Question about GPS
Have a 91 chevy blazer.my instument panel dont work except my turn signals and speedometer.replaced 2 blown bulbs and it still wont light up.steering wheel was replaced.need help
  • Paul Marks Mar 20, 2014
    did it just Quit ? if not replace the speedo head cause they do go then you should be up and runnin if that don,t do it you need to look at body controll module it does all the wiring for you
    One other thing ck the back to see if it is burnt if so at the plug you have problems ?you might be lookin at lots of cash
    Master:
  • 354 Answers
Well check your fuse panel diagram for those components and see if the fuse is there ,maybe they forgot to put them back in or make sure they are good. If so than you might have a headache on your hands if they didnt bother to hook them back up. Or they could have ripped them when they installed the wheel I would have them do it if you have a warranty and if they worked prior to the install. Wiring diagrams can be found inside the back of a Haynes manual that you can get at your auto parts store,it's pretty time consuming and a royal pain. Probably the simplest way would be to pull the instrument panel and just wire it back to the fuse panel off each component(looking at the Haynes manual).Cause by the time you chase down all those wires you could have rewired it.
Posted on Mar 28, 2011
99 lesabre turn signals dont work wont even light up on the intrument panel but the 4 way flashers work
you have a bad turn signal flasher it looks like the hazard flasher but is a separate unit. its under the dash by the steering colume or fuse panel.
Aug 24, 2014 | Cars & Trucks
I have a 1993 Chevy Blazer I recently purchased. The instrument panel only has certain items that light up. The speedometer is one of them. However, this too occasionally stops working. But if you bump the...
bad connection. unfortunatly the dash panel above the steering column will need to be removed to clean and replace any other blown bulbs. suggest if you do remove it, replace all the bulbs with new ones since you're there already.it's not a real complicated fix, mostly phillips screws holding it in, make sure you put emergency brake on because you will have to move the shifter into the lowest gear position to remove the panel. wipe the cluster panel down with a clean dry rag after you've done the replacement of bulbs to remove any oil that has come off your hands during the replacement. hope this helps and thank you for choosing fixya.com
Nov 21, 2010 | 1993 Chevrolet S-10 Blazer
My 97 chevy blazer, the brake lights dont work but the third brake light does and the turn signals or hazard lights dont work??
More likely it is the hazard/turnsignal/highbeam/cruise control switch module. It costs about $275 for the module. However there is a repair kit for the likely culprit...the hazard button. Try jiggling it around a little, see if that helps. Spray a little WD-40 into it so it can jostle back into it's correct position. You could try a junkyard unit or Ebay. It's not too hard to change. The hard part is doing it without removing the steering wheel. It can be done. I've done it. But hopefully you can locate the repair kit which costs about 15 dollars. Good luck.
Apr 27, 2010 | 1997 Chevrolet Blazer
Turn signals wont work, all other lights work. turn signals wont turn on. 1984 Military Chevy Blazer
The element are serpent in the lights bulb the turn signal and brake usually share the same one but the running or park light are not shared with the turn . so if none of the light for the turn signal light then you will want to look for your flasher control it is ether in or near the fuse box or under dash by steering wheel shaft,,you should also check grounds at light socket if we can be of any further assistance please feel free to ask hope this gives you a place to start .Thank You..
Mar 30, 2010 | 1984 Chevrolet Blazer
I have a 1997 chevy blazer the hazards work fine but the turn signal is not working I checked the fuse in the fuse panel. what else could it be
Replace the Turn Signal Flasher Relay. It has 2 relays. One for the Hazard lights and one for the Turn Signals. The Turn Signal Flasher Relay is located Front seating area, driver side, passenger side of steering column, under dash, mounted near cigarette lighter. Optional mounting location is under dash, on driver side of steering column. (Curtorsey Auto Zone)
Dec 15, 2009 | 1997 Chevrolet Blazer
1991 Chevy Blazer dashboard lights are burned out. Can't read
Your dash needs to come out. These bulbs push into a plastic piece that "twists" into the back of the dash board. (About a 1/4 turn) Unless you can get at them from underneath, but I think it's to tight.
Aug 13, 2009 | 1989 Chevrolet S-10 Blazer
2001 chevy blazer all lights work except the brake lights. The third top light works but not the bottom. Bulbs are good and no fuses are out.
does the 4 ways work? if they do it would be the brake light switch at the brake peddle,,,,,,,,, if they dont the problem is in that red hazerd switch on your steering colum inside it has 3 spring loaded pads that make 3 electrical contacts each so 9 in all and they get sticky from dirt, dust & coffee and hot chocolite dumped on them and stick and burn out. and your brake lights stop working... I could tell you how to fix it but rather diagnose what it is first
Jun 11, 2009 | 2001 Chevrolet Blazer
No brake lights on 2001 chevy blazer LT 2wd
Check your wires, the smoke could mean an electrical fire.
Jun 03, 2009 | 2001 Chevrolet Blazer
Turn signal relay switch, 94 s10 chevy blazer
The Turn signal relay on a 94 s10 blazer is located under the cluster area right behind the panel that holds the parking brake release handle you will see it once a couple of trim panels get remove it will be to the right side of the brake release handle
Nov 18, 2008 | 1994 Chevrolet S-10 Blazer
GPS Logo
70 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
