Question about Keurig Elite B40 Coffee Maker
We are on the move and I need to empty the water from the heating tank, not the resevoir on the side...how???
Just run it once with no k-cup or tank on it so it can't refill when it's done.
Posted on Mar 30, 2011
Water spits in tank but all inlets are open
It may be time to descale. Most models will give you a message when it's time to have the mineral deposits cleaned.
HERES HOW TO DO THAT...
Empty water resevoir. Disable auto off. Pour approx 48 oz of undiluted white vinegar into resevoir. PLace large mug on drip plate, run brew cycle, dump contents of mug in sink. DO NOT USE A K-CUP.
Repeat this process until the add water light is indicated.
Let brewer stand for at least 4 hours while still on.
Discard any residual vinegar in the resevoir and rinse thorughly.
AFTER approx 4 hours...fill resevoir with water.
RINSE:
PLace a large mug on the drip plate and water brew cycle. Pour the contents of the mug into the sink.
REPEAT this brew process until the add water light is indicated.
YOU MAY NEED TO REPEAT THIS "RINSE" PROCESS if you notice any residual taste.
Jun 19, 2013 | Keurig B100 Coffee Maker
I have a Zoeller Water Ridd'r II Model 48 Sump pump. The pump comes on okay, but will nit shutoff. The float is not impededd, it's just laying on the bottom of the sump. Is this a defective...
If I undrestand your description, when the resevoir is empty, the float lays on the bottom of the resevoir but, the pump doesn't shut off, after water is pumped out? You have to look at this as opposite of a toilet tank filling with water. In a toilet, the water rises and the foat turn the water flow off. In a sump the water will rise, and the float will turnthe pump on until the resevoir is empty, then it will open the system and turn off the pump. If the float doesn't rise, the resevoir will overflow and the pump won't come on at all. If the float rises and the pump comes on but, the float does "not" drop, the pump will continue to run after the resevoir is empty.
http://www.zoellerpumps.com/ProductByCategory.aspx?CategoryID=3
This is Zoellers link. I don't see your pump but they do have a support link. If the float rises and falls with the height of the water, turns pump on, then drops "all the way" and pump doesn't turn off, the switch is bad not the float. Make sure there is nothing in the way of the float dropping to it's full down position.
Jul 03, 2011 | Home
Keurig model B40 How do I empty the resevoir , I can empty the cold watet tank. We are moving so need to completely empty all water.
The water reservoir lifts out. There are two tabs on the side which lock it in place. You may have to pres on them to remove it. If you are wanting to completely empty the entire machine, I have found an instruction manual and have instructions for purging: Fill reservoir with clean water and replace on machine with lid on it. Raise and lower handle without K cup inserted. Wait for the red light next to "heating goes off.
The blue lights on the control center will begin flashing. Put a cup on the drip tray and press "Brew"
When finished, repeat brew procedure 2 or 3 times and inner tank should be empty.
Hope this helps, if it does, please place a vote for me.
Good luck with your move,
Handie Andie
Mar 28, 2011 | Vacuums
Every other cup seems to stop brewing after a few drops come out. Water drips back into resevoir. I tried the paper clip clean out to no avail!
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 26, 2010 | Keurig B60 Coffee Maker
My Keurig b40 has stopped cycling water thru the cup holder portion. It only returns the heated water thru the small fitting back into the resevoir. This appears to be the only defect. Is there a valve...
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
Dec 22, 2010 | Keurig Elite B40 Coffee Maker
How can I demineralize my rowenta iron? I use carbon filtered water in it. The last time I used it white stuff came out of the steam ports and it sounded like there was sediment inside when I moved the...
Fill the resevoir with a 25% vinegar to water solution & turn on the iron until it steams. Allow to cool and empty resevoir then rinse with clean water. Fill up resevoir and & turn on the iron until it steams again. Cool, empty & rinse again. DONE!
Only use distilled or reverse osmosis water in your iron. This will reduce mineral build up.
Nov 13, 2010 | Rowenta Irons
Empty boiler
Turn main water off to the water heater, it may be a valve on cold side coming in to shut off. Next turn power off to the heater and drain the tank the drain will be located near the bottom of the tank.
You will need a water hose to connect to the drain to run water outside. Open a faucet hot side to allow you to drain the tank.
Upon reinstall connect the tank up and fill tank and open up hot side on one faucet at a time to purge out air from system before turning power back on. Make sure you have water flowing from each faucet's hot side before turning power back on.
Jul 02, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Having trouble with my kia carnival over heating, now my heaters in car are no longer working, what could this mean?
my kia carnival 2002 keeps less heating when the car is in slow speed & when it is fast at 100 KM/H the RPM comes down, there is gear oil at Max & engine oil at max and water is getting low. with this i replaced thermostat, have had radiator pressure tested and was fine, radiator water is full but coolant box is getting empty whilst driving the distance of 100 kms. also when it begins to little overheat or just taking off the speed there is a loud ascending rattling noise which seems to come from the under right side of engine But when it catches the speed everything is smooth. & then you park for an hour the coolant tank is empty.or at low. please tell me what to do.
Dec 19, 2009 | 2002 Kia Sedona
Over heating and anti-freeze spilling out of resevoir tank. New thermostat, new water pump, new resvoir tank, radiator 1 year old, new gasket seals. Can not figure out why it is leaking.
Your head gasket has blown or the cylinder head has crancked.You are getting compression in the water system thats why you are getting spill out from resevoir tank.
Jul 29, 2009 | 2000 Ford Taurus
They emptied my water heater to move it without cutting the power, then when I got home I reconnected the water and filled it up and now it wont heat up the water
You have either a burnt heating element or your thermostat is bad. The tank must be drained to check and replace both of these. They are both located under access doors on the side of the tank.
Apr 27, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Keurig Elite B40 Coffee Maker Logo
119 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
