical safety switches....
Shows all safety switches disabled....
Disable all lawnmower safety switches
Apr 29, 2016 | John Deere Garden
Why does engine cut back, even though the mower still cuts well?
Hi Anonymous, The links below are youtube video's, I hope this helps....CHEERS..
1st shows a craftsman mower with problems....
Craftsman Lawn Tractor stalling out
2nd shows a craftsman seat safety switch disabled....
Seat Safety Craftsman Disablement
3rd shows all safety switches disabled....
4thHow to test lawn mower electrical safety switches....
5th How to test a solenoid....
6th How to test a lawn mower Key switch....
How to test lawn mower key switch
Apr 16, 2016 | Garden
Broken pull chord
Remove recoil assembly from top of engine. Observe recoil wheel and find knotted end of rope in wheel, Observe direction of rope wrapped around wheel, cut knot off wheel end of rope remove rope. Rope purchased by the foot at mower repair shop. Feed new rope end into hole in recoil wheel wrap around in correct direction, feed rope thru recoil cover, remove old rope from handle, feed new rope thru handle to proper length, Knot rope to stay in handle.
May 14, 2012 | Toro Power Lawn Mower
Electric mower will quit after mowing for 10minutes. checked the extension chords and everything is plugged in.
I don't know what model or brand this is but once you make sure you have power at the end of the cord (bring something else to plug in to test it.) My next thought would be the switch. This seems to be the first to go on some of these. Look at the housing and see if it is cracked or distorted. Post brand and model # also.
Jun 16, 2011 | Electric Lawn Mower
I have a Yard Machine lawn mower (Model # 11A-41MY229). I lost the manual. When I pull the chord the motor turns but it won't start. It has plenty of gas. Do these lawn mowers have a starter fuse that...
How old is this lawn mower, and have you replaced the spark plug recently?
Also, check to make sure the air filter is not clogged, preventing the engine from breathing.
May 02, 2011 | Yard Machines 158cc Push Lawn Mower #11a...
My pull chord snapped in half where do
Go to smalleng.com they have video on how to do what you need. Check it out awesome website! The cord you can buy at any local home center. or repair shop.
Apr 17, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Mower Blades
most lawnmower shops can help you prob just a worn keyway ! or goto black&decker.com for closest repair shop?
Aug 27, 2009 | Electric Lawn Mower
Electric mower won't cut well
change a new blade. when was the last time the blade gotten changed?
May 22, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Electric Lawn Mower Logo
52 people viewed this question
Top Electric Garden Experts
dannydoesita
JohnPaul Robertson
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
