Question about Casio XJ-350 Replacement Lamp
This projector is beyond warranty. I am willing to open up the box and do what is needed.
  • 2 more comments
  • js8427 Mar 28, 2011
    I guess you didn't see my original question? Ok, I will write this yet again...
    I have a Casio XJ-350 Projecter. When I plug it in it the power light turns amber - this is good. When I hit the power button to turn the projecter on it, it beeps at me 4 times and the the temp light blinks red and the power light is a solid red. Needless to say, the projecter is not projecting. I suspect I need to reset something on this projector. Just not sure what.
    Couple problems with your suggestion.
    1. Because it is not projecting, I can't "go into the menu".
    2. The manual doesn't tell me how to do this
    3. I have not recently replaced the lamp
    It's blinking in 1/2 second intervals.
    what is the "mains lead" - do you mean the power cord. I haven't used it for over a year. It was stored in a closet in the house. No water, moisture etc.
    President:
  • 1,623 Answers
What is it you wish to do
Posted on Mar 28, 2011
  • 3 more comments
  • Martin Murray Mar 28, 2011
    if you have replaced the lamp, you will need to reset the lamp counter by going into the menu on the projector ,manual can be obtained here, in case you have misplaced ithttp://www.retrevo.com/search/v2/jsp/myt...
    read page 108 it gives instructions for resetting the lamp timer
    your original question was this "This projector is beyond warranty. I am willing to open up the box and do what is needed."
    Anyway How many times a second does the temp light flash? if its 1 every second then its an internal memory error according to the manual. As you cant actually start up the projector it wont be able to be reset manually
    Have you attempted to leave it switched off for an hour and then reattach the mains lead to see if it will start up. Have you checked the fan is not blocked or clogged. The symptoms really sound as if there is a problem with it overheating or the lamp. Did it alert you saying the lamp is reaching the end of its life, has it been near moisture? Has it been used much lately? If it hasnt , where was it stored?
    yes mains lead is power cord. What colour is the lamp light, the top most light above the temp light
    My conclusion is that the lamp is defective and needs to be replaced, this could have been caused by many factors
The projector has a redish purple tinge on screen. This has been like it and when bulb was changed has remained. I was told this is to do with the LCD prism. The data projector has been running for...
Hi Mark,
It sounds like this is a non user repair. If the projector is out of warranty it may be more cost effective to replace it than repair it as you will be billed around £75 + courier charges for someone to take a look, plus any additional charges. A simple internal cleaning may help. LCD projectors have open optics so dirt, grease, smoke etc can get in and cause staining.
The UK Sanyo repair agent is multicare in Leeds. If you are lucky this projector was supplied with a 3 year warranty and which may still be valid as it's not a particularly old model.
Best of Luck.
Feb 14, 2011 | Sanyo PLC-XU75 LCD Projector
New bulb, fan working, after 10 mins of operation get posterized image; suspect overheating; dust has been cleaned out; has not been taken apart
Hi!
Is the projector placed in a box or an area where it could generate overheating? Is this projector still within warranty?
Please feel free to update me. Cheers!
Feb 04, 2011 | Optoma TX1080 Projector
How do I change the lamp on a NEC NP510 projector? If I open it up it voids the warranty...
The lamp is a consumable item and is not covered by warranties of any kind. The cover for the lamp should not be sealed. If it is contact your supplier for advice.
Jan 20, 2011 | NEC NP510 Projector Projector
Can the projector be opened to clean inside ?
Yes projector can be opened, however its advisable to give it for servicing to authorized service center. The lense adjustments of projector is very important in order to work it properly. Further if you open it at home, you may void the warranty of the product.
Nov 19, 2009 | Acer XD1150 DLP Projector
NEC VT 440 Projector noise
The unit needs to be opened and have the fan checked. If it is out of warranty and you are capable you should be able to access the fan quite easily. It may be rubbing against something or it may have contaminants inside and needs to be replaced.
Jan 25, 2009 | NEC VT47 Multimedia Projector
Canon projector Dim & yellow
Yes, thsi can be a problem with the projector bulb and you may need to replace it already..
Hope that helps.........
Oct 03, 2008 | Canon LV-7230 Multimedia Projector
Changing a light bulb?
Yes the bulb will need to be replaced. You can do a google search and find the bulbs from different vendors at cheaper rates.
As far as knowing how to change it, Dell has excellent tech support.
Nov 21, 2007 | Dell 2300MP Projector with 3-Year Advanced...
Casio XJ-350 Replacement Lamp Logo
157 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
