Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
I moved and I have not use my computer for almost 3 yrs. The computer turns fine, its being updated, but the monitor screen its bright at first and go into dark. How I can fix it? Can it be the power cable?
    Scholar:
  • 118 Answers
Are you sure it is not something to do with the computer? perhaps some sort of screen saver?
secondly, there are "power saving modes" on the screen and on the computer, they could darken the screen to save power.
check to make sure these are not enabled.
Posted on Mar 28, 2011
Fuzzy emachine flat screen monitor
hi,
you have to adjust the brightness and contrats so that the image ca be improved properly....other than you have change the wire which connects cpu to monitr since it is 4 yrs old the cable is damged..
thank you for using fixya,rate my answer
vijay
Oct 01, 2009 | E-Machines eMachines Monitor E15T4
Monitor brightness contrast problem
Turn Off auto-adjustment screen
Jul 29, 2009 | Proview PL19Wb Monitor
Monotor screen s shaking..
1. Main filter capacitor 220mf / 420v problem.
2. There is any U P S or Speaker boxs near to monitor.
3. Electrical distabence.
4. PTC problem.
Nov 02, 2008 | Computers & Internet
Monitor black screen
Your first step in troubleshooting this problem is to plug in another monitor to your computer. If you are having the same problem it is related to your computer. If the second monitor works fine then your original monitor is shot.
May 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
My samsung 2032bw monitor has just suffered a white screen of death and wont turn on.
if available try switching another monitor and see if it does the same thing. If the other monitor works fine it is the monitor, if you get the same white screen on the other monitor .. it could be the video card, try updating the drivers. If the monitor is 4-5 yrs old it is probably the monitor.
Mar 11, 2008 | Computers & Internet
7550 brightens intremittently
some component might have loosen up on the circuit of your monitor! cleaning inside and resoldering loose components could fix your problem!
Dec 06, 2007 | HP Compaq FS 7550 17" CRT Monitor
Monitor Black, Green Power Light Flashes Monitor is 4 yrs. old
Assuming you've already checked your driver and system settings, tried a different monitor, and checked the cable and connector pins, this would almost certainly be a problem with the power or signal circuit board inside the monitor.
Jan 19, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
Monitor going black
My HP f1703 is almost 3 years old and started having this same problem. My fix got the display to stay on. Don't know how long this fix will work. I set the monitor brightness to 51 and contrast to 41. You may have to adjust to your levels to your appropriate enviroment. Levels may determine how long the monitor stay operational. Do NOT set your monitor brightness to factory levels it will just start to recreate the problem again. Solution: The monitor should be on with the blue button lighted. If the screen is acting up (you turn it on and the display lights up and then it turns off within 2 to 5 seconds) Try decreasing the brightness level down as much as possible. Wait 15 to 30 seconds and see if the display comes back to life. If not, turn the monitor off and on again and try the procedure again, if necessary. Cause: I believe the monitor brightness level, set at 100 by the factory setting, is over driving the display and causing the protection circuit to cut off the flouresent lamps that light the display. HP had an issue with this display, and had a notice to replace them if the problem occurred during the warranty period. They extended the warranty period from Jun 04 to Feb 06. Check with HP Technical Support to determine if your monitor is cover.
Oct 10, 2006 | HP Pavilion F1703 17" LCD Monitor
Getting More Brightness/Contrast ?
problem with my monitor Viewsonic E70....Memory recall keep flashing......any help out there.....
Mar 15, 2006 | HP 90 19 in.CRT Conventional Monitor
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
75 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
