My washing machine hotpoint wf745 was flashing fault code f 12 and now it doesnt switch on
SOURCE: AEG Lavamat 86720 washing machine
FAULT CODE C 9
Posted on Aug 17, 2008
barkencoa
  • 3463 Answers
SOURCE: Hotpoint Washing Machine WT741
Error code F12 is indicating a communications error between cards, this can be caused by one of several things..
A problem with bad connections, if you can remove and then replace the plug on connectors, check for loose or chafed wires to motor, they can chafe due to tightness of wires, particularly down to the motor.
It is a electrical problem as opposed to a mechanical one.
If you cannot eliminate the problem your self, then i'm afraid your only other option would be to call an engineer out, it can be a difficult problem to pinpoint correctly.
Please leave a rating for my suggested solution.
Thankyou.
Posted on Jan 30, 2009
amgm
  • 32 Answers
SOURCE: can you remove hotpoint bwm 12 washing machine filter
Hi, yes it is. Hotpoint bwm12 is a built-in washing machine, the filter is located at the bottom (black round knob). Undo the filter by turning it to the left (please be sure there's no water inside the machine, or getas much as possible out before opening the filter).
Cheers
Posted on Feb 19, 2009
barkencoa
  • 3463 Answers
SOURCE: I have a F05 fault code on a Hoptoint AQxxf149. Washing machine
The pressure switch is located in the top of the washer. To locate it, look for a small diameter plastic or rubber tube about 5mm in diameter.This is connected to the preesure switch.
Please rate my solution.
Thanks.
Posted on Apr 16, 2009
barkencoa
  • 3463 Answers
SOURCE: my hotpoint washing machine wt960 keeps displaying
Error code F08 is indicating that the heater relay cannot be activated.
Check all connections on pressure switch----module---- and heater.element.
Hope this helps, this is the recommended procedure.
Posted on Dec 01, 2009
When I on the machine LG WF-F5700PCX ,all the lights are blinking. water is not flowing in.
Washing machine all the lights flashing, error codes on ...
www.how-to-repair.com/.../washing-machine-with-all-the-lights-flashing...
Oct 25, 2014 - In this video I'll be showing how to fix a washing machine with all the lights flashing and how to identify error codes or fault codes on Hotpoint, ...
Washing machine lights flashing - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - Flashing lights Many modern washing machines display error codes if they detect a fault, but they don't all display a readable error code.
Flashing Lights on Washing Machine How to Repair ...
? 8:05
https://www.youtube.com/watch?v=P6WZNLO6wE4
Oct 22, 2014 - Uploaded by how-2-repair.com
Flashing Lights on Washing Machine How to Repair Hotpoint, Ariston, ... flashing like this.error faults are available at our website for all makes.
Indesit Washing Machine Repair: Flickering Or Flashing Lights
? 4:36
https://www.youtube.com/watch?v=S1L2N7srXKs
Mar 27, 2014 - Uploaded by DextersLab2013
Indesit Washing Machine Repair: Flickering Or Flashing Lights... Since making this video i have had to replace all of the remaining capacitors ...
Jan 11, 2016 | Washing Machines
Anyone now the fault light codes for this model---thank you
Flashing Lights & Error/Fault code - Repair
Oct 25, 2014 - Now there may be some variances for older models, but there are 3 main types of board listed ... Tagged under: Ariston, Creda, error codes, flashinglights, Hotpoint, Indesit ... And can someone please enlighten me, thank you.
Identifying Hotpoint or Indesit Error Codes - YouTube
? 6:46
https://www.youtube.com/watch?v=aud14I0Zu9M
Aug 29, 2014 - Uploaded by eSpares
If your machine is stopping with flashing lights or a error code on the ... Lights on Washing Machine How to Repair Hotpoint,Ariston, Indesit ...
Dec 15, 2015 | Hotpoint Ariston Aquarius WD420 Front Load...
HOTPOINT WASHING MACHINE aq9f49u f05 fault code is coming on
Hello , I have the F05 fault also ... I have changed preasure switch and have checked the pump and no blockage. It goes through half a cycle then the F05 fault comes up and flashing lights .. Question ... should the pump turn freely if you turn it with your finger ?? Mine sort of judders ... Also when you tru it on a wash it does not draw any water in ??? Can you help please ??
thanks in advance
Malcolm .
Mar 06, 2013 | Hotpoint Washing Machines
Aquarius WF745 Front Load Washer.Full of water won't drain.
The filter is located at the bottom front of washer.
Remove the kickstrip at the bottom, by levering off.
Unscrew filter anti-clockwise to remove and clean..
Be careful when removing filter, as there will be water come out.Lay the drain hose down into a bowl or similar to drain off excess water.
Thankyou
Jan 30, 2010 | Hotpoint Aquarius WF210 Front Load Washer
WF745 Control PCB
Yon can puchase the part you need direct from Hotpoint, go to>
WWW.HOTPOINTSERVICE.CO.UK
In the menu on the left, click on> SPARES.
Then click on the appropiate tab.
Hopefully, you will find the part you are looking for.
Thankyou.
Jan 23, 2010 | Hotpoint WF645 Front Load Washer
F-10 fault code
F10 is indicating pressure switch not sensing correctly.
Check connections from pressure switch to module.
Thanks.
Nov 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpopint Washing Machine WT741 flashing F-12
Resolved the problem.
Switched off the power to the machine. hit the on /off button and the f-12 error code disappeared .
On reappling the power to the machine the orignial programme continued to completionj
Jan 29, 2009 | Hotpoint Ultima WF860 Front Load Washer
Wf860
may be the pressure switch, or the rubber tube up to the pressure switch blocked
Oct 21, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
