Question about Refrigerators
I have a kenmore coldspot side by side model 106.53582300. We have just hooked it up the water but no water seems to be coming out. We haven't put a filter in yet, is there a trigger of some sort that gets tapped in order for the water to actually come out?
  • 3,289 Answers
Some fridges will not work without a filter. Additionally, it may take a while of dispensing water before water actually flows completely through the system. Most fridges use a small solenoid that snaps open and closed to allow water to flow and stop. The solenoid is usually loud enough to hear without too much difficulty. The ice maker (if installed) has a solenoid for it, too. Both solenoids are often very close to each other at the bottom of the backside (on the rear) of the fridge. This should run automatically as long as the ice detection arm is in the lowered position.
Also, make sure that the water supply line was not kinked when slipping the fridge into its resting place. Make sure the wheels or supports haven't come to rest on top of the line (crushing it) either. Make sure the water valve at the point of attachment to the home's cold water pipe is on. Some of the piercing type valves work a little differently than you may expect. Check the instructions on the package for the valve to make sure it's really on.
I hope this points you in the right direction & good luck.
Posted on Mar 28, 2011
Kenmore Coldspot 106.53592300 ice maker valve does not seem to be working. I have replaced the valves but there does not seem to be power to the ice maker water valve
Go to page 18 on the PDF at the link here=> http://appliance911seabreeze.com/whirlpool_icemaker_troubleshooting.pdf
and use a jumper wire to cause the water valve (Water Valve - L to V) to come on if the water valve is good. Here is an Ice Maker for your model=> HERE and a water control valve for your model HERE
APPLIANCE911
Aug 20, 2016 | Kenmore Refrigerators
Kenmore Coldspot Model 51572200 is leaking water all over the floor
On the bottom rear of the refrigerator as you are looking at it from behind the left side where the water is feeding into there should be a double valve. 1 is for the water and the other to the icemaker. Many times that valve won't shut off, however the switch that dispenses the water is evidentially bad and needs to be checked if it is stuck open.
Jun 03, 2017 | Kenmore Side by Side Refrigerator
Kenmore coldspot refrigerator model #106 RUMBLING!!!
Does it have automatic ice cube maker not hooked up to water? If you do make sure thin stainless bar isn't straight down. on the side of ice maker.
Nov 15, 2017 | Kenmore Refrigerators
2002 Kenmore coldspot 51262103 model number Just hooked it up to water and it runs slow and the ice maker is blinking red.
Not sure if I resolved the issue, but after defrosting my icemaker, with a blow dryer for a second time. It seems to be working fine again.
Is it possible maybe there was some ice build up and every time it added more water for the ice cubes the water level was to high making it impossible for the auger to push the ice thru?
Jun 15, 2009 | Kenmore Refrigerators
Kenmore coldspot side by side refrigerator - freezer fine. other
Good to see you put your model number down correctly. Do the lights come on inside when you open door? I noticed your refrigerator has a control board inside the fresh food section behind the control panel I want you to unplug the refrigerator and examine that board for burn marks or loose solder connections on both Sides. Then let me know what you find. Thanks, Sea breeze My email is appliancepsrtsse@yahoo.com Web Site http://servicepartstec.blogspot.com/ Part Number for Control board is 8201528
Jun 10, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker won't make ice
The ice maker tells the water valve when to send the water on up. Replace the ice maker! goodluck!!!
Dec 16, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side refrigerator
there is valve for each right at the water inlet, your valve is stuck or your coil is bad......get a new valve.
Nov 03, 2007 | Refrigerators
Refrigerators Logo
171 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
