Question about Canon PowerShot SX20 IS Digital Camera
Took the Canon Power Shot on a fishing charter at Coasta Rico. Camera was dampened in a bag with a wave of salt water. Not drenched but dampened. Took batteries out and dried camera for 7 days and still will not turn on. What do you think
  • Canon Master
  • 3,289 Answers
Saltwater? I don't think you're going to revive this camera. If it were fresh water - you'd have a fighting chance - but salt water is highly corrosive and is a much better electrical conductor than fresh water. Even if you managed to get the camera work right after it got wet - chances are the salt would eventually "work its magic" and corrode metal circuits inside the camera and cause it to fail - much the way salt "eats cars" in areas that roads are treated with salt in winter to control ice.
If you ever have a water problem with something not designed to get wet, place the item in a bowl of uncooked rice. Cover completely and let it sit a day or two. The dry rice will wick away water and moisture on and inside the device. If doused in salt water, the water will be absorbed - but salt deposits are left behind, as salt can not be evaporated.
I know it wasn't what you wanted to hear... good luck.
Posted on Mar 28, 2011
I just bought myself a fish. How do I know what is good food to feed it?
Fish food really depend on the type of fish that you have; salt fish, fresh fish etc. Read the information at this website which gives a detailed breakdown of which fish should be eating which foods. http://www.drsfostersmith.com/pic/article.cfm?aid=334
Aug 26, 2012 | Archos Fish
Accidentally soak in fresh water,after drying thru hair blower ,there is power but showing black the lcd
Probably no saving it but there is something you can try. Remove the battery and put the camera in a one gallon ziplock bag full of fresh uncooked white rice. Leave the camera and the rice sealed in the bag for about a week and the rice should absorb any residual water that may still be in the camera.
It is a long shot but it has been known to work.
Jun 18, 2011 | Canon Cameras
L18nikon coolpix got drenched by sea water (a wave).now the screen is blank when started even though it worked well immediately afterwards.it is8.0megapixels 1600antishake AE3.0inch LCD -amritsar
Turning on a wet camera almost certainly will fry the circuits. Salt water will continue to corrode the electronics inside the camera. Start shopping and be careful next time.
Jul 27, 2010 | Nikon COOLPIX L18 Digital Camera
Lens has to be opened w/finger NO error message, though
Find a Canon dealer and ask them to remove the salt spray and grit from the lens opening mechanism. Apparently, the spray put salt and sand in there, and that has stopped the gears from working without help from your finger.
-a.
Apr 18, 2010 | Canon PowerShot A560 Digital Camera
Is there a fix to salt water immersion of camera?
Water, any kind of water is a conductor of electricity. If you truly dried out the camera and it will not power up it probably shorted out. The one thing that might clean any minerals or salts out of the camera that is readily available is rubbing alcohol. With the battery removed, submerge the camera in rubbing alcohol and swish it around, then drain it and let it dry. Do not use anything like a hair drier to do it because alcohol is flammable. After it is dry, install a charged battery and see if there is any sign that it powers up. This is a real long shot and I would use this as a last resort. Getting the camera fixed would probably cost as much as the camera. One other idea, if you have a Homeowner's Insurance policy, is to see if they would cover it.
Mar 22, 2010 | Cameras
Camera fell in the water for 3 seconds, wont turn on
The best advice is to check with Canon, describe what happened, and take their advice. I think you will do best if it is seawater, or saltwater, to return it for servicing, as salt is deadly to some camera parts, and if you switch on with salt water in, it can cause permanent damage to circuits, and even can create a short between components, particularly the flash circuit. If it is fresh water, and for some reason you don't want to return it, it is best to use a hair dryer on medium or low heat to blow dry as much as possible, with the lens off, and the battery and card compartments also open, and come back to it after about an hour and repeat.Do not heat it to anything more than about skin heat, as evaporation will continue at even room temperature. Do this for most of the day, and leave it for a day or two, or even a week, as open to the air as you can, but in a dust-free environment, preferably in a warmish place, like an airing cupboard, so that all moisture will evaporate, Then try it again with fresh battery. I suspect that if it still won't operate, you could repeat the process, but it is most likely then, that you will have to return it for servicing or repair. I had an Olympus C8080w, and me and the camera were swamped by heavy spray from a wave, and I ran to the local shop, bought some tissues, and dried it immediately. I took it home, zoomed out, dried as much as possible down the lens gap, and left it in warm room. When dried out, some salt crystals were left on the lens barrel on zoom out, but thank the Lord, it still worked, and has not let me down - I did use a damp hanky to try and absorb as much water as possible from the outside, and dilute any surface salt as much as I could. I still use it regularly, but dropping into water is a different matter. - Please post and let us know what happens - and the best of luck
Nov 25, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Cannon power shot A 85 camera CCD faulty
Dear Faiz Bhatti Sahib,
You can contact Canon Sales for further guidance about problem in your A85 camera as this only canon contact I found on web.
Shukria.
Oct 14, 2008 | Cameras
Sand in Sony Cybershot DSC-S650
You have a problem.
Sand is very destructive and may make the lens completely unusable, and can lead to broken parts internally. The only way now to fix this camera is to send it to a professional, if Canon, to Canon repair. The lens needs to be completely disassembled and cleaned thoroughly.
Since the lens has extremely small parts, and may not be able to be taken apart and put back together very easily, a repair is the best option here.
As a precaution never take a digital camera in an environment which has sand, or water, especially salt water. If you do, take extra time to put the camera in either a self-zipping locking kind of bag or a padded bag.
If you treat the digital camera with carefulness, and also like you are handling eggs...meaning it can break easily, you will get good service from most any one. It is true, however things happen internally, and can cause problems as well.
Aug 02, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
D70 and ocean water
Replace the Camera Water is death to cameras Salt water Kills them even deader
Aug 13, 2007 | Nikon D70s Digital Camera
Sony Cybershot
Turning on may have killed it. however try this. Take the batteries and card out and leave the doors open Take a polythene bag and place in it a quantity of uncooked rice or salt tied into a suitable cloth. put the camera in and seal the bag. leave in a warm dry place for several days This may save it -or it may not.
Aug 02, 2007 | Sony Cybershot S650 Digital Camera
Canon PowerShot SX20 IS Digital Camera Logo
153 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
