Question about Crunch BlackMaxx BMX2250 2 Ch 1000W Amp Car Audio Amplifier
What size fuse goes in the 2 side ports - Crunch BlackMaxx BMX2250 2 Ch 1000W Amp Car Audio Amplifier
The amp delivers from the factory with 2 40amp fuses.
Posted on Oct 28, 2012
I took the piston out and didnt watch how the piston goes in the cylinder.its got two holes on 1 side does it go with them toward exhaust side or the intake side?
i can 100% tell you that the two windows go on the inlet side of the barrel so they face the carburettor,they are ports for letting the fuel air mixture into the crankcase its known as piston porting when a piston has these holes very popular with yamaha in the 80's
Oct 25, 2015 | Goes Motorcycles
Where is the low air pressure port on a 2004 Suzuki verona
on what?
tires?
is this a TPMS question, tire monitors?
all you said are and ment Freon (or A/C Refrigerant)
HVAC answers. (low pressure side, is large pipe)
there are 2 ports. each a different size. (big is it)
the tool in hand the Freon R134a can and hose.
has but one fitting (walfart setup)
you look under hood. and see, the 2 big lines on compressor
its just 2 lines.
the one big line on the compressor is that line. Lowside.
and to fire wall it goes, and fitting,
on the way are 2 fittings, only one fits the hose.
they have caps.
here is a generic site, showing the same trick.
http://acprocold.com/blog/car-tipstricks/find-low-pressure-ac-port-car/
the walfart gauge only has 1, on left. low side
Aug 22, 2015 | Suzuki Cars & Trucks
There are 2 ports on the front,right side of the motor. One is vaccuum Port, what is the second one on the left side of it?
If ots the same size then its probably a emissions recirculation libe that recycles your exhaust. Follow the line and what it goes to, that will give you a better idea
Jun 06, 2014 | 1991 Toyota Camry
Craftsman 33cc weedwacker rep lace fuel lines
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, hh
Feb 21, 2012 | Craftsman Garden
Fuel line diagram for sears mini cultivator
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, ``
Feb 17, 2012 | Ryobi Garden
WHERE DOES MY STICK GO IN AN IBM THINKPAD LAPTOP
The model number is located either on the bottom of the right corner of the screen and on the label on the bottom of the laptop and the location and number of USB ports vary with different models.
The USB port is a connector/port that is 12x5 mm in size, some model thinkpad have onlt one USB port and some have 2 USB ports.
The USB ports are usually located at the back or at the sides of the laptop.
The T30 model has 2 USB ports at the back of the laptop located between the LAN and PS2 connectors.
The T40 model has 2 USB ports located at the left side of the laptop.
The A31p model has 2 USB ports located at the back left hand corner of the laptop.
The R32 model has 2 USB ports, one is located at the back left hand corner and the other is located on the left hand side of the laptop.
Feb 08, 2012 | IBM Computers & Internet
Internal line in gas tank came loose
Jan 23, 2012 | Homelite Mighty Lite Lawn Trimmer
I need the fuel line routing diagram for a Craftsman Model No. 358.791510 Weedwacker 32cc/1.9 cu.in. 2-cycle
Jan 18, 2012 | Garden
Craftman trimmers has two gas lines wich one goes to the primmer the one with the filter or the thine one
Jan 09, 2012 | Garden
Want to add refrigerant. air conditioner not very cool. which is low pressure port for adding r134a coolant?
The newer cars have 2 ports. The large port which is the high side and small port, low side. The kit you buy to refill the air cond will fit only one of the ports and that's the small port. You don't want to hook up on the high side so, this is why ports are sized and the gauge will only fit one. The low side should be near the evaporator or on the evaporator.
Aug 11, 2010 | 2001 Dodge Grand Caravan
Crunch BlackMaxx BMX2250 2 Ch 1000W Amp Car Audio Amplifier Logo
50 people viewed this question
Top Crunch Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Vernon Taylor
Are you a Crunch Car Audio and Video Expert? Answer questions, earn points and help others
